Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet 9200 Washer door lock issue
Maybe someone can help me.  I just received a new Duet wfw9200sq washer and would like to know if this is normal.  I start the machine, (normal cycle) and the door locks (light comes on).  Water comes into machine for about 3 seconds and stops.  The door unlocks (light goes out) and the about 3 seconds later the door locks again (light goes on).  Machine then washes normally and seems fine.
Does anyone know if this is normal?  My neighbor has a similar machine and does the same thing, however the company says that its not normal. Any advice before I return the machine for a new one would be greatly appreciated.  Thank you.
  • 1 more comment
  • lbarreca Dec 04, 2008
    Thanks long as its normal, thats fine.  Although the sleeping child thing is a bit odd, didnt think little ones liked sleeping in washing machines...thanks for the reply.
  • Anonymous Apr 13, 2009
    I just purchased a Whirlpool Duet 8400 Washer and I have the same situation. I press Start and the door locks and the add garmnet light comes on then within a few seconds door unlocks and then locks again and wash light comes on and add garment light stays on for awhile before going off (the book says 7 minutes but it isn't always that long) Anyway I was also wondering if that initial lock, unlock, lock sequence is normal? I don't see the point of the unlock after the initial lock? Boy wash cycles are sure long with a front load washing machine.
  • prem mathew May 11, 2010
    Could even be cats or dogs............
  • Whirlpool Master
  • 2,651 Answers
No thiis is normal operation, it is considered a child safety feature. in case a sleeping child should happen to be in machine, the short 2 sec blast of cold water will wake them and give them a chance to exit before the machine starts washing.. all whirlpool frontloaders do this, thats how it waas explained to us at factory training.
Posted on Dec 04, 2008
I think Ihave a wfw 9200, the door lock light is flashing and cannot be cancelled. There is a f21 fault code flashing. HOW can I open the door ?
Hello, Welcome to FixYa.
Based on your post I understand you have a F21 problem with a Whirlpool Duet washer, that indicates the F21 error means an excessive drain time.
As for the door locked issue, it is a by-product of the F21 error. Make sure you get the water out before attempting to open the door manually or it could be messy.
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about ¼" or until a click is heard.
6. The door may now be opened.
If you follow the link to my solution to this error you should be fixed up in no time.
Thank you for visiting fixya for your washer inquiry. Please take a moment to rate my assistance and leave a brief testimony.
Macmarkus :)
May 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet ht washer control locked. How do I unlock it? Really need your help
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washers however, your whirlpool duet washer can be reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Apr 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
May 18, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool washer doesn't unlock the door at the
Hi There
I have found this for you to read. it's door unlock error. Hope this helpful and let me know how it goes.
F/dU Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F32 comes up when we just installed our new Whirlpool Duet Washer WFW9200SQ.
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer door will not open
try pressing start and then pause/cancel immediately after. I just had this issue with mine
May 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not start
This is joyce
Go to and download your document to your machine and see what it has to say about your particular machine if that will help if not you may have to get some proff. help.
Feb 19, 2009 | Washing Machines
Whirlpool frountloader washmachine door locked
Has the washer finished it's cycle?
Reply and I will try to help more.
Jan 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The door on my Whirlpool duet sport won't close / lock ..
its best if you call whirlpool to set up service call. tampering with your washer could void the warranty
Dec 16, 2008 | Whirlpool GHW9400 Duet Washer
Control locked on ghw920 can u help me unlock
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Jul 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
351 people viewed this question
Dan Webster
Dan Webster
Sal De
