Db500 the protection circuit operates at low volume
  • 1 more comment
  • atv1000 Dec 03, 2008
    this is a samson db500a thanks.
    when the mic is used at any level on the volume control, the same fault happens ie the protection circuit kicks in and then resets
    regards ken
  • atv1000 Dec 04, 2008
    Thanks Dan I will look into the caps with a scope also the zener diodes on the protection circuit.
    regards ken
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, based on your description, an internal electronic failure most likely in the preamp and/or the amplifier stage. this is of course assuming that you have tested and eliminated that the speaker and its wiring maybe at fault. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Dec 04, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    An alternate possibility is that this unit uses a DC amp design where each stages is directly coupled. The front end would have a Darlington pair and/or a differential transistor pair. Any constant input signal such as AC hum would be interpreted as an audio signal upsetting the balance. One way to check if it is internal to the amp/pre-amp is to measure the voltage across the speaker terminal, with no signal input, it should read 0 volts while rotating the volume control. If there is voltage measured, then the DC bias has to be adjusted or there is a problem at the front end/pre-amp. Another possibility is dirty volume control contacts and spikes and glitches are introduced while adjusting, enough to trigger the protection circuitry.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
  • 1,512 Answers
Hi
The fact it only occurs when you put audio through it at any level from the mic would tend to indicate that the output stage of the amplifier is faulty. There may also be a fault with the speaker system that could also produce the same symptoms. The protection circuits work in up to 7 different ways relating to current draw, DC offset, Thermal conditions present, or inaccuracies between input and output from the power amp stages.
Checking the speaker system/cables with an ohms meter will give you a quick test to see if there is a problem there with a short circuit. Try another speaker connected to the amp may also help you to eliminate that end of it.
Otherwise, most probably when audio from the mic is amplified, there is an electronic fault is producing a DC voltage in the output stage,and firing the protection circuit. This problem is often caused by failing solder or cracked/dry solder joints in and about the output stage. This is where I would start to look for problems. Happy to talk to you further about the problem.
regards
robotek
  • 734 Answers
Sound condenser/filter might be faulty due to which it resets at higher volume.....get them repaired
  • 4,234 Answers
If an amp protection circuit kicks in at volume level changes, the problem is usually in the pre-amp stage. What is happening here is that there is DC voltage being presented to the output stage. That is detected by the protection circuitry and is causing the shutdown. Normally, these amps are designed as cap coupled to filter out any lingering or transistional DC from stage to stage. If the coupling cap has shorted or is leaky, this type of symptom can occur.
Any service shop that works on audio gear should be able to trace this problem with a scope and resolve it quickly and cheaply. Expect a parts cost in the $10-$15 range.
Dan
    Master:
  • 763 Answers
Sir, did you try to check your settings of your device?
CHARCOIS
Posted on Dec 03, 2008
  • 19,396 Answers
If the unit goes in protection mode when you lower the volume down test the boards with controls and remote sensor. Let me have more details on the problem.
  • Ginko
    Ginko Dec 03, 2008
    Usually amps fail when you pump up the volume , not when you lower it down.
    When amps fail at a certain point when turnig volume up , that is usually for a shorted speaker wire.
    In your case:
    If this just happened and it is the first time, unplug power cord for ten or twenty minutes, test a different AC socket, in case the one you are using is not well grounded.
    If amp fails at a low volume in general, then it can be any internal problem or faulty component, the board must be taken out and tested.
    If the active speaker fails when you lower down the volume, always at same point, that means that the amp is not stable at that determined ohm level, this because of a faulty component, usually one of the ICs that do the same job of Valves/transistors on the old amps in the amp final.
    If the problem does not goes by leaving the unit unplugged, or using a different socket, the active speaker must be taken apart, and speaker wiring and amp onboard component tested.
  • Ginko
    Ginko Dec 03, 2008
    If the fault only happens when using an external mic, then either the mic is shorted, or there is a fault on the mic wirings, usually the connector wiring.
    Test a different mic first.
My 07 Saturn Relay shows ac off for engine protection but the gauge shows cold. The hoses feel normal. What is happening?
A/C Off For Engine Protection
Refer to Cooling System Description and Operation
DTC P1258: Engine Coolant Overtemperature - Protection Mode Active.
This is something you need to take to a qualified repair shop .
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) or engine control module (ECM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood junction block. The ground path is provided at G100.
During low speed operation, the PCM/ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the cooling fan 1 relay coil, closes the relay contacts, and supplies battery positive voltage from the cool fan 1 maxifuse® through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation, the PCM/ECM supplies the ground path for the cooling fan 1 relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM/ECM supplies a ground path for the cooling fan 2 relay and the cooling fan relay through the high speed cooling fan relay control circuit. This energizes the cooling fan relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the cooling fan 2 relay coil is energized closing the relay contacts and provides battery positive voltage from the cool fan 2 maxifuse® on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Nov 20, 2016 | 2007 Saturn Relay
My stereo sysytem is a mini stereo: serial number 10200055. It currently says "protect", what is this and how do we return our system to normal operations?
