Question about Philips DVDR 3355 DVD Recorder
Dvdr 3355 How can I unblock this dvd player to play all regions?
  • casbas Dec 08, 2008
    I am having the same problem and the solutions given do not work. What else can I try?
  • dajo572 May 11, 2010
    How do I unlock a Phillips DVP 532K175 dvd player to play all regions?
  • 86 Answers
SOURCE: Changing region on a DVD player
You did not specify what kind of DVD player this is? Since you said player, and not drive, then I will assume this is a dvd player you hook up to your TV, not install in a computer.
Simple answer, you can not change the region code on a DVD player, unless there is a known hack listed on a website.
Therefore, your only option, is get a region free dvd player. They are cheap and easy to get on amazon.
here is one for $30:
http://www.amazon.com/Philips-DVP642-DivX-Certified-Progressive-Scan-Player/dp/B000204SWE/ref=pd_sim_e?ie=UTF8&qid=1196024533&sr=8-9
Posted on Nov 25, 2007
jaffa012001
  • 376 Answers
SOURCE: Change Change Oppo DV-980H DVD player to play DVD's from all regions.
1. Press Setup.
2. Press "9210" in quick succession. A new window should appear.
3. Press "0" to set the Region to R0.
4. Press Setup to exit.
Posted on Aug 12, 2008
jaffa012001
  • 376 Answers
SOURCE: philips dvdr 3320 v DVD Player Unlock region codes
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
  • 7 Answers
SOURCE: Unlocking of region codes for Philips DVP 3260K DVD player
http://www.wisebread.com/make-your-dvd-player-region-free-in-seconds
have a look here and see if it helps
good luck
Posted on Nov 26, 2008
SOURCE: cant play region 1 dvd's on my sony bdp-s350 player
check these guys out; they offer a mod kit to unlock regions 1-6 for the BD 350
www.multiregionupgrades.com
Located in the UK but world-wide shipping available
Posted on Jan 31, 2009
Hi, bought dvd ntsc format from US but can't play at our player. Are you able to assist ? Player type - Philips HTS3011/98
your dvd has regional code..only play dvd from where your purchase it.
you can do some hack.
try this
To convert this player for multi-region playback
This hack should work on all Philips DVD players with any firmware version, and other similar models by manufacturers such as Grundig, Marantz and Yamaha
Please note that if you experience problems with this hack you can obtain firmware version 7.03 and later by visiting the PhilipsSyndicate to obtain files that you can burn to a CD-R and flash your unit to the new version.
1a.
The following uses the machines own remote control:
We have heard reports that hacking some players using the units own remote control incurs a 25 change limit after which it will lock the machine in the last set region
We have heard other reports that hacking some players such as the DVDR-880 using the units own remote control can result in an inoperable unit, we recommend you use the OneForAll remote only and consult our Region Hacks forum for more information
  • Press the Play button on the player
    NB: You may need to press this button on the remote control instead
  • Press the 1 button on the remote control
  • Press the 5 button on the remote control
  • Press the 9 button on the remote control
Although the above may appear to work on many units, showing the correct display as indicated in Step 2, the hack may still not work. In which case you WILL need to use Step 1b instead! 1b.
If the above does not work, you will have to send the infra-red code RC6 (aka Codeset 4, Key 235 in nerd-speak) to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital with the following instructions:
  • Configure your remote using the setup code 0 5 3 9
  • Press the Magic button
  • Enter the code 0 8 5, or if your unit requires a five digit code, enter 0 0 0 8 5
If you own a Palm Pilot, you may also use Pacific Neo-Tek's OmniRemote software to generate the RC6 code using a downloadable .pdb file.
  • Download the .pdb file into your Palm Pilot
  • Press the OmniRemote key marked as 955 Multizone
If you do not own either of the above units, it is possible to construct a cheap DIY solution by following instructions at the following website.
NB: Sending these codes to some players, such as the Philips DVDR-980, requires you to select a DVD player remote on the unit as the default IR device, as opposed to the DVD recorder remote it is factory set to. Please consult your player documentation to find out how to do this.
2. The onscreen display should show 11 spaces like this: '-----------'
NB: The actual display may differ slightly depending on the model of your player, may be shown on the unit itself, or may even not be visible on some models at all.
3. Using the number keys on your DVD player's remote control, enter the code 222 222 005 255. Note that this is 12 digits and the last digit will not show on the on-screen display.
NB: For players such as the Philips DVDR-980, DVDR-985 and DVDR-1000 units, you may need to use the code 121 212 005 255 instead. For players such as the Philips DVDR-880 you may need to use the code 121 212 005 00x instead, where x is the desired region, however this also works on other units including the DVDR-985 for setting a specific region. 4. Press the Play button on your DVD player's remote control 5. The onscreen display should now show the words No Disc 6. Power off your DVD player, wait 10 seconds and then power back on
Aug 24, 2011 | Televison & Video
Remote control power button and stop/play/home dont work
open the remote clean with petrol
or ony from dry cloth
thare was a corben in that key becouse that key are more useable so carben
Feb 19, 2010 | Philips DVDR 3355 DVD Recorder
I had my DVDR 3355 in a box for a few months. I newly installed and I have no AV signal (Blue presentation of PHILIPS System) at the TV.
Try changing your settings on the AV menus on the TV. Also make sure the AV leads are pushed in fully (I know sounds silly but you'd be surprised!)
Aug 13, 2009 | Philips DVDR 3355 DVD Recorder
Code for remote control of philips DVDR 3360D Hard disk / DVD Recorder
Also need to know what is the make and model of the universal remote you are using. Codes vary from one to the next.
If by chance your remote is Philips, the code for Philips DVDR's is one of the following:
0599, 0699, 1211
I have a Philips URC US2-PH5DSS and I use the code 0599 to control my Philips 3355 DVDR.
Apr 15, 2008 | Philips DVDR 3355 DVD Recorder
Blocked
The solution for this problem is on this forum here http://www.fixya.com/support/t353456-dvd_player
Apr 13, 2008 | Philips DVDR 3355 DVD Recorder
Philips dvdr 3320 v DVD Player Unlock region codes
Mar 23, 2008 | Philips Magnavox DVD/VCR Dual Player
Code required please
hello .
try this region codes for the region codes . for philips dvdr 3380.
riz.
Feb 09, 2008 | RCA DRC8295 DVD Recorder/VCR Combo
Dvd player
Just google a bit like
"My brand nad type" region code unlock
You can be surprised - once it was - press 999 on remote :)
Dec 04, 2007 | Televison & Video
Phillips DVD Player / Recorder
Slot under front edge of player will allow you to eject by sliding lever with a small pointed object
Nov 03, 2007 | Philips DVDR 3355 DVD Recorder
Philips DVDR 3355 DVD Recorder Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
