Question about Lands Phones
Searching is displayed on handset and Y icon is blinking, looks like a twig sign, have tried move closer to base station, base station is on reset unit restart handset reg, have tried all but gets to waiting then goes back to searching, so no dialling tone or anything, please help.
  • a1vivek Feb 22, 2009
    only searching in displayed in handset .
Turn base around and find the area which says pager/registration. Push this button after you set internally the handset registration.
Menu/H set settings/Reg. Handset
Posted on Dec 31, 2008
Solution is displayed on handset, need to reset
Posted on Sep 12, 2009
Display keeps saying 'searching'
I don't have this model but I have had two Siemens phone systems. Typically, when the handset says "Searching" it is trying to connect to the base station (the part actually connected to the phone line). This can happen if the handset is too far from the base station to connect to it wirelessly. It can also happen if the handset has become unregistered from the base station (or was never registered to begin with). If the distance issue is not the problem, look in your documentation for how to register the handset and give that a try.
Sep 07, 2014 | Siemens Gigaset 4215 Cordless Phone
I just bought the Panasonic KX-TG9341T. This model has 4 remote extensions. My problem is the light on top of each phone keeps blinking. I checked to be sure I don't have any messages or anything else,...
The message indicator lights up when you have a new voicemail message, answering machine message, when you are receiving a call, or when the handset is placed on the charger. You can change the setting for the voicemail indicator and message indicator by pressing [MENU], [#][3][4][0], and press [▲] or [▼] to switch between off and on, then select [Save]. It is not possible to turn off the LED for an incoming call, or while it is on the charger.
Good luck...
Sep 05, 2008 | Panasonic Lands Phones
I have a KX-TG6700 base station and 4 Handsets. When I have been calling on the handsets I have recently found that there is static on the line. Later I realized that there is problem with the DTMF being...
The KX-TG6700 manual at: http://www.panasonic.ca/PDP/OperatingInstructions/kxtg6700-oi-eng.pdfhttp://www.panasonic.ca/PDP/OperatingInstructions/kxtg6700-oi-eng.pdf
States:
For best performance
Base unit location/avoiding noise
The base unit and other compatible
Panasonic units use radio waves to
communicate with each other.
For maximum distance and noise-free
operation, we recommend the following:
LPlacing the product away from electrical
appliances.
LPlacing the base unit in a HIGH and
CENTRAL location with no obstructions
such as walls.
LRaising the antennas vertically.
LIf you use the handset near a microwave
oven which is being used, noise may be
heard. Move away from the microwave
oven and closer to the base unit.
LIf you use the handset near another
cordless phone’s base unit, noise may
be heard. Move away from the other
cordless phone’s base unit and closer to
your base unit.
Have you considered all these points?
Is there a way you can move the base station to another location in your house to see if the problem get better? I don't beleive your base station is faulty, I suspect interference from something.
I don't think the 2.4GHz set is causing any issues, but you never know, try unplugged it for a while to investigate.
If you do determine that the base station is faulty there probably isn't many options to get it repair other than sending it to Panasonic. May be cheaper to buy a new base station to go with your extra handsets.
Good Luck!
Mar 14, 2008 | Lands Phones
Uniden dwx207
When a handset is reading "Searching", it can't communicate with the base. First, check if the base station is plugged into a live outlet. (Try plugging the base into a different outlet or making sure that the circuit breaker hasn't popped. I had a cordless phone base plugged into a UPS. During an extended power outage, the UPS was turned off. The phone didn't work until someone noticed and turned the UPS back on.) Move closer to the base station.
If this was an extra handset purchased later, make sure it is compatible with the base station. The Uniden DWX207 works with the DECT1500, DECT2000 and DECT3000 series bases. Register the handset with the base. The registration procedure depends on the base station. If the base unit has an LCD screen, with the phone in standby, press Menu/Select and press the down arrow to reach "Register Handset". Then press Menu Select again. (If the base doesn't have an LCD screen, unplug the power cord. Then hold the Find HS or Find button as you reconnect the power cord until the Charge/In Use light starts to blink.) Then press the # key on the handset before the registration period ends.
Make sure that you haven't exceeded the number of handsets for your base. You may need to de-register all handsets and then re-register them.
If no handsets will pair with the base, replace the base unit. The transmitter or the receiver aren't communicating properly with the handsets.
I hope this helps.
Oct 06, 2013 | Lands Phones
A key symbol on the left hand side of the phone is blinking. I'm unble to make a call,its telling me that no link to base. move closer to base, Try again. All the phone cords are in the socks and...
The key symbol is supposed to be an antenna.
It can't receive a signal.
There are a few possibilities:
- Too far from base. Move closer.
- Base is unplugged (no power at base station)
- Phone has become unregistered (unlikely).
If you need to re-register the phone, the process will vary depending in the model of the base station and will be covered in the manual.
