Question about Sharp UX B700 Plain Paper Inkjet Fax
Fax will not print after installation of new cartridge
I replaced the old cartridge, which was running out of ink, with a new one. The machine was printing fine before the cartridge was replaced. I did remove the strip from the new cartridge and went through all the steps very carefully (I have done this several times successfully in the past). When the alignment page did not print I tried another new cartridge and this did not work either. The machine makes sounds like it is printing and the paper goes through slowly as if it is printing but there is nothing on the page. Help!! We are missing out on some important faxes that we need to receive. Thank you!!
  • 3 Answers
Look at your NEW print cartridge again, very carefully. I'll bet there's another piece of tape on the bottom of it. That's what happened to me.
Posted on Jan 13, 2009
When fax comes through paper is blank. I've tried 2 different cartridges
Replace the print cartridge
When you notice that the print becomes light or ink low or when install new ink
cartridge appears in the display, replace the print cartridge. The part number for
replacement cartridges is HP 701.
1. Take out a cartridge from its packaging and carefully remove the tape covering the
printhead.
Hold the cartridge by the colored top or black areas only. Do not touch the copper
area.
2. Press the Access Cartridge button on the control panel.
The cartridge carrier moves to the install position.
1 Access Cartridge
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
Care and maintenance 45
3. Open the control panel and cartridge compartment cover (it will click and remain
open).
4. Push the cartridge down and remove it.
5. To load the cartridge insert the cartridge as shown below. When the cartridge is
pushed to the back of the cartridge carrier, push the top of the cartridge until it clicks
into place.
If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this
step.
1 Control panel
2 Cartridge compartment
cover
46 Care and maintenance
Clear jammed documents and paper
6. Close the cartridge compartment cover and control panel.
7. Press Start/Enter.
8. Press 1 for new cartridge, or 2 for the old one.
• When you put in a new cartridge, you must choose 1:New
• When you put in a used cartridge, choose 2:Used. This helps you to check the
correct amount of ink you have left.
TIP: If you mix up several used cartridges, it is not possible to check the correct amount
of remaining ink. Once you have put in a new cartridge, use it until it is completely
exhausted.
Nov 11, 2011 | HP 640 Inkjet Fax Machine
Fax problems
ok..let's start with this step
go here, get a fresh set of drivers, and remove old s/w, then install the new set
Jun 18, 2008 | HP 1010 Plain Paper Inkjet Fax
HOW DO I CHNGE THE CARTIDGE.?
When you notice that the print becomes light or ink low or when install new ink cartridge appears in the display, replace the print cartridge. The part number for replacement cartridges is HP 20.
1. Take out a cartridge from its packaging and carefully remove the tape covering the printhead.
Hold the cartridge by the colored top or black areas only. Do not touch the copper area.
3. Open the control panel and cartridge compartment cover (it will click and remain open).
4. Pull the cartridge toward you and remove it.
3 To load the cartridge insert the cartridge as shown below. When the cartridge is pushed to the back of the cartridge carrier, push the top of the cartridge until it clicks into place.
If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this step.
5. Close the cartridge compartment cover and control panel.
6. Press Start/Enter.
7. Press 1 for new cartridge, or 2 for the old one.
• When you put in a used cartridge, choose 2:Used. This helps you to check the correct amount of ink you have left.
TIP: If you mix up several used cartridges, it is not possible to check the correct amount of remaining ink. Once you have put in a new cartridge, use it until it is completely exhausted.
Dec 22, 2010 | HP 1040 Plain Paper Inkjet Fax
How do you open for ink replacement?
Removing an empty print cartridges Follow the steps below to remove an empty print cartridge:
  1. Press the Access Cartridge button on the control panel. The cartridge carrier moves to the remove/install position. Figure 1: HP Fax 1040/1050 control panelc00253378.gif 1 - Access Cartridge button
  2. Open the control panel and cartridge compartment cover (it will click and remain open). Figure 2: Opening the control panel and the compartment coverc00253379.gif 1 - Control panel 2 - Cartridge compartment cover
  3. Pull the cartridge toward you until it releases from the print cartridge cradle and then remove it. Figure 3: Removing an empty print cartridgec00253380.gif 1 - Pull cartridge towards you 2 - Remove cartridge from print cartridge cradle
Installing a new print cartridge Follow the steps below to install a print cartridge.
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape using the pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. Figure 4: HP 20 print cartridgec00259017.gif
  2. With the cartridge compartment cover open, insert the print cartridge into the print cartridge cradle with the contacts facing into the unit. When the cartridge is seated in the print cartridge cradle, push the top of the cartridge towards the back of the unit until the print cartridge clicks into place. Figure 5: Inserting a new print cartridgec00253382.gif 1 - Insert the print cartridge into the print cartridge cradle 2 - Push the top of the cartridge until it clicks into place NOTE: If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this step.
  3. Close the cartridge compartment cover and control panel.
  4. Press the Start/Enter button.
  5. On the keypad, press 1 if the replacement print cartridge is new or 2 if the replacement print cartridge is old. NOTE: When you put in a new cartridge, you must choose 1: New .When you put in a used cartridge, choose 2: Used . This helps you to check the correct amount of ink you have left.
for more information follow the link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00253364&tmp_task=useCategory&lc=en&dlc=en&cc=ca&lang=en&product=425911
Jun 18, 2010 | HP 1040 Plain Paper Inkjet Fax
How can i install the ink film?
Hello :
If you mean change then :
1: Turn the power off on your fax machine.
2: Open the front or top control panel Make sure not to force the door open.
3:Locate the ink cartridge. Gently pull the cartridge out. Set the cartridge aside.
4:Take the new cartridge out of the package and reserve the packaging. Remove the protective covers over the copper connectors.
5:Insert the new cartridge into the fax machine with the brand label toward you. Now place the old cartridge into the plastic wrapping and box that you reserved from the new cartridge. Recycle the old cartridge or dispose of it in the garbage.
6:Close the fax machine's access panel. Turn the fax machine's power back on.
Warning:
1:Touching the copper connectors on the ink cartridge could damage the cartridge. 2:Make sure that you purchase the correct cartridge for your fax machine. Purchasing the wrong one could damage the cartridge or your fax machine. good luck . please don't forget to rate !
Apr 04, 2010 | Panasonic KX-FHD331 Plain Paper Thermal...
I have a Samsung fax machine, model SF-3100. It is about 9 years old and has always worked very well for me. Now all of a sudden the print quality has got very poor, very quickly. The first I noticed was...
Try cleaning the print heads with rubbing alcohol to remove any dry ink, also clean the rollers too.
If the unit has a reset button or option i suggest you try that.
Good luck.
Aug 06, 2009 | Office Equipment & Supplies
Not Printing?
Buy a GENUINE HP ink cartridge. I think your cartridge is dried up.
Dec 19, 2008 | HP 1040 Plain Paper Inkjet Fax
Check Cartridge Error - Sharp UX-B700 Plain Paper Inkjet Fax
I replaced my new $40 cartridge with another new cartridge and it worked.
Feb 23, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
UX B700
wipe off the contacts on back ink cartridge with a microfiber towel moistened with alcohol also wipe of the printhead (area where ink cartridge contacts the paper) then reinstall and try printing.
Jan 22, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Reprint last fax
JUST OPEN THE TOP COVER PUT IN NEW INK CAARTRIGE THEN FAX WILL RESUME PRINTING FOM MEMORY AS LONG THE POWERS WASNT TURNED OFF
Dec 31, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
Sharp UX B700 Plain Paper Inkjet Fax Logo
125 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