When the word PROTECT appears on this display, this means the unit has detected a critical fault which could potentially cause harm to your stereo system.
The most common cause is a short circuit somewhere - something even as simple as loose speaker wiring could cause a short, triggering the Protect message.
You will need to determine if there is a possible short somewhere, so I recommend you start by firstly turning power OFF, disconnecting all speaker wires, then turn unit back ON.
Operate the stereo (without speakers) and turn volume up:
  • If Protect message appears when turning volume up, then stereo unit itself has an internal fault
  • If no Protect message appears, then suspect the speakers may be causing the issue.
  • Reduce volume and turn unit OFF
Re-connect speakers (ensure the connections are secure), turn unit ON:
  • If turning volume up triggers the Protect message again, there is an issue with the speakers or connections
Hope this helps.....
Sep 04, 2011 | Kenwood Audio Players & Recorders
What if went in safety mode, safety mode is froze in screen. Won't do anything
"Safety" mode - literally? I don't see that anywhere in the manual.
Page 13
Speaker Connection Precautions
(North American and Taiwan models) You can connect speakers with an impedance of between 6 and 16 ohms. If you use speakers with a lower impedance, and use the amplifier at high volume levels for a long period of time, the built-in amp protection circuit may be activated.
Page 66
The STANDBY indicator flashes red
The protection circuit has been activated. Remove the power cord from the wall outlet immediately.
Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and set the volume to maximum. If the AV receiver stays on, set the volume to minimum, disconnect the power cord, and reconnect your speakers and input sources. If the AV receiver turns off when you set the volume to maximum, disconnect the power cord, and contact your Onkyo dealer.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Apr 04, 2011 | Onkyo TX-SR608 Receiver
When I turn the volume up past 3 it starts this
I suspect you are going into protect mode which backs the gain way off to prevent over driving.
You MAY be trying to get too much volume out of it. Remember that the value of "3" on the volume means ALMOST nothing as you may have a hotter guitar. Some guitars with internal preamps EASILY overdrive the amps at low settings. Do not use excessive gain at the input.
If the amp is real low volume way below what is needed to play, then there may be a problem with the protection/compressor circuit.
Suggestion: Take your guitar to a music store and compare action on an IDENTICAL amp.
Feb 01, 2010 | Music
My amp goes into protection mode when i turn on my car. It gets hot too. I had 2 kicker 12" l5's and blew the subs with that amp, could i just have a simple problem with the amp? What are all my options?
Protection LED on, no output? Amplifi er is very hot = thermal protection is engaged. Test for proper
impedance at the speaker terminals with a VOM meter (see the diagrams in this manual for minimum
recommended impedance and multiple speaker wiring suggestions). Also check for adequate airfl ow around
the amplifi er. Amplifi er shuts down only while vehicle is running = voltage protection circuitry is engaged.
Voltage to the amplifi er is not within the 10–16 volt operating range. Have the vehicle’s charging and electrical
system inspected. Amplifi er will only play at low volume levels = short circuit protection is engaged. Check
for speaker wires shorted to each other or to the vehicle chassis. Check for damaged speakers or speaker(s)
operating below the minimum recommended impedance.
No or low output? Check the balance control on source unit Check the RCA (or speaker input) and
speaker output connections.
Jan 29, 2010 | Kicker ZX10001 Car Audio Amplifier
Nad C370
Since the problem seems to be sensitive to the volume level, I would be looking at the output wave form for any DC current. Although the protection circuit should detect any DC present, it is possible that some is leaking through. Also, verify that the speaker impedence is correct. If the amp is seeing too low an impedence load, it will work too hard causing excessive heat which will shutdown the unit as well.
Keep me posted.
Dan
Nov 04, 2008 | NAD C370 2-Channel Amplifier
My amp goes into protection mode at high volume
need more info, make and model of amp and subs please
Feb 18, 2008 | Kicker DX350 Car Audio Amplifier
PROTECTION MODE
The unit may be experiencing an overload caused by a short circuit, internally or externally. Try disconnecting all the speakers, then turning up the volume. If nothing happens, connect one speaker at a time and turn up the volume to see if you get more sound. You may have a speaker that has shorted internally and this will help you discover the bad one. However, if when you have all the speakers disconnected, and the unit still goes into protection mode with the volume up, then there is a problem with the unit itself.
Hope this helps, and please rate my advice, good OR bad.
Feb 04, 2008 | Audio Players & Recorders
Vollume trouble
the system protect is usually displayed when a condition of short or shorting is occurring in the speaker wiring or the voice coil of any of your speakers.... thte circuit of you reciever is trying to protect itself and you from a very costly repair,,,so it you have another set of speakers try to use them and see if the condition still exists and if it does the problem is in the output section of the receiver,,,and if the protect no longer exists you have fixed your problem,,,good luck
Apr 07, 2007 | Onkyo TX-8211 Receiver
64 people viewed this question
 Grubhead
Grubhead
