Question about Toshiba e-Studio 232 Black and White Copier
REBOOTING MY TOSHIBA E STUDIO 202L
MESSAGE SAYS TO REBOOT MACHINE. HOW DO I DO THIS?
  • 77 Answers
Remove the hard drive,turn on the copier,then turn it off and reinstall the hard drive. that should do it.
Posted on Dec 04, 2008
  • Scott Yeoman Jan 04, 2009
    easiest way is to unplug the hard drive or sub board,turn copier on for 15 secounds , turn off reconnect,turn back on. If you have the same prob. you have a board or hard drive prob.
What is error c440 of toshiba photocopier
Toshiba e-studio Error code c440 is just problem with Fuser Unit after warm up time . 200L/ 202L/ 230/ 232/ 280/ 282/ 283/ 233
PROBLEM:
Fuser unit problem,
SOLUTION:
Try to reset it:
1. Hold down "0" and "8" keys while turn on the power.
2. Enter 400 press Start.
3. Enter 0 press Set or Enter.
Hope this helps
you can find more info at this link
Apr 28, 2014 | Toshiba E-studio 352 Digital...
Is there a setting for the sleep timer? E studio 202L
you can make your machine sleep by press 0+8 with switch-on then press press 205 start from 1 to15 as you wish
Sep 10, 2012 | Toshiba e-Studio 202L Copier
Error e030 copier toshiba 202L
E030 indicates Paper remaining inside the equipment at power-ON.
If no paper is found, probably the actuator/sensor is faulty. Kindly perform input test on following sensors:
Exit sensor 03-[FAX]ON/[2]/[B
Registration sensor 03-[FAX]ON/[2]/[A]
Upper drawer feed sensor 03-[FAX]OFF/[6]/[E]
Aug 28, 2012 | Toshiba e-Studio 202L Copier
Where we can buy toshiba studio 230 developer?
677864645f7a396c54674d71464b78424b4677-100x100-0-0.jpg Toshiba E-STUDIO 163 202l Developer Black
New Genuine Original D2320 TOSHIBA E-STUDIO 163 202L DEVELOPER BLACK Each $88.21ExtraMileToner
at
GenuineBrandSupplies.com
New Genuine Original D-2320 TOSHIBA E-STUDIO 163 202L DEVELOPER BLACK Each $65.33
Oct 21, 2011 | Toshiba e-Studio163 Copier
I have a Toshiba estudio 202L copier. It has been working fine. When I turn it on, I hear it turning on like usual and see the light come on under the paper tray, there are no error messages, display...
try formatting the HDD (make sure you backup templates and address book if you use them.) To format HDD hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again. Wait for it to say please reboot the machine, turn it off and back on. Hopefully this will work but if not, your HDD will need replacing.
Jun 14, 2011 | Toshiba e-Studio 202L Copier
I replaced the drum and wiper blade and I need to clear the maintenance reminder on Toshiba eStudio 202L. I cant find the procedure in the service manual. Do you know which code will reset the...
switch off machine hold down 6 and print key switch on when the machine is on enter 2 and reset you counters switch off and wait 30 seconds and switch on again
Feb 11, 2011 | Toshiba e-Studio 202L Copier
I dont have the admin password toshiba e-studio 202L
202L HOW TO RESET ADMIN PASSWORD IS HOLD 08
TURN ON MACHINE YOU WILL BE IN TEST MODE THEN
PRESS 263 CLEAR OLD PASSWORD AND ENTER DEFAULT PASSWORD 123456. ENTER TUNRM OFF MACHINE THEN ON.
Jan 05, 2010 | Toshiba Office Equipment & Supplies
I can not access my toshiba estudio 202L copier from my vista pc but works fine from xp pc
Vista is notorious for not being "user friendly" printer drivers. Search the toshiba website for downloadable vista drivers. Try pcl 5 or pcl 6 drivers. also try the auto search feature of vista to search out the best driver. Good Luck
Oct 16, 2009 | Toshiba e-Studio 202L Copier
Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Jun 23, 2009 | Toshiba e-Studio 202L Copier
Failed to send email on a toshiba 202l
Check the Admin settings from the web portal.
If you moved the machine from one router to a another for example, the machine may still have the old configuration, or make sure that the email account that the machine uses to send emails from is setup properly, i.e. correct username and password and SMTP for email provider. Mine was such a hassle to setup, and it was because we did a firmware upgrade on the router and had to factory reset the toshiba afterwards and connect via dynamic connection. It was troublesome since all the settings matched and were correct, but something in it, held the config some where. Another site said to flash the Toshibas firmware, but i never found a good download, so the reset was my best choice.
Mar 12, 2009 | Toshiba e-Studio 202L Copier
Toshiba e-Studio 232 Black and White Copier Logo
467 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
