I want to buy an lcd tv. can i still use my vcr with it?
    President:
  • 2,110 Answers
Yes sure U can use VCR
Posted on Dec 03, 2008
How do you connect a polaroid lcd tv to a polaroid vcr/dvd combo?
does it have HDMI INPUT/OUTPUT? OR Audio video input/output? First you must have a cable for either of those two. HDMI (from the lcd tv) to HDMI (vcr/dvd combo).
audio/video input (from the lcd) to audio/video output (from the vcr).
hope this helps.
Jul 06, 2011 | Polaroid TLX-01911C LCD TV
Need the tv code for 23" LCD Tv 233 or where I can get the remote control device for this tv as mine broke. This is a Mintek TV/dvd
u want new remote for minteck tv or u want codes from what remote model ? u can buy harmoney logitech remote 99 bucks best buy does all lights ect tvs vcr auto buton hit it finds best buy thx nick
Feb 09, 2008 | Televison & Video
Why will my VCR not work with my LG LCD TV,model 47LD520?IT comes on but will not play tape.
The tv LCD screen panel reconize the VCR and have the LCD screen panel,have a LCD have a blue screen wright,that incated u hook up the VCR wright.The VCR is not playing the tape,because is the VCR have problems,Not the tv itself.
Oct 26, 2010 | LG 47LD520 47 in. HD-Ready LCD TV
I do not see a standard cable input on the tv...is there an adapter to connect standard cable line to the antenna input?
if the TV has 2 screws for an antenna connection then you could use what is called a BALUN aka matching transformer. you can buy them at a dollar store. it has a male cable connection and 2 wires.
I am surprised that an LCD TV would have an antenna connection, they are from the days before cable TV.
if your TV does not have a cable input you can use an old VCR as a tuner
or buy an RF converter (but they are overpriced IMO)
you would plug the TV cable into the VCR and use rca cables red,and white for right and left audio, and yellow for video
Jan 10, 2010 | Mintek DTV-265-D 26 in. LCD TV
Why won't older Sanyo VCR playback VHS tape on new HD-LCD TV?
The problem is not with your TV. I have had this problem as well and the older the VCR gets the harder it is for it to turn the tape. Does your VCR react the same way with other tapes? Try Fastforwarding the tape about halfway and then test it again.
Jan 06, 2010 | Sanyo Televison & Video
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi Televison & Video
Connecting a DVD/VCR combo to LCD TV
The best suggestion I would advise is to buy a shielded scart connector & connect that from your DVD combi to either AV1 OR AV2. It sounds as if you are picking up RF interference from your current connections, this can sometimes happen if the cables do not have adequate shielding.
May 21, 2009 | LG 42LG30 42 in. LCD HDTV
Can't record from lcd to vcr
On any VCR/TV setup, the television does not send signals to the VCR, the VCR has to send the signal to the television and then the show can be recorded. Attach the antenna input to the VCR and then your other cables (they may be RCA jacks or another coaxial, like the antenna cable) to the TV. You would have to change the channels using the VCR's TV tuner (if it has one).
If it does not have one, then you would need a new digital TV converter, and you hook this up to the VCR, then to the TV set. Hope this helps!
Mar 14, 2009 | LG Televison & Video
Tuning VCR into Tv
Set the LCD to TV source and tune the LCD TV channel to 3 or 4.
For best viewing experience, you should connect the LCD TV to the VCR using component / SVideo or RCA cables instead of RF coxial to avoid signal loss. Your VCR manual should indicate these types of connections.
Aug 11, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Coaxial to component
You may need an extra HD tuner for your TV. The only problem that you may have would be the original signal running through the coaxial cable. If it's just regular TV stations, the tuner should fix the problem.
May 22, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
