Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
REMOTE CONTROLS WILL NOT WORK-WALL BUTTON FLASHING RAPIDLY
I have a Liftmaster 1/2 HP Professional Line chain drive operator I am having a problem with. Mod. 41A4252-7 5/93 K1027 FCC HBW 0777. The two button remote controls will not operate this one door. The wall button operates the door just fine. The remotes will operate the second operator. The door bell style wall push button is flashing rapidly and the remote controls will not operate the door. Both sensor eyes have green lights. I have powered it down for 5 min. and cleaned and aligned the sensor eyes but that did not help. Any advice you could offer would be MUCH appreciated. Thanks!
  • 2 more comments
  • ramonruiz_s Dec 04, 2008
    The remote controls were working well till the light of the remote on the wall started flashing
  • ronaldjamesh Dec 06, 2008
    My operators only have the door bell style buttons. No lock button. Does anyone have an idea how to turn off the lock feature using this type of button? I tried holding the button down for a few seconds and that did not work. I also powered down the operator with no luck either.
    Thanks!
  •  Dan Spurlock
    Dan Spurlock Feb 28, 2014
    Follow the steps to reprogram your remotes. The rapid flashing means they have lost connection. Here is a closeup of the instructions... (My opener is Chaimberlain, model numbers are identical)
  •  Dan Spurlock
    Close up imgage showing program instructions... http://i1.ytimg.com/vi/7USIB7QaMwI/maxre...
Does your wall switch have a lock feature? By pressing the lock button, the remote control is disabled. A flashing light indicates this feature has been activated.
To deactivate, press and hold the lock button for 2 seconds. The flashing should stop and your remote should work again.
Posted on Dec 05, 2008
  • Rob Feller
    Rob Feller Nov 22, 2016
    Same problem, older opener, all I have on wall is a switch, kinda like a doorbell
    New Friend:
I followed to procedure to program the remote with button on back of opener. Fixed my problem. Remote works, button no longer flashes,
Posted on Mar 07, 2013
Door operates properly with wall switch. will not respond to remote control. have replaced battery and tried to reprogram the control box with the remote as described on the unit. Lighted wall switch...
Sounds as if you have inadvertently turned on the vacation lock. If you have a lock button hold down for two seconds to turn off. Then your remote should start working again. May need re-programmed if you left the battery out for more than a minute or two.
Aug 15, 2011 | liftmaster Chamberlain Garage Door Opener...
I have a Merlin Powerlift model 430R roller door. The battery went flat in the remote and I replaced it. Now the door will not work via the remote.Works ok from red button on unit. I have tried to reset...
If the LED is flashing rapidly when the button on the remote is not pressed you have interference from something. Check for old remotes stored in a drawer somewhere or some new electric item nearby. Start unplugging things until that rapid flashing stops.
Apr 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster 1250LM won't operate with the remote (or my travel link in the other car) while the unit light is lit. So when I open the door from the remote and back out I have to wait two minutes for the...
On the end of your opener where the small gray antenna is you will find an LED that flashes rapidly when you use your remote. When you release your remote it should stop flashing rapidly and just occasionally flash. See if this continues to flash rapidly while the bulb is on and your remotes are inoperative. If it does, remove the bulb and do the same thing. I have a feeling your light bulb is radiating.
May 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Professional series, lift master 1/3 hp, the remotes will not operate door but door will operate from wall pad
Check to see if the small light in the wall pad is blinking. If so press and hold the button with the lock icon for 3 seconds.
If this isn't the case your receiver may have failed. The wall button works without the receiver;
I would remove the logic board and look for loose or missing traces on the printed circuit board.
Nov 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/3 HP. Remote and wireless keypad stopped working.
Sounds like the reciever for you wireless devices is not working?
Aug 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Hi I have 1/3 hp liftmaster garage door opener that will not open from the remotes but will open with button on wall. I think it is a reciever problem?? any suggestions?/
reset your remotes and your main transmitter after removing and replacing the remote batteries (these use rolling codes that change each time you operate the door) the procedure for doing this is listed on the liftmaster website
Apr 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,455 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
