posted by Helpmefixit on Feb 03, 2007
The counter and light on the Smeg FME24X come on and timer counts down but the oven isn't coming on. A toy screwdriver was inserted in the top hole on right side door opening and fuse tripped. Any solutions?
Comment by Helpmefixit, posted on Feb 03, 2007
.... the turntasble isn't coming on either
1 Other User Has The Same Problem
Comment by Guest, posted on Jul 28, 2008
have had service engineer, who took it away for diagnosis and has phoned to say it needs a new transformer at £192!!!!
it's 6 years old
what to do?
Best Solution
The door switches are almost certainly the culprit - probably the upper one. It may also be a loose mount, or even a loose spring in the hook-like devices on the door which activate the switches.
There is a center monitor switch whose purpose is to blow open the fuse if the door is open and the upper or lower switch gets activated.
That's why the fuse blew when the screwdriver was introduced - you activated the door switch while the monitor switch was on.
I've attached a generic picture which gives you the idea.
More importantly, at my Web site, I have critical safety information, disassembly tips, and infomration on checking and replacing door switches.
You can find these via my link at FixYa here: http://tinyurl.com/yzjozk
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Smeg FME24X 900 Watts Microwave Oven
Email this problem
Email this problem
This Problem Also Relates To:
GE JVM1650 1000 Watts Microwave Oven
GE Advantium 120 900 Watts Convection / Microwave Oven
GE JE2160 1150 Watts Microwave Oven
GE JE1360 Microwave Oven
GE JE1460 1150 Watts Microwave Oven
GE JE1590 1000 Watts Convection / Microwave Oven
GE Advantium SCA2001BSS 950 Watts Microwave Oven
Can you Help with these Microwave Ovens problems?
Repair Service
Find Microwave Oven Repairman Near You:
