Question about Kodak EasyShare DX6490 Digital Camera
Joystick switch stuck
The rotary on/off/video on my kodak dx6490 has gotten tough to work but is still managable... however now the center toggle switch will not do right or down, only left and up. Tried cleaning from the outside thinking it's simply grit or something blocking the contacts? My next step is taking it apart to clean properly. I fear there might be tiny pieces ready to fall out.
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello Megan,The joystick you are referring to has a bad record for failure in these model Kodaks,It is one of the most occurring problems the units have with age. It is not an easy fix nor a cheap one, the cost will exceed the value of the DX6490 on todays market.You are better off to sell your camera for parts and buy one in better condition on E-Bay,If you buy the same model you can still use all your accessories,battery,charger,etc.
Best Regards, Russell
Posted on Jan 23, 2013
SOURCE:
wizzkid3
SOURCE: Mode dial on my Kodak DX6490 camera is hard to turn!
dissmantle the back case (watch for 1 hidden screw under rubber covers), lift plate on back of lcd screen, remove screw on back of dial, clean where it sits on both sides (most probably from a liquid spill...tea, coffee...) , apply some lube with a cottonbud ore a bit of tisue and rebuild.
hope this helps
stewart
Posted on May 30, 2009
  • 11967 Answers
SOURCE: how to take it apart a kodak dx6490
Google the words...disassemble a digital camera.
Posted on Dec 08, 2009
  • 411 Answers
SOURCE: Brand new (3 weeks!) old camera ppost beach
sir, u r doubt is appriciated,must be careful when u r in suchbeach excursion,and also protect from moisture,and sand. take to the kodak service,lens unit has to be replaced,serviced.
Posted on Mar 04, 2010
vijay005
  • 231 Answers
SOURCE: my camera keeps saying unrecognized file format
dear sir,
the problem is usually caused by virus and sometimes it might be software failure also, which causes some of the menu not to function,the only solution is to flash ur cam software from the nearest kodak service centre..
thank you...take care
Posted on Oct 08, 2010
SOURCE: Kodak DX6490 error E45
hi...
i fix the problem.
2 years after the problem, i extend the lense and twist hard to the left.
then put it in the original position.
voilaaa..it works..
Posted on Dec 20, 2010
The joystick on my KodaK DX6490 has come loose. Can it be fixed? I can't navigate the directions.it feels as if a spring has gone underneath it.
This is exactly what happened with my DX6490. The underlying switch is only attached to the PCB with 6 or so tiny solder pads and these tend to give way after a time. It can be fixed although v. fiddly. You need to open the camera body up (screws and brute force, see previous solutions) and carefully release bits and pieces until you have access to the board. The switch can be resoldered if you have a tiny enough iron, very steady hands (use a rest) and a magnifying glass - or know someone who can do this kind of thing.
May 27, 2014 | Kodak EasyShare DX6490 Digital Camera
Broken joystick
Hello,This is a major problem with this series Kodak camera, as they age the switch either stops working or just falls apart !! The cost to repair would exceed the cost of a newer camera on E-Bay, I would stay away from this style control unless camera is new. Hope this helps.
Russ
Jan 15, 2013 | Kodak EasyShare DX6490 Digital Camera
Joystick broke off
Hello Carol, This is an ongoing problem with these cameras, the cost of the repair exceeds the price of a replacement camera found on E-Bay. Find a good one and you are still able to use your accessories, batteries,dock,memory cards,etc.There are some nice DX6490 cameras listed all the time.
Regards, Russell
Nov 26, 2012 | Kodak EasyShare DX6490 Digital Camera
How does the toggle, in the middle of the round and turning control, come off a kodak dx6490 camera?
Hello,If you are referring to the small joystick control the camera must be taken apart.the control is mounted under the small circuit board next to the LCD screen,Should only be performed by qualified repair person.The cost would be more than a replacement camera !!!!!! These models are prone to this problem,it is a major down-side to the model kodak camera.
Regards,Russell
Jun 16, 2010 | Kodak EasyShare DX6490 Digital Camera
Can't turn on the DX6490. I have 2 fully charged batteries, and neither one will work.
Hello, If the batteries you have are charging up with no problems then it sounds as if the rotary switch has gone 10 - 7. This model Kodak suffers from a great deal of switch problems. Cheap China plastic.
There are thousands of owners with these cameras having switch problems as the cameras age. Only cure is to replace the camera. It is not cost effective to repair.
May 25, 2010 | Kodak EasyShare DX6490 Digital Camera
The toggle in the middle of the mode selector does not respond any more.
Hello, Well I work on these DX6490 Kodaks as a hobby, I guess I am a sucker for punishment !!!! These guys all have problems with the small joystick you are referring to. It was just not designed or built for the long haul. As they age the problems begin to show. Not a cheap repair. Time to think about a newer camera, sell yours on E-Bay for parts, It will probably sell if the camera is in good condition.
Mar 17, 2010 | Kodak EasyShare DX6490 Digital Camera
Horizontal lines appear on the image after taking picture. As if the photo cells in the camera are kaput. Any other ideas?
The shutter doesn't work - stuck blades or the shutter cable is broken. Contact your local Kodak service center.
Jul 21, 2009 | Kodak EasyShare DX6490 Digital Camera
Can a faulty joystick be repaired/replaced?
Hello, The cost of the repair you are referring to will exceed the cost of a nice DX6490 on E-BAY. They all suffer from this problem with age,Bad design by Kodak.
Best Regards,Russell
Jul 01, 2009 | Kodak EasyShare DX6490 Digital Camera
Need to open dx6490
Hello, I work on these DX6940 cameras and can tell you that you are between a rock and a hard place when it comes to the small joystick.This is a major point of failure on these cameras and you will not find a good replacement unit, Chinese made low quality and no replacements available. You need two cameras to make one good one !!!
GOOD LUCK
Russell
Aug 07, 2008 | Kodak EasyShare DX6490 Digital Camera
ON / OFF Rotary selector is jaming
I sprayed the stem of the switch with big bath iso contact cleaner and rotated the switch through all positions repeating the sprying and rotating and it helped.
Feb 03, 2007 | Kodak EasyShare DX6490 Digital Camera
Kodak EasyShare DX6490 Digital Camera Logo
71 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
