Question about Frigidaire GLER341A Electric Dryer
Dryer has no heat/clothes not is cold
My dryer is not even 2 years old .is it possible that i still have a warranty on it .model# is GLER341AS
  • 525 Answers
Your unit has a 1 year manufacturer's warranty. If you have no service knowledge, you will need a repairman. If you do have some electrical/mechanical background, post me back and I will try to assist you in diagnosis/repair of the unit, or I can help you find a servicer in your area.
Posted on Dec 03, 2008
Takes too long to dry clothes
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
Whirlpool Duet Steam is not heating to dry any clothes
Don't have your model so I couldn't bring up the schematic some will run with an open thermal fuse I suspect thermal fuse which is non resettable I've only run across a bad thermistor once based on the age check the exhaust exiting the house and at the dryer this a safety fuse designed to open due to excessive heat if the dryer cannot breath restricted exhaust.
Jan 21, 2014 | Washing Machines
My Bosch dryer never seems to get very warm.It's an Axxis. I've only washed about 10 loads. It seems to take a long time, and when I take the clothes out, they are cool to the touch. Even when I touch the...
There are a few possibilities here:
1. Washer/dryers generally take longer to dry clothes than a stand-alone dryer so if you previously had a stand-alone and are now using a combi, this could be the reason.
2. There are usually at least 2 heat settings on a dryer, so maybe you have it on a cool setting?
3. The last part of a drying cycle (5-10 minutes) is usually cool - even when on a high setting. This helps to reduce creasing and cools metal parts such as zips and buckles for saftey. This could explain why everything feels cool when you remove the clothes.
It's possible your old dryer didn't have the cool final setting and/or it was higher power than your new Bosch and therefore dried the clothes quicker.
If your new machine is taking an eternity and your clothes still aren't properly dry, then there may be a fault with your dryer thermostat which is switching the heating coil/element off at too low a temperature. However, I suspect your problem is related to information I've written above.
It would help to know whether you have an Axxis washer/dryer or just a dryer. If the information above doesn't help you to solve your problem, please post back with details of your machine, including the model number, if possible.
Nov 25, 2010 | Bosch Dryers
I have LG DLE2101W just installed yesterday. It
I found your manual and learned yours is a GAS dryer... the FIRST check is to be SURE the gas valve to your dryer is OPEN.
There is a Troubleshooting section, but NOTHING about no heat?
Know that LOW gas pressure CAN be a issue too!
I did find this:
"If the dryer no longer heats then the heating element may have failed, but it is not the most common cause. The most common cause for a dryer to stop heating is a blown thermal fuse."
The SECOND Link will be VERY helpful...
More help?
Cause 1 Thermal Fuse
Cause 2 Gas Valve Solenoid
Cause 3 Igniter
LG DLE2101W Support Manuals Warranty More LG
LG Dryer Not Heating
Dec 24, 2017 | LG Dryers
Is fading and shrinking my clothes
low temperature and low rpm of motor,must try this.
Feb 16, 2009 | Frigidaire FTF2140F Front Load Washer
Dryer not drying cloths This shows the screws (#2) that hold the front on. Use a putty knife to push on spring catches (#20) to release the top.
Jan 24, 2009 | Roper RGX4634KQ Gas Dryer
My dryer never shut off for 7 hours now it runs but dsnt heat up
Your timer has gone bad. if you get me the model # i can get you a part number and you can order the part from sears. (this is a very common issue)
Nov 19, 2008 | Dryers
Frigidaire GLER341A Electric Dryer Logo
206 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
