Question about KitchenAid KSRS25IL Side by Side Refrigerator
  • 7 Answers
Spray door seals with furniture polish
Posted on Dec 03, 2008
Reading on door OF
Teresa, The fridge is in a retailers demo mode and here is what you do to reset it to normal operation:
Left Door: Simultaneously press and hold the top two buttons on the left side of the display panel until you hear a distinctively different chime sound when the display changes. This will either be a combination of "Energy Saver" and "Freezer", or "Energy Saver" and "Power Freeze/Freezer."
  • At the top of the door frame: Simultaneously press and hold the "Power Freeze" and "Freezer" buttons until you hear a distinctively different chime sound and the temperatures for the fridge and freezer are both displayed.
  • Note: If the temperature is displayed, but then "OF OF" reappears a few seconds later, Cooling Off mode was not disabled. Repeat the actions above, and be sure to press and hold the buttons at the exact same time until the distinctive chime sound is heard and both temperatures are displayed.
Apr 11, 2014 | Samsung RF265AA Bottom Freezer French Door...
Good Morning Jill,
I see that you are trying to remove the doors on your Frigidaire refrigerator, model# FRS23R4A, for shipping purposes. Below are the instructions you will need to follow for both the refrigerator and freezer doors.
If it is necessary to move the refrigerator through narrow doorways, follow these steps to remove the doors.
IMPORTANT: Before you begin, turn your freezer and fresh food controls to "O" and remove electrical power cord from the wall outlet. Remove any food from the door shelves.
1. Disconnect electrical supply.
2. Open both doors, then remove toe grille.
3. Close doors.
To Remove Refrigerator Door:
1. Remove top hinge cover screw on refrigerator door and remove cover.
2. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
3. Remove top hinge and lift refrigerator door off bottom hinge pin. Set door aside.
4. Remove bottom hinge, if necessary.
5. Reverse this procedure to reinstall refrigerator door.
To Remove Freezer Door:
1. Disconnect water line coming from lower hinge of freezer door at connection located under front of freezer: Press outer ring against face of fitting, then pull to remove tube.
2. Remove top hinge cover screw on freezer door and remove cover.
3. Disconnect wiring harness connector plug at top hinge: place your thumbs on flat sides of each connector and bend both parts back and forth, then with firm grasp, pull both pieces apart.
4. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
5. Remove top hinge, allowing wiring harness to pull through hinge and lift freezer door off of bottom hinge pin. Lay door down flat to avoid kinking water line.
6. Remove bottom hinge, if necessary.
7. Reverse this procedure to reinstall freezer door.
When both doors have been reinstalled, connect water line by inserting tube and push until mark touches face of fitting, replace toe grille and plug in electrical power cord. Turn both temperature controls to center position. Adjust settings as necessary. Hope this is helpful.
-Best Regards-
Mar 14, 2014 | Frigidaire FRS23R4A Side by Side...
Frigidaire icemaker not despensing ice
Hello jgamewell - Sounds like the dispenser could possibly have a broken or frozen door dispenser sealed. Contact a professional to move forward accurately to properly repair/reinstall part.
Jan 03, 2013 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
Door and handle problems. Smeg fa311x
sounds like your door is sprung. take door off and lay flat on a table outside of the door down. loosen screws on door liner . screws are hidden under door seal. when all loose not removed make sure door is flat on table. tighten the screws being careful not to move door. reinstall door and it should be ok. this is usually cause be either someone leaning or hanging on the door when it is open. or putting to heavy of items in the door trays.
May 26, 2012 | Smeg FA311X Top Freezer Refrigerator
When we close the refrigerator door (side-by-side unit) the freezer door pops open slightly. The unit is about 14 months old and the seals look fine.
There is something not fully in place holding the door from closing completely. It doesn't take much. You should be able to feel slight resistance when opening if it is seated properly. The cavities are connected so when you close the door fast the air pressure moves from one to the other and pops the door open.
Oct 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Bottom freezer popping open on its own
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Sep 21, 2009 | Refrigerators
Door makes poping sound when opened
Thanks for using FixYa. Please check the lower door hinge and the door gasket. There is a small hex screw that prevents the plastic hinge support from moving and while moving it makes a popping sound if it is loose. To resolve the issue you just need to tight it.
Please do rate the solution and revert for further assistance.
Aug 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator won't fit thru door.
I ran into the same problem when I moved into my old house. the door way was to small, so I had to take both doors off the refrigerator to get it through the doorway. But I found out when I moved out of the house, that I was able to open both doors and wiggle it through the doorway. It was a hassle but it was alot easier that removing the doors. Good luck.
Apr 04, 2009 | Whirlpool ED2FHGX Side by Side...
Refrigeraor door "thunks!"
that s what sounds like, either it cracked upon removal/reinstall. or perhaps it justneed to be tightened. its a seperate "cam lifter and riser" that gives yo the self closing action. strictly an annoyance however, no fearof door falling off
Mar 08, 2009 | Frigidaire FRS23R4A Side by Side...
Right Door is making loud popping noise
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Sep 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
KitchenAid KSRS25IL Side by Side Refrigerator Logo
100 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