Apr 05, 2011 | Panasonic KX-TGA101S Cordless Handset
The phone says no phone line, and i dont have a dial tone. cant call out and cant get calls coming in
Model LS6305: How to register a handset:
  1. Place the non-registered handset in the telephone base or charger. If 1.Press FIND HS on base 4sec and 2.Then press # on handset do not appear alternately on the handset screen after a few seconds, remove the handset and place it in the telephone base or charger again.
  2. On the telephone base, press and hold FIND HANDSET for about four seconds until the red IN USE light on the telephone base turns on.
  3. Remove the handset from the telephone base or charger and then press # (pound key). It displays Registering...Please wait. It takes about 60 seconds to complete the registration. The handset displays Handset X Registered and you hear a beep when the registration process completes.
  • If the registration fails, the handset displays Registration failed for a few seconds, then 1.Press FIND HS on base 4sec and 2.Then press # on handset alternately. To reset the handset, remove it from the telephone base or charger and place it back in. Try the registration process again.
Model ip8300: How to register a handset:
  1. Press and hold FIND HANDSET for at least 10 seconds on the telephone base. The VMWI and LINE IN USE lights will blink alternately indicating that the telephone base is in registration mode.
  2. To display the telephone feature menu, press the Menu softkey from the main idle screen.
  3. Press the up, down, left and/or right NavKeys to choose Registration Settings then press the Select softkey or center NavKey/SEL.
  4. Press the up or down NavKey to choose Handset Settings then press the Select softkey or center NavKey/SEL.
  5. Press the up or down NavKey to choose Register to Base then press the Select softkey or center NavKey/SEL. A list of locations for assigning telephone bases will be displayed.
  6. Press the up or down NavKey to choose an empty location and press the Register softkey or center NavKey/SEL.
  7. The handset will display Searching while it searches for the telephone base. If the search is successful, a code from the telephone base will be displayed. To register the handset to the telephone base, press the Register softkey.
  8. In the Enter PIN box, enter the system PIN. The default PIN is 0000. Press the Apply softkey.
  9. Handset registered will be displayed when the registration process is complete. The screen will return to the registration settings menu. Press OFF to return to the idle screen.
Model ip8301: How to register a handset:
  • Before registering the handset with the base station, press the FIND HANDSET button in the base till the VMWI and LINE IN USE lights blink alternatively. When the lights start blinking, register the handset. The default PIN for registering the handset with the base station is 0000.
  1. Press Softkey Menu from Home screen
  2. Choose the Settings icon from Menu screen and press center Navigation key/SEL to display the settings menu options.
  3. Press the up or down Navigation Key to choose the Registration Settings menu option and press the center Navigation key/SEL to select.
  4. Press the up or down Navigation Key to choose the Handset Settings and press the softkey Select to select.
  5. Press the up or down Navigation Key to choose the Register to Base and press the softkey Select to display a list of available base stations. Choose a base station from the list and press the softkey Select to select.
  6. The handset will search for the Base within its range. During this time, the searching screen will be displayed.
  7. If the search is successful, the Base station number of the base will be displayed.
  8. Press softkey Register. Enter the PIN and press softkey Apply to save and subscribe to the base station.
  9. To cancel the entire operation, press OFF key anytime.
Mar 07, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Can not rec a dial tone, phone states no link to base move closer
If “No link to base. Move closer to base, try again.” is displayed
even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
• Make sure the base unit is not being used.
• Have both handsets and base unit nearby during registration.
• Follow steps 1–3 listed below. You have about 1 minute to complete them.
• Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
If you re-register the handset using the other handset’s extension number, the other handset will not function.
• If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
• You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
• The CHARGE indicator flashes.
2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
handset which has lost the communication.
3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
• When registration is complete, a beep sounds from the handset and the display shows the number.
• Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
Feb 23, 2010 | Panasonic KX-TG2357 Cordless Phone
No Link to base. Move closer to base and try again.
Re-Register!
That's right.
Wait, don't look for any product registration card you think you still have. You probably threw that away with the packaging the first day you opened it.
On the Handset:
Know which handset you have (#1 or #2)
Menu --> Initial Setting --> Registration
The Handset will say follow the instruction on the manual which you don't have.
Now, go to the base unit:
Press and Hold the Handset # button (#1 or #2), until you see the display on the base unit changes.
You can release the # button now.
Press <select> button on the handset.
Wait until you hear beep.
You're done!
Apr 04, 2008 | Panasonic GigaRange KX-TG2432 Cordless...
TWX977 submersible unable to base register
push menu on base station - select register phone
push # sign on twx977 phone at the same time
phone will register on 9485 base station and unit
Sep 09, 2007 | Uniden TRU9485 Cordless Phone
Lost comunication
I solved this problem with a RESET of the handset. Instructions from the Philips website: Please perform a reset of your device. You will not loose your recorded data (phonebook and personal settings are being kept). 1. Unplug the mains of the base station. 2. Remove one of the batteries of each handset. 3. Put the batteries back in and re-plug the mains of the base station.
Mar 09, 2006 | Xact Communication XG2200 Cordless Phone
Lands Phones Logo
627 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
