Question about Funai PY90DG DVD Recorder
Funai DRVR-B778 Finalising problems
I have finalised a disc on my Funai video/dvd machine and now all I get are some lilac coloured horizontal bars about an inch wide with the top bar with a narrow box around it and menu written above the box and in the box is written 1 AV2 2H.Please can you help in this matter. Thank you very much........Brian Evans
5 Suggested Answers
SOURCE: Funai drvr-b778s manual
Get it from here.
http://www.funai.de/English/index.php?page=shop.getfile&file_id=42&product_id=6&option=com_virtuemart&Itemid=3&vmcchk=1
Fred
Posted on Apr 03, 2008
SOURCE: Recorded DVD wont play on any other DVD Player
to finalize press setup on remote control, then use the up and down buttons on the remote [white ones in middle] to go to disk edit, it will then say finalize so move the white buttons again to go to finalize ,then push ok button. I can record but it comes up disk error when I try to finalize . Does anyone know what causes that?
Posted on Aug 26, 2008
  • 9 Answers
SOURCE: funai drvr-b778 dvd record problems
try mr dvd-r discs from poundland they seem to work
Posted on Feb 07, 2010
ginko
  • 19396 Answers
SOURCE: How can I record teletex
Hi.
You cannot record teletext subtitle if you record straight from the programmed channel on DVD. For that reason you cannot record teletext subtitles using programmed recording.
To record teletext subtitles you need to set the TV as an external input and record straight from TV input..
In order to do this:
  1. Connect a TV OUTPUT to DVD INPUTusing AV Cables (red-white-yellow) or SCART. ( HDMI may not work).
  2. Turn on TV and start teletext subtitle page.
  3. Set the DVD recorder to the TV input using DVD remote (e.g. L1 or L2- Ex1 or Ex2, AV1 or AV2 and similar depending on DVD model) - T know it is the right input set TV on recorder channel and you will see TV channel with teletext.
  4. Start manually the recording.
The recording done in this way will include teletext, on screen display (e.g. volume bar) or whatever is actually displayed on TV.
Regards.
Ginko
Posted on Sep 03, 2011
Reports "can not repair disc' when finalising.
Hi I used to have a similar problem I changed to TDK Disc's.cheers
Jan 27, 2016 | Televison & Video
Model DMR-ES30VEB. I have had this recorder for a few years now but since I got a new Sony TV at christmas I am having problems recording. When I record a programme the DVD says it does not recognise the...
DVD-RW discs are ideal for temporary video recording and data backup, but they are not recommended for successful finalising, as there is no guarantee that the disc will work in another device.
Have you tried using DVD-R discs? these CAN be recorded in video mode AND finalised for compatible playback in other players. I assume the DMR-ES30V is a DVD/VCR combo unit - if so, the DVD recorder will not recognise RW discs; only DVD-RAM and DVD-R.
DVD-R discs are recommended for video recording and finalising in this model. (later model Panasonic DVD recorders allow RW disc recording).
Mar 26, 2011 | Panasonic DMR-ES30VEBS
Funai VCR/DVD recorder DVR 2737. My -R discs record ok but during finalising I get disc error - cannot record on this disc Error code E22. Can you help?
I was advised to try another make of blank discs. I bought Sony discs & they worked ok. I had been using supermarket own brand.
Oct 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
FINALISING ERROR
I have same problem. Gotten worse with time. Am currently upgrading firmware from www.philips.co.uk which should help
Nov 23, 2008 | Philips Televison & Video
FUNAI drvr b778s
Have you finalised your disc in your dvd? I was having problems with my pc reading discs until I did this ,although some pcs wont take dvd-r discs and will only accept dvd-+r so it could be that.
Jun 18, 2008 | Funai PY90DG DVD Recorder
Will not play on computer
Before you can transfer pictures or video from your Canon DC210 to your PC you need to finalise the disc in the camcorder.
You also need to make sure that the DVD drive on your PC is capable of reading a DVD-R, DVD-R DL or DVD-RW format as these are the only disk formats that the DC210 will handle. Not all PC DVD drives can read these formats.
To finalise the disk you must have the power adapter connected to the camera, plugged into a wall socket and turned on. Then, switch on the camera, put it into playback mode, Press 'Func.', select main menu, select 'disk operations', select 'finalise'. Don't move or shake the camera or switch it off whilst the finalising step is underway - this could cause problems.
Once finalising is complete, put the disk into the PC.
Good Luck.
Mar 25, 2008 | Canon DC210 DVD Camcorder
Cant transfer footage from Canon DC201 onto computer (and eventually internet) Do I need specialist software to take video from DVD to computer?
You don't need specialist software to take video from DVD to computer.
One of two things has gone wrong
1. Your PC cannot read the -R DVD format, or, more likely
2. You have not finalised the disk.
You must finalise the disk in the camcorder before putting it in the PC. To finalise the disk you must have the power adapter connected to the camera, plugged into a wall socket and turned on. Then go to the main menu, select 'disk operations' and you'll see an option to finalise disk. Don't move or shake the camera whilst the finalising step is underway.
Mar 09, 2008 | Canon DC210 DVD Camcorder
Funai drvr-b778 dvd record problems
Jan 11, 2008 | Funai FDRV90E DVD Recorder/VCR
FUNAI drvr-b778
Use a head cleaner to clean the heads on the vcr.
Jan 09, 2008 | Funai PY90VG DVD Player/VCR
Funai PY90DG DVD Recorder Logo
46 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
