SOURCE: I need a belt routing diagram for a John Deere
If you go to this page http://manuals.deere.com/cceomview/OMGX21647_K3/Output/Index.html?tM=HO , scroll down the left side to the heading for your deck.
SOURCE: lawn mower belt diagram
try www.johndeere.com apply for user id and password
will need to wait for these to be issued to you via e-mail
then go to www.jdparts.com and enter your user id and pw and enter the correct site for your country and then enter model stx38
scroll through list to find deck or attachments and double click it
your deck could be a yellow or black deck
cheers
SOURCE: i need a belt diagram for a lt166 john deere mower
From the JD site, you can get the drive and deck belt diagrams here:
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
***Don't forget to VOTE for the guys who take an interest in helping!
Testimonial: "i think this will help my husband immensely"
SOURCE: electric pto will not engage
had a similar problem. The engine mount bolt that grounded the PTO black ground wire was loose- causing the pto to work erratically. To see this bolt (13mm i think) you will have to lie on your back and look under the machine. It is above the front steering arm of the right tire. If the wire is dangling you will need a new bolt. Thanks for the previous posts ;)
SOURCE: john deere stx 38 with black deck, will not do
I see this problem not as an electrical but a seize problem. Since I can't be there to inspect I am relying on your discription of the problem. I would go first to the place of the problem. If this solenoid goes up to disengage and down to engage ,or the opposite, this is most likely your problem area. It may be seized in the disengaged position therefore not allowing the blades to get spinning. Disconnect the belt and try to turn unit by hand, if tight or completely stuck use penetrating oil on pulley shaft.If shaft loosens up and blades engage this was the problem. Is there a grease fitting anywhere in the area?I hope this at least gets you started in the right direction. GOOD LUCK.
