Question about Electrical Supplies
I am trying to design a panel for a 75 ft yacht and was trying to copy a drawing of the 4207 on your web sight but the tech spects said it was the right panel a dc with mains and 36 branch but the picture that i was trying to print out was that of an 120v ac panes a 4307 HELP
  • Allen Neal
    Allen Neal May 11, 2010
    i have a friend that does tour buses i will try to find his e-mail would be the same as the panel your trying to design
    Problem Solver:
  • 5 Answers
Most likely becase you might have been coping the grounded ckt. You need the ungrounged ckt. Boats and ships work on Non-grounded systems, the hual is the ground. Hope that might clarify. seth
Posted on Mar 17, 2009
I need torque spects for a 98 4.0 jeep on rods and mains.
  1. Tighten all main bearing bolts to 108 Nm (80 ft. lbs.) torque.
  2. Install the main bearing cap brace. Tighten nuts to 47 Nm (35 ft. lbs.) .
Connecting Rod Nuts 33 ft.lb
Dec 06, 2010 | 1998 Jeep Grand Cherokee
I need to know he torque spects for the oil filter container the bolts on to the moter on a 94 BMW 318i...there are 6 bolts...I also need to know the torque spects on the alternator mounting bracket...
OIL PAN OR TRANSMISSION PAN BOLTS TORQUE ABOUT 7 FT LBS. CAN GET SPECS ON BOLTS SIZES. IF BOLTS SIZES IS 13M I4M 15 M TORQUE BOLTS ABOUT 55 TO 80 FT LBS
Nov 11, 2010 | 1994 BMW 3 Series
Need bolt torqe specs , rods, mains, oil pump & oil pan for 6.0 vortec engine thanks
Connecting Rods: First pass 15 lb ft. If you have an early first design final pass 60 degrees. Second design 75 degrees.
Main Crank Bolts: Inner bolts first pass 15 lb ft. A final pass additional 80 degrees. Tighten the outer bolts/studs 15 lb ft. Final pass 53 degrees.
Tighten the side cap bolts to 18 lb ft. Tighten the bolt on ones side of the bearing and then tighten the bolt on the opposite side of the same bearing cap.
Oil Pump Bolts: 18 lb ft.
Oil Pump Screen Nut: 18 lb ft
Oil Pump Screen Bolt: 106 lb in
Oil Level Indicator Tube Bolt: 18 lb ft
Oil Level Sensor: 115 lb in
Oil Pan Drain Plug: 18 lb ft
Oil Pan Bolt: 18 lb ft
Oil Pan (to front cover): 18 lb ft
Oil Pan (to rear cover): 106 lb in
Oil Pan Skid Plate Bolt: 15 lb ft
If you need more specs contact: melissapowers75@gmail.com
Feb 02, 2010 | Chevrolet C2500 Cars & Trucks
Torque spects on valve cover gasket
4 cylinder engines 17 ft/lbs
V6 engines 69 in/lbs or 5.75 ft/lbs
Sep 12, 2009 | 1994 Toyota Camry
Hi, I neeed to know what the torque pattern is for
If your installing a new head gasget, the torque spects and pattern will come with it. If not and you are installing a new head gasget you have to use new head bolts, the short bolts witch go in next to exhaust manafold are 43 ft. lbs. and the longer ones in the center of the head are 46 ft. lbs. start with the one in the middle by exhaust and next one in center of head next to it and do the rest in a circle pattern, after you got them all torque than you have to turn each one 1/4 turn, thats why you have to use new bolts that 1/4 turn stretches the bolts. If you don't understand this go to auto zones web sight thats where i found it. I just did one 2 weeks ago.
Aug 15, 2009 | 1999 Chevrolet S-10 Pickup
Electrical Supplies Logo
67 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
