Question about WYSE 900986-07 185 Terminal Amber w/o Keyboard
How to connect wyse wy-185 to at&t 577 printer
Trying to connect wy-185 to at&t 577 printer. I need pin-outs for rj11 and db25. Looks like a null modem is needed. WY-185 does not see printer. Printer head docks when wy-185 is powered on or off. So. it looks like the printer is seeing the wy-185.
Dear mm6529, I have an At&t 577 printer, but do not have a manual for it. Any ideas where to get one or could make a copy for me.
blevinsb33@aol.com
Posted on Aug 12, 2010
Kx-td1232
You have to change the usb to a virtual serial port to do it.
Aug 06, 2012 | Panasonic Kx-td1232 Super Hybrid Pbx...
How to connect to the computer?
Devices: Canon CanoScan FB330P/FB630P Color Flatbed Scanners
Check pages 22-23 of this copy of your Canon Canoscan 630P Product Guide.
You'll need an "IBM-type" parallel printer cable - with a DB25 on each end, and your computer will also need to have an "IBM-type" DB-25 parallel printer port.
What the Canon Product Guide fails to mention is that this "IBM-type" printer cable is a kluged Centronics parallel printer cable, but became so popular (on older computers - your laptop may not have this port), that it got an IEEE standard: IEEE 1284 (with DB25 connectors on both ends).
You'll need a DB25-to-DB25 M/F cable, meaning DB25 connectors on both ends, with a Male on one end, and a Female on the other end.
The Male DB25 will plug into the Female DB25 connector on your computer/laptop, with the Female DB25 going to the FB630P Color scanner..
Here are some pictures/pricing:
http://www.computercablestore.com/IEEE_1284_Printer_DB25_to_DB25_catID2134.aspx
The nice thing about the design of the Canon FB630P Color Scanner is that the scanner also has a Female DB25 Printer port for an existing parallel printer, so when you connect an FB330P/FB630P to your system, your existing parallel printer is daisy-chained through this port - so you needn't give up you printer (to scan), nor must you install another parallel printer port onto your PCI-bus tower PC to keep your printer.
Canon Canoscan FB330P/FB630P Color Scanner Product Guide (82 pages):
http://canoncanada.custhelp.com/ci/fattach/get/267/
Most modern printers are USB-attached to laptop systems, so you may need an adapter, an example of which is seen here:
http://www.cablestogo.com/product.asp?cat_id=116&sku=16899
Dec 05, 2011 | Canon CanoScan FB630P Flatbed Scanner
How to crimp 1 end of cat 5e cable with rj11 connector that was cut off. What is pinout order that each wire should in the rj11 connector? the colors are: Black,green,red, yellow & clear. ...
The pinout of the modular camera connections is as follows:
Pin 1 ----------------------- Alarm / In
Pin 2 -------------------- +15Vdc Out
Pin 3 ---------- Intercom Audio Out
Pin 4 ------------------------- Video In
Pin 5 ------------ Intercom Audio In
Pin 6 -------------------------- Ground
Goodluck
Oct 18, 2010 | Cameras
Is't opossible to get complete schematic for an
http://fileshare.eshop.bg/
is the only place I can think of
Jan 15, 2010 | WYSE WY-370 (wy370)
Cable structure
DB25 F DB25 M
(Computer) (Printer)
2 2
3 3
4 4
5 5
6 6
7 7
20 20
DB9 F DB25 M
1 8
2 3
3 2
4 20
5 7
6 6
7 4
8 5
Dec 08, 2009 | Toshiba TEC B-472 Thermal Label Printer
Saving things in the WYSE WY-150
As far as i know the monitor can do very little and internal storage capacity is not big at all.
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 e 240
rcardenas@mrp.to
May 08, 2009 | WYSE WY-150 Network Terminal
Adaptador
First you'll need to make sure your system has a COM (serial) port. Looks for a port on the pC that has 9 pins (5 on top, 4 on bottom). Get a Null modem DB25-DB9 cable and connect the printer to the PC. That'll take care of the hardware connection. Youll need to know what kind of driver you want to use. POS printers like the Samsung SRP printers either has a windows or OPOS driver. You should have a software you intend to use to print to the printer, so check with the software vendor what kind of driver you need to print. Install that driver, make sure the baud rate on the printer and the driver is matched and your good to go.
Apr 10, 2009 | Samsung SRP 270D Matrix Printer
Samsung SCX 4216F which rj11 cable do i need
It needs only two pins - more is OK but not required
Feb 04, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Have epson pos thermal printer with wrong interface
RS232 and Centronics interfaces are incompatible. You need to connect the printer to a SERIAL port not a PARALELL
Oct 06, 2007 | Epson TM T88II Label Printer
WYSE 900986-07 185 Terminal Amber w/o Keyboard Logo
197 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
