Question about Acer Aspire™ T180 PC Desktop
Computer will not boot, it just beeps
When I turn on the computer, it just makes a beeping noise. The monitor displays, vga input no signal.
  • Jonathan Wolf May 11, 2010
    The beeps are the motherboard telling you what's wrong.
    Can you count out the beeps and tell us what they are?
  • ronnie owens Feb 04, 2013
    one long beep
    Novelist:
    Champion:
  • 233 Answers
Could be bad RAM or bad graphics card.
Posted on Dec 15, 2008
  • 53 Answers
You can look up on the internet about beeping, every beep refers to something and how many beeps it does refers to what it excatly is
Try looking here there is a list of beep codes and what they mean.
http://www.computerhope.com/beep.htm
Need any more help let me know
Hope this helps
Posted on Dec 03, 2008
My hpw1907 monitor says no input and wont display anything. The cpu also makes 1 beeping noise that last 1 second nd doesnt come back
A one second beep from the computer is standard for a proper boot.
Do you have a TV that you can plug your computer into to see if it is posting video? That would be the easiest way to test if it is a computer or monitor thing.
Jan 20, 2014 | Computers & Internet
My acer veriton desk top is not booting up and giving a beep continues beep also moniter is not displyaing omething
This is likely a result of the computer not recognizing the monitor. During the POST test during startup,the computer will check for a video output. It can range from the video card failing to just not having the monitor plugged in. I would check you connections, perhaps try a different monitor, even a television that has either HDMI, DVI, or VGA input. If that does not fix it, it is likely your graphics card or on board graphics from the motherboard. Is there anything new since the last time the computer worked? How old is your PC?
Jul 10, 2012 | Computers & Internet
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
Asus led monitor model vh197 shows no signal on screen and no display ,screen became dark
Good Day Dasarathi!
Please check the VGA cable if its properly connected and make sure two screws are fixed to both end connecting the monitor and the video card.
No signal comes out when there is no signal from the video card to the monitor. That is why you need to check if the VGA cable is fix to both end.
If that did not fix it, you will need to open the casing of your computer. Disconnect the video card from the motherboard. Gently clean by wiping a clean clothe over the contact surface of the video card. Then, reseat the video card properly to the slot in the motherboard. Return the casing cover and connect the VGA cable again.
Just remember doing the above procedure is only when the computer is turn off.
Turn on your PC and see if that fix it.
You will need to replace the video card if by booting the PC you will hear a series of beep codes. If no beeps then you are lucky VGA cable is the faulty one.
Jun 09, 2011 | ASUS Computers & Internet
Monitor has no signal
have you tried you PC with another Monitor?
I'm expecting that you still have same problem.
Is your PC making any audible noise, beep sounds?
May be you should have your PC checked
Mar 15, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
My monitor receives power, but doesn't receive signal from my computer. The green light blinks like there is something wrong and there is a faint beeping noise.
1st you separate you monitor from you Computer.
  • Now On your Monitor and check there is Faint beeping noise.
  • If there is no noise and after sometime the monitor light will change in orange colour.
  • It means there is no fault in monitor.
  • And also check Data cable of monitor is it right.
  • It means there is problem with you computer .
  • You Check the VGA Card.
  • I think there is problem with your VGA Card.
Mar 10, 2010 | Acer AL1916W 19" LCD Monitor
No input signal
that is the problem of cpu not a monitor to confirm disconnect signal cable and power on. monitor will show "no signal check signal cable" it means that monitor is ok and fault lies in cpu .then open the cpu and disconnect ram and listen the beep. contineus beep should be heard then ram is faulty replace it. if no beep heard then motherboard is faulty .
Mar 08, 2010 | HP vs17
I turned on my hp dx 2450 pc and the screen said ''no signal input'' why?
Well, make sure the screen is connected to your graphics card (via VGA, HDMI, etc). If it is and there is still no signal, check to see if your computer is making the usual boot noises, beeping, fans turning on, etc. If it turns on normally, it is most likely your graphics card (if you have a separate one) or your motherboard if it has built in graphics.
Good luck, contact me if you need more help.
Dec 29, 2009 | HP Compaq dx2450 Microtower - KR611UTABA ...
Blank display, machine seems to boot ok but display is blank.
If you hear your computer beep once then your system has no problem. If it does'nt show a display, try to check the power of your monitor, if it has power. Check the power cords and also the vga connection.
Nov 10, 2009 | HP Pavilion dv9000 Motherboard
DELL E173FP 17" LCD MONITOR
try to contact dell. Maybe the power supply inside the case is bad. Try without VGA input. It should say dell genious display
Dec 18, 2007 | Dell E173FP 17" LCD Monitor
Acer Aspire™ T180 PC Desktop Logo
1,326 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
