Question about Apple iMac 17" MA199LLA Desktop
THE COMPUTER TURN ON
BUT THE SCREEIN REMAINS DARK
    Novelist:
    Champion:
  • 233 Answers
This is an iMac right? Which means it is an all-in-one computer. Which means, like all iMacs, it is probably very difficult to repair. Some of the older iMacs had a port in the back for an external monitor. If yours does try that. I assume this has an LCD screen. If it does and if that has gone bad and if it could be replaced, it would probably cost more than the unit is worth.
Posted on Dec 24, 2008
    Problem Solver:
  • 15 Answers
First (and this is going to sound stupid) check that it has both power and is connected to the computer. Second, if it turns on check that it is recieving a signal. For video cards, most computers keep the default display adapter as the built in one and you have to manually change it in your CMOS settings. Third, make sure that your computer or screen isn't burnt out. This can happen and is noticible if your screen says nothing or your computer doesn't output a signal. If you aren't sure check your screen with someone elses computer.
Posted on Dec 03, 2008
The monitor Westinghouse model LCM-19w4 when I turn on the computer the screen remains black even with a green light on and I can use a flashlight to see the screen. When I turn it on and off the scre
It's mostly likely a bad capacitor in the main power supply of your monitor. If you're brave enough to dismantle it, look for capacitors that're "crowned", and sometimes even rupture from overheating in such circumstances. You can order replacements from Digi-Key if you can figure out which might be your problem, but I'm not sure I recommend you try this unless you have at least SOME soldering/desoldering skills or a friend who does. You COULD wind up worse off. It's up to you, only YOU know your personal skill level for such tasks. And do I need to say, UNPLUG it before dismantiling? :)
Mar 16, 2014 | Westinghouse 22" Widescreen LCD Flat Panel...
Dark screen and flickering on the laptop computer model pcg 61611L
I would check the GPU by connecting an external monitor before booting it, that will allow the external drive to automatically work.
Jan 02, 2014 | Sony VAIO Computers & Internet
Dukane 7100HC The picture is dark. In a completely dark room. I recently replaced the bulb, but the picture was dark before I replaced the bulb. I've adjusted the brightness, but it just washes out the...
Turn the brightness up slightly and turn the contrast on the highest setting. There may also be settings to control wether your projectin on a wall or on a screen. Make sure these settings are correct to your setup.
Jan 25, 2011 | Dukane ImagePro 7100HC Multimedia...
IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
Rear view mirror too dark for 05 sport track ford
I own on 04 and if its like mine, it automatically dims itself when lights are behind you. If its only too dark then... just turn it off. If it remains too dark all the time, I'd call your dealer and see what they suggest.
Nov 05, 2009 | 2005 Ford Explorer Sport Trac
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Dark screen on HP Photosmart E327
Same problem here, i upload the pics on my computer, then i turn off my cam, few minutes later try to turn it on, but no success, still have the blackscreen. I try to change the battery, reset it (15s without the battery, another 2 hours but no success), format the memory card (even without the memory the cam doesn't turn on).
Jan 03, 2008 | HP Photosmart E327 Digital Camera
Computers & Internet Logo
134 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
