Question about Goodman CLJ30AR32 Air Conditioner
Not enough return air to heating unit
I had a HVAC maintanence person do a routin service last night. He said that my downstairs furnace didn't have enough return air coming into it. I have a Trane unit for a house that is about 1,400 square feet (downstairs). The return is one 20 x 20 return (filter size). There is a seperate unit upstairs that is a little smaller but has 2 returns (one 20 inch and one 14 inch).
The person said that I need at least 1,000 CFM's but I am only getting 700 CFM's. He is suggesting that they put in another return to help ease the load of the downstairs unit. The cost of a new return grate and duct is about $1,000. He said that the current unit will not last long the way it is.
Do you think I need a few duct system installed?
Thansk very much for your advice!
  • 2 more comments
  • msteffens Dec 04, 2008
    The unit is a 2.5 ton heater and is located in the crawl space under the first floor.
    Thanks very much. I will look into that suggestion.
  • dwkcool May 11, 2010
    if your return is the wall you can enlarge the one you have now by reframing the 20 by 20 to a 20 by 25 and that will help
    wHERE IS THE DOWN STAIRS UNIT AT
  • 56 Answers
Right now you are at bare minimun for what your unit requires. If you are not having any problems with the unit or have not had any I would not worry about it. You need to check and make sure that your duct size on the unit is not smaller than 14" in diameter. If it is 14" or bigger you are fine.
Posted on Feb 14, 2009
No heat or air
HVAC Troubleshooting: No Heat - YouTube
? 6:39
https://www.youtube.com/watch?v=YSPvCYmROvo
Dec 23, 2011 - Uploaded by talyn875
I show my method of diagnosing a no heat symptom in a heat pump. ..... Wiring and troubleshooting Thermostat - heat cold aircondition AC ...
BEFORE YOU CALL FOR SERVICE: My furnace heater / ac ...
? 9:34
www.youtube.com/watch?v=rgOnfG62aBM
Jan 13, 2013 - Uploaded by CalQwax
BEFORE YOU CALL FOR SERVICE: My furnace heater / ac unit doesn't ... heating blowing hot air please help me there is no heatin my house ...
Nov 01, 2015 | Heating & Cooling
Amana Furnace
The furnace may have a cracked heat exchanger.
Dec 19, 2013 | Heating & Cooling
Not enough, hardly any air flow coming thru forced hot air/central air system. Forced air has hard steel round 4" tubing to all rooms. Just recently bought a small ranch with 1000 sq ft that has a...
You have a mess, You need a complete new duct system and new equipment.......
You have a 2 1/2 ton AC which needs 1000 cfm of air to do the job. You need a supply trunk line 8 by 24 inch with takeoffs of a Min of 6" round pipe to each register which will delvery 100 cfm per run 4" will only delivery about 30 cfm per run.... and then you also need a 10 by 24 return Duct to the furnace ....
So that is why the heat exchanger burned up and the that is why the Compressor is noisy because you was flooding back liquid to the compressor... All because of air flow....
If you replace the AC or Furnace without replacing the Ductwork you will burn them up also....
Sorry for being so Frank......
Jun 09, 2011 | Heating & Cooling
I recently had a ducted gas heating unit undergo a routine service. At the same time, the technician identified an external gas leak. The gas leak was subsequently fixed by another technician who noted...
The tech that fixed the gas leak had to shut the main gas supply off so if he didn't bled the line to the furnace you may still have air in the line....... Go ahead and shut the furnace off and retry to start it again it takes a couple of trys to bled the air out through the pilot.... And if that doesn't work I would call the first tech and have him recheck it......that is assuming that you have an electronic ignition type furnace.
Apr 19, 2011 | Heating & Cooling
My wife and I just purchased a home built in 1900. It has two separate HVAC systems, with a package unit downstairs, and a traditional compressor/furnace combo in the upper. Most of the windows are in need...
With that large of an opening I would inspect the blower and as much inside the unit as I could get to as there is no telling what might have gotten in there and is obstructing air flow. I would remove squirrel cage and blowere motor and clean thourghly,clean burners and exhaust as best you can.
In thirty years in hvac and plumbing you wouldn't believe some of the things i've found in furnaces and ductwork. Cleaning and serviceing the blower motor should help.
Best of luck to you and your wife and hope this helps you. Thanks
Jan 06, 2011 | Heating & Cooling
I have a direct vent hi efficiency furnace. All
Check the condensate pump if it is full of water and does not come on that will shut the unit down. And might need a new pump. high efficiency furnaces condensate to squeeze the last amount of heat out of the unit. Seen this problem before. But not being there is a little chance that, that is the problem. let me know and we can go from there. okay ken
Jan 03, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heat will not come on.
No heat troubleshooting
Diagnostic: Set SYSTEM Switch to HEAT and raise the setpoint above room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation listed above. If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a HVAC service
person to verify the heating is operating correctly.
If you need further support call the techline 18002842925.
Nov 16, 2009 | Honeywell Electronic Programmable...
Day / Night HVAC is running cool air BUT the furnace is running 2
Strange. Does the thermostat control both the air conditioning units and the furnace. If not make sure the furnace thermostat is turned down to below 65 degrees.
Jun 29, 2009 | Honeywell Programmable Thermostat Heater
Heating blowing coo air downstairs and warm upstairs?
Some of this depends on where the air handler/furnace is located. Most often in two story houses, it's in the attic upstairs, or in a closet upstairs. A duct routes air from the furnace to the downstairs supply duct, so it is a distance from the air handler.
When the unit first initiates a heating cycle, that duct is going to be full of cool air, and the duct itself will be cool. So the furnace has to run long enough to push the cool air out, as well as warm the duct up, before your going to feel warm air at the registers downstairs.
Keep in mind, heat rises. And, your thermostat only monitors the immediate area where it's located. In your case, upstairs.
Two story houses are problematic because of this. And one way around it is to have a damper system installed that distributes the air upstairs or downstairs based on a thermostat located in those spaces. There would be 2 dampers, and 2 thermostats (one upstairs, one downstairs). Each stat would control a damper, and the call for heat or cooling.
Let me know if you would like to consider a system like this, and I can point you to components to use. I've put several system like this in.
Jan 26, 2009 | Kitchen Appliances - Others
Goodman CLJ30AR32 Air Conditioner Logo
397 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
