Question about MSI PM8M-V Motherboard
I am getting 1 long beep and then 6 short ones
I am using a KVM switch when both pc's are on they both work, when I shut one down the other one start beeping very fast, so when I restart it, that is when I hear one long beep and 6 short ones. I also hooked up the PC with out the KVM switch thinking I had a bad KVM and the pc still boots up with the same error. I am getting a check sum error so the option is to hit the F2 to load defaults, not sure if the Mother board is bad or what. It is a MSI
    President:
  • 2,351 Answers
Hi canturob,
When a system reports a check sum error the bios is telling you the information stored from the last working boot does not match the current settings stored in the bios. Please power down your MSI system, unplug the power cord. Open the case & clear the bios. Location of JBAT1 on page 3 in manual.
Clear CMOS Jumper: JBAT1 page 10 in the manual. Remove the battery/cmos. Check it's voltage with a volt meter. It should test to 3volts DC. Anything less & the battery needs to be replaced.
While in the case re-check all data cables & power cables for good connection.
The MSI board uses the Award bios. Your current beep code of 1 long & six short is not a common beep code for the Award bios. See bios beep codes here: http://www.bioscentral.com/beepcodes/awardbeep.htm
If the battery checks out ok, you may need to update the bios. Go to MSI: http://global.msi.com.tw/index.php?func=downloaddetail&type=utility&maincat_no=1&prod_no=205
To update your MSI bios (Option only if bios clear fails to resolves the check sum issue).
Good luck canturob!
Mike
Posted on Dec 03, 2008
Computer beeping and won't start up
Dear,
There is a full code list that relates with the problems. You can justify yourself that which type of beeps, you are facing. I am going to write down the codes for you.
1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed
Hope, now it will be quite easy for your do check and troubleshoot the issue.
best of luck, ask further if required.
Mar 08, 2012 | Computers & Internet
My compaq presario sr1000 computor won't stop beeping from the inside and it says no signal on the monitor
1 short beep and 1 long beep means its a memory problem.
Shut down your computer, then open your computer case and replace the memory module.If you have 2 or more modules ,try starting the pc with one.If it fails, try a different single module.
2 short beeps and 1 long beep repeating for 5 times means its a graphics card issue.
Shut down your computer, then open your computer case and unplug the graphics card, then plug it again.If this doesn't help, try with a different(confirmed working) graphics card.
Mar 13, 2011 | Computers & Internet
My computers seem to have become somehow linked by the KVM switch
The GCS632U is just one KVM switch. But if you're going to check it out, it has actually two separate connections.
It will just switch once you toggle from one computer to another.
Try to power cycle the KVM switch.
1. Shut off both computers.
2. Disconnect the KVM switch from the computers. (make sure that not even a single cable is connected to the computer, even the audio).
3. Leave it disconnected for 10 minutes.
4. Reconnect the KVM and boot up the XP first.
5. Boot up the Vista, try to toggle from one computer to another.
6. LASTLY, shut off the Vista and see if same problem will occur.
If you get the same problem, then you need to contact IOGEAR and have them RMA the device. Because this is the first time that I heard of this problem.
Thank you and good luck!
Jan 25, 2010 | IOGear GCS632U 2-port KVM Switch
Iam using lennovo y410 series.my lapton suddenly making some beep sound continuously on running and its not getting turned off. i removed battery and shutted down,i have been running laptop continuously ...
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Feb 22, 2009 | Lenovo 3000 Y410 Notebook
When powering up I get 2 short beeps and one long one.
The beep code is signifying either improperly seated/ bad ram or improperly seated/ bad video card. Since you replaced the RAM I would say it would be a bad video card. Replace & reboot. Hope this helps & please remember to rate my answer. Thanks.
Jan 22, 2009 | Toshiba Tecra S1 Notebook
Upgraded RAM in D51C, from 256 to 2GB, got 1 short beep, 2 long
Remove all the memory, start up, it will beep. shut down, place in one memory and try starting up. IF it still beeps count the beeps short and long and let me know.
Thank you
iWillFixIT!!
Nov 15, 2008 | Compaq Evo D500 PC Desktop
Cannot switch between PC's
That unit mention above is a Mountable Dual Output VGA to UXGA Distribution Amplifier with Audio not a KVM Switch.
Apr 07, 2008 | Extron Electronics Extron P/2 DA2 MT...
Kvm switch won't stay on second computer, switches back
You might try disabling any power saving schemes in use on either computer. The KVM (I believe) gets its power through the ports and one computer may be shutting down power.
Aug 31, 2007 | Belkin F1DL102P 2-port KVM Switch
Typically, the KVM indicator light will only light up on the connection that is currently active. The indicator light will switch to another connection when that connection becomes active. First I would make sure that all the mouse and keyboard connections are secure. I have seen where these sometimes pop out, and thus some componenty will not work. I would then make sure that all the computers are fully powered on. The KVM will not allow you to switch to a device if it is not powered on. The KVM may indicate that a connection is down by a blinking light if you switch to a port and the connection is not up. It sounds that you have atleast one good set of cables. I would confirm that the other sets of cables are good as well. Do this by swapping the other cables with the one port that you know you have working. Finally, with a set of good working cables, swap them over to the other ports on the KVM switch. Although it may be improbable, you may have a bad KVM. AS always, I would review the product manual here: http://web.belkin.com/support/download/files/P74711ea_F1DJ10x_man.pdf And, since this is a new product, you will also be entitled to free tech support from Belkin: http://web.belkin.com/support/phonenumbers.asp?pge=bro 1-800-2BELKIN x2263
Sep 03, 2006 | Belkin (F1DJ104P-B) 4-port KVM Switch
MSI PM8M-V Motherboard Logo
819 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
