Hello, my problem is that i can't seem to get my second (built-in) 140gb hdd to store any data?! My first drive is almost completely full and keeps coming up with the low disk space warning! I was just wondering do i need to do something to 'activate' the drive or will it just automatically start using it?! Many thanks, Jonny
  • 1 more comment
  • Graeme van Malsen
    Graeme van Malsen May 11, 2010
    First of all, when you double click 'My computer' icon, do you see an icon in 'My computer' for your second hdd?
  • Chris Fourie May 11, 2010
    Is the drive being seen by your computer? Is it a SATA (Serial - ATA) drive? Does your BIOS read it?
  • Sibananda Jena
    Sibananda Jena May 11, 2010
    Pls clarify,wheather u can access ur 2nd hard disk in explorer or not...
    Sergeant:
  • 302 Answers
You will have to slave your hard drive
Make sure you configure the jumpers on the old drive correctly and connect only as a slave. Booting a PC with 2 hard disks, each with it's own OS and logical DOS partitions, without one configured properly as a slave, can irrepairably damage a PC.
Posted on Dec 06, 2008
Disc c is showing full of memory and everything goes downloaded in this disc but it has no space other volume are free..so what i do
Usually the C drive is your main drive on your computer. The C hard disk drive (HDD) contains space measured in gigabytes, for example 500GB means 500 gigabytes of data that you can store on this HDD.
If the C drive on your system is showing full, then it is time to backup some of your data to another HDD usually an external HDD, that you can purchase at locations such as CompUSA or Best Buy.
The other volumes you refer to are internal HDD then you're in luck. Move some of your data from your C HDD to your other HDD.
Remember that after a certain point, a HDD may stop responding or respond very slowly when it is almost completely full.
Let me know if this helps out.
Feb 12, 2012 | Computers & Internet
How do i remove a built-in HDD password?
If it is the password that has been firmware locked, you cannot. This is to stop people who steal laptops from accessing data
If its a BIOS password, access the bios by pressing ( I THINK) F2 or F1 or Del at start up, navigate through the BIOS screens until you find SET Password and remove it
Dec 25, 2010 | Toshiba L305-S5955 Notebook
I forgot hdd password how to unlock
Toshiba highly recommends the customer to fully understand what HDD Password is and once registered please keep your "PASSWORD" in a safe place.Your HDD password is different from your BIOS Password. Your BIOS Password is stored in the computer, but your HDD Password is stored in the HDD unit itself. So even the HDD unit is removed from one computer and attached to another, the HDD password is required to access it.If you forget your HDD User Password, TOSHIBA will NOT be able to assist you, and your HDD will be rendered COMPLETELY and PERMANENTLY INOPERABLE. TOSHIBA will NOT be held responsible for any loss of data, any loss of use or access to your HDD, or for any other losses to you or any other person or organization resulting from the loss of access to your HDD. http://aps2.toshiba-tro.de/kb0/TSB6B01MC000CR01.htm
Dec 07, 2010 | Toshiba 80GB MK8037GSX 2.5" SATA II SATA...
I used my Lacie 160GB Mobile Disk from morning to evening on my Dell Latitude D610 Laptop, until evening when my younger brother came home from work, he demands to copy some movies from my Lacie 160GB...
This happened because your brother's computer is infected with a virus or otherwise corrupted. Take the drive and both computers to a local tech to further diagnose the problem and that tech can probably recover your files. I think your brother should pay for the repairs - his computer has some malware that may have overwritten your files. This is why you should do two things - first, always have two kinds of backups - copy vital files to a usb memory stick, and second, don't lend anyone any device you plug into your computer - that is how viruses are spread.
Apr 06, 2017 | LaCie 160GB Mobile Disk USB2.0 160 GB Hard...
I keep getting a message that my HDD smart something is predicting my hard drive is going to fail. Windows also gives me the same message. What should I do?
goto my computer , right click on the C: drive goto properties
check the pie chart it shows you what size your drive is and how
much data is stored on it , if the drive is very close to being full
then messages will occur , the number one cause for a full drive
is media ( music movies photos videos Etc. )
Mar 13, 2010 | Toshiba Computers & Internet
I need to replace hard drive for a ricoh copier 1045. How can I get the software for the hardrive, and what is the maximum size of the hard drive?
No need for software. The standard hard drive size is 10GB. I don't remember the exact limit but the machine will only recongnize a certain amount so it will do you any good to buy a larger capacity drive. Just get the smallest/cheapest one and you'll be fine. These take the smaller "laptop" size drive in case you did not know. Other than that just install the new drive and let the machine do the setup. If your old drive failed then keep in mind you will have lost any document server files, scan destination or fax destination info and will have to re-enter that info.
Good Luck
Feb 23, 2010 | Ricoh Office Equipment & Supplies
Data Vanished
the data recovery software will recover at lest 95% if it is a full vasion. also scan the drive with updated anti(virus and spyware)
Jul 02, 2009 | Western Digital Elements powered by WD 320...
Acomdata 640GB External HDD problem.
I'd recommend that you use some data recovery software. You may try asoftech data recovery that helped me before.
Feb 22, 2009 | Acomdata 500GB PureDrive USB eSATA 500 GB...
How to copy to disk or to pc from lg42lt75 hard drive
lg hdd format not suport by pc and protected so you cant save data on hdd
Dec 21, 2008 | LG 42LC2D 42 in. LCD HDTV
No Allocated letter on HDD
hello,
i think you lost the mbr of old hdd. Or you have a virus problem on your pc. firstly you boot the pc with new hdd and then scan the whole drive by an updated antivirus and then boot prom old hdd. if it is not solve your problem then rebuild the mbr by any software which are avalable on net.
i think it can solve your problem.
ramesh
Nov 29, 2008 | Western Digital 250GB MyBook External USB...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
