Question about Hitachi Televison & Video
My television won't turn on anymore
There isn't any obvious reason as to why it won't turn on , the standby light comes on , it won't recognize remotes either even w/ the correct code. How can i fix this problem ?
Sanyo TV turns on and works but standby light not working
Do you mean that the standby LED does not light up; but the set works fine? Of so, either the standby LED is damaged, or it do not get voltage [due to loose soldering or some other reason]. Anyway, the set works fine. Isn't it. It means that there is no other fault than this. Contact any service technician in this case; to find out the reason. Electro help
Dec 05, 2014 | Sanyo Televison & Video
Television will not come on
A lot depends on what the brand and model number are here, the set is coming from standby to on and then back off, different reasons for different brands and models.
Dec 02, 2012 | Televison & Video
Sony HCD LX20i audio shelf sysyem won't turn on. Standby light flashing. Disc stuck in it.
Check the speaker wires for shorts, if okay! suspect the audio output ic's, the protection circuit won't come out of standby because there is a short.
May 06, 2012 | Audio Players & Recorders
LG 42LK45OU won't turn on
Do you get the power/standby light to come on?
Mar 17, 2012 | LG Televison & Video
My hot point dryer won't start. the turn knob isn't clicking anymore and won't wind up.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 09, 2011 | Hotpoint Dryers
Standby light flashes and TV won't turn on. Have to unplug it and wait for a bit then plug it back in and TV turns on. Quite a delay though. Then after TV is turned off, standby light starts...
seems like a power supply problem inside the tv and when the transformer gets warm it is giving you problems you might have to get a tech seviceman to come out and have a look at it as it is not a job you should do yourself when it comes to replacing the power supply hope all goes well
Jul 06, 2011 | Samsung LN52B530 LCD TV
My 36'' insignia tv will not turn on...do you know why?
We need more information, does the standby light come on?? have you checked the obvious fuse in the plug ect... Is there any kind of noise from the tv, do you have a model number?
Apr 05, 2010 | Televison & Video
Sony tv turns on then off immediatly..standby light then is on
hey i have the same thing with my tv how do you fix it do you know?
May 29, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Akira Plasma not working anymore!
Have you gotten it fied yet? You can use a hair dryer to get it to come on.
Jan 30, 2008 | Akira EPM-420A 42 in. Plasma Television
Televison & Video Logo
32 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
