Question about Symbol P470-SR1211100FB Handheld
Entering data codes for hand held device
I'm trying to set up hand set to take multiple scans before having to hit enter.
Scanner setting
Got to the following:-
Start >> Settings >> System >> Intermec Settings
You are then presented with all the settings you can change within teh device. From here got to:-
Data Collection >> Internal Scanner >> Symbology Options >> Postable
You are then presented with an input field. Enter your (13) here and hit [OK] to save and exit.
Use notepad on the device to check that the 13 is placed at the end of the {Barcode Date}
I confirmed this on a terminal we have here and it worked 500011972829613
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL +44(0)1202 620955
http://www.biastechnology.com/
Jul 03, 2012 | Intermec CN70 Handheld Mobile Computer...
After scanning a bar code I need it to enter and go to next row in excel
This can be possible, therefore it is not an Excel setting. You would need
to use the software that comes with your bar-code reader to configure this.
Try looking in your bar-code reader documentation for "Append Enter" or
"Append Carriage Return"
May 21, 2011 | Symbol LS 4000i Handheld
I'm using Symbol LS1004 with SirsiDynix Symphony 3.3.1 Workflows. How can I tab over after each scan, without having to hit <Enter>? Thanks, -john
Here is what I did to fix the problem of the bar-code scanner not going to next line after a successful scan. (Symbol ls4000i,This fix should work for other models as well)
1. Get the manual for your scanner or here is a link to the Symbol LS400i
https://docs.symbol.com/manuals/3789802a.pdf
You will want to print off few pages that have the proper bar-codes for programming.
2. I usually start with setting scanner to the Default Parameter, this should be in section 5-7,page 50 of the manual.PRINT IT
Warning! If you set scanner to default, you need to be aware of which bar-code types you use. (We use UPC-A) Also if you have it programed for other things already you may not want to set all settings to default. You can skip to step 4. If you do not wish to reset all values to default.
Now scan the Default bar-code.
3. Now program scanner to Enable your bar-code type. (For us Enable UPC-A bar-code is in section 5-22,page 66. PRINT IT
Now Scan the Enable (your bar-code type UPC-A, UPC-E,etc etc)
4.Next You need to set a Suffix Value. The scan Suffix bar-code is found in section 5-80, page 124. PRINT IT
Now Scan the Scan Suffix bar-code
This prepares the scanner for the code of the whatever Suffix you want to add.
5. The Suffix you want to add to fix this particular problem is ENTER. So that it goes to the next line. There is a prefix/suffix value chart on page 162 table A-4. The code for ENTER Is 7013. In order to enter this code you will need to print off the Numeric Bar Codes found in section 5-109,5-110,pages 153,154. PRINT IT
Now scan in 7013 one number at a time to program ENTER as the suffix.
6.Now you have to program the Scan Data Transmission Format found in section 5-81,5-82, pages 125,126 . PRINT IT
(This lets the scanner know to transmit the Suffix after the data.)
First scan the Scan Options Bar-code.
Second scan the <DATA><SUFFIX> bar-code.
Last scan the ENTER Bar-Code.
YOUR DONE !
Your scanner should be working now. Also look through the manual there are some nice functions that can be turned on and off with a simple bar code scan. Such as volume and tone of beep etc etc.
Hope this helps
Nate N7w7
Apr 06, 2011 | Symbol Spark LS 1004
Trying to connect multiple computers but need wep code . where is it?
Hi Friend,
Please follow the steps in order to retrieve the WEP code from the router.
1. Click Start\ Run\ type cmd and hit enter.
2. In the black window type ipconfig and hit enter.
3. Note down the default gateway and close this window.
4.Open web browser and type the default gateway adn hit enter.
5. If you have not changed the default password of the router then type admin as the password and leave the username blank.
6. In the router setup page click Wireless and then click Wireless Security.
7. You may note down the passphrase and try to connect the wireless devices with this passphrase.
8. in case if there is something written in Key 1, then try this instead of passphrase.
I hope this will resolve the issue.
Regards
Chiranjeet
Dec 10, 2010 | Linksys WRT160N Wireless Router
How do i program it with a IT 3800 hand held scanner ?
At this web link you will find the data sheet as well as several user guides.
be sure the cable you have matches the emulation you wish to user.
contact the vendor or Honeywell for information.
be sure codabar is set to on, min length at lease 3, same code out.
The turbo wedge menus are printed in codabar.
http://www.honeywellaidc.com/Site.aspx/na/en/product_center/product_support/?category=5&product=140
at this web link you can find information on the turbo wedge.
www.compseemfg.com
all menus are covered in the manual ..
to set the terminal ID
scan enter terminal id
scan 2 digits form the options page to set the terminal type .
scan exit terminal selections .
most of the menus run in this same sequence .
for example to set the AUX port on a turbo 1 to RS232
Scan Enter General II
Scan Auxiliary Port selection
Scan a 0 (zero) form the digit colum on the Options page
Scan Exit Gerneral II
Oct 22, 2010 | Compsee TurboWedge (02kt023) Hands Free
When I scan the barcode it coming on the POS system ,but you have to hit enter for it to give details information.
You have to scan the barcodes: Scan Options, Data Suffix, and Enter from the LS9100 Product Reference Guide. This knowledge article contains a link to download a Word document containing those barcodes.
Nov 05, 2009 | Symbol LS9100 Hands Free
Scanner beeps but doesn't enter data into system
Have you scanned the configuration barcodes on the manual? For example if you are using keyboard wedge cable, you will need to scan the keyboard wedge barcode from the manual. Page 20.
http://www.handheld.com/download.aspx?download=/data/ffdefe60-2c7a-423f-a204-ee2450b7c4d9.pdf&filename=IT3800PDF+Linear+Imager+PDF
Apr 02, 2009 | HHP IT3800 Handheld
Symbol P470-SR1211100FB Handheld Logo
136 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
