Question about Black & Decker AV1200 DustBuster Handheld Vacuum
Black & Decker Dustbuster 7.2v
On/off switch does not work. Just stopped..it is charged.
I am in the DC area--any small repair services?
SOURCE: Black & Decker hand held dustbuster
First make sure it's not the wall charger - use a meter or a flashlight bulb to test the 15 or so volts that should be on the contacts when the charger is plugged in but the unit is detached.
The next thing is to remove the filters and see how easily the "fan" spins - use a popsickle stick or something that won't break the plastic fan if you can't get your fingers on it. Tight bearings may indicate clogged with dust (or corrosion) or destroyed. Free bearings likely indicate a switch or battery problem (good motor.)
Posted on Dec 06, 2007
ukvacfan
  • 328 Answers
SOURCE: Charging Black & Decker Dustbuster
Leave it in the charger for at least 7 hours and then try and see if it works on a full performance time of roughly 3 minutes.
Posted on Mar 07, 2009
  • 34 Answers
SOURCE: I need a black and
I have bad news. That part is no longer available; check out the info here:
http://www.ereplacementparts.com/black-and-decker-fve9610-dustbuster-parts-c-4167_8887_8911.html
I actually have exactly this kind of dustbuster, and I was able to renew the battery pack, but I had to do it by using eight individual cells and soldering them together. The size of cell (I think it's called a sub-c) is not common to consumers, but is fairly common to battery pack manufacturers. Quite honestly, your dustbuster with no battery is worthless, even when it was available, the pack was $46.46 as a spare - probably more than the thing is worth. Buy a new one from wal mart! If you really, really want to look at getting a new pack for this one, then your only option is to find a specialist battery store (I know there's one in my city) that can 'remanufacture' them. Basically, they take the old pack, and rip out the old cells, and put in new ones. They have the special equipment to weld the connections without frying the cells too, and they have access to Sub-C cells, of course. It'll be expensive. Good luck, you're gonna need it. Sell it at a garage sale; it looks nice.
Posted on Feb 05, 2011
hmerchant110
  • 7191 Answers
SOURCE: require manual for black &
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Thanks for using FixYa.
Posted on May 06, 2011
HansPP
  • 2510 Answers
SOURCE: our black and decker 14.4
You can test the output of the charger with a multimeter. Set it at about the 20v scale and touch the contacts at point where it connects with the Dustbuster. If you get a reading it means that the charger is working. I would say that the charger is most likely not working because LED indicators very seldom fail while chargers are not all that reliable.
Posted on Jun 09, 2011
Black & decker chva5a0 dustbuster will not hold charge
If less than about 12 months could be the charger, if older than 18 months or so it could be a dud battery
May 02, 2017 | Black & Decker Vacuums
Can I fix model cwv363004 black &decker
Hi-
This dustbuster does not have internal parts still available to replace. This model currently still has the filter, wet deflector and crevice tool available. If you would like to locate a service center for further information you can follow the link to find your nearest service center. blackanddecker com
Thanks
Black + Decker Customer Care
Feb 21, 2015 | Black & Decker 15.6 Volt DustBuster Vacuum
Our black and decker 14.4 Dustbuster is functioning but the charger does not shot its light that will indicate of charging. we dont know if the charger is not working or just the charge light is the one...
Jun 09, 2011 | Black & Decker Vacuums
How long do i have to charge a dustbuster? I purchased one at a garage sale and it does not seem to be working. The owner said that it was working..
if its not working at all it has a fault that could be anywere if it is working but with little suction then the batery is no good replace the battery
Jun 25, 2010 | Black & Decker AV1200 DustBuster Handheld...
Our dustbuster (dont' have model number with me-sorry) won't turn off when I pull back on the switch handle. I disassembled the unit and realize that the tab on the switch handle that pulls back on the...
If you can provide a model number, I can check availability of the switch and can either order it for you, or supply the B&D part number and you can order it from most local vacuum shops in your area or from Black & Decker direct online: http://www.blackanddeckerservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
May 06, 2009 | Black & Decker 15.6 Volt DustBuster Vacuum
Feb 04, 2009 | Black & Decker V9650 DustBuster Handheld...
How do I open the dustbuster to clean out the end
There should be an area to press at the joint between the front section, and the motor section. The whole front cone comes off to empty the contents, and there is a filter - but no bag with these.
Hope this helps you.
Thanks for using Fixya
Dec 26, 2008 | Black & Decker V9650 DustBuster Handheld...
REPLACEMENT FILTERS
I suggest calling customer service.
http://www.blackanddecker.com/CustomerCenter/
Incidentally, the model number you gave is a 3.6 volt vacuum.
Dec 15, 2007 | Black & Decker CWV3630 DustBuster Wet/Dry...
Nov 12, 2007 | Black & Decker CHV1500 Bagless Handheld...
Black & Decker AV1200 DustBuster Handheld Vacuum Logo
116 people viewed this question
Top Black & Decker Vacuums Experts
GG TECHNOLOGIES
Greg Cann
Greg Cann
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
