I need to ship a commercial bunn coffee maker. How do I remove the water from the tank?
    Genius:
  • 2,120 Answers
Put a bucket underneath of the water inlet line and unscrew it.
After that drains, turn the coffee maker upside down in a sink for further draining.
Posted on Dec 04, 2008
Is there a gasket between the filling tank and the lid of the tank
Yes. It's a tank gasket that can be purchased from www.bunn.com. You'll have to remove the trough above the tank, wires, fuse, temperature probe, water inlet, hot water output tube, and 8 nuts to get to it.
May 03, 2015 | Bunn Coffee Makers & Espresso Machines
Commercial Bunn CWTF-DV-3T is leaking water from the top right corner of the machine and now at the base behind the bottom burner when you start a pot of coffee
water tank inlet in the top possibly limed up causing pan to overflow. remove top, use screwdriver or deliming spring to poke through the drain nut in the pan. should work fine now
Feb 17, 2014 | Bunn 10 Cup Home Coffee Brewer
Leak from hot water faucet
Replace the water faucet. Contact the company the unit was sold or installed by. they should have the part in stock.
Dec 14, 2009 | Bunn Automatic Coffee Brewer CWTF15 1
WE have the Bunn VPR series. It's a pourover
Hello this coffee maker has a one and a half gallon internal tank, could be one of a few problems, first thing to check is the spray head, unscrew this you may need some channel locks to get it off and check it..use a tooth pick to clear the 6 holes with any lime that may have formed...also if you use a commercial coffee company for your coffee they should have supplied you with a spring to clean the spray head tube. After checking these 2 items the next thing to check is there enough water in the tank..when the vpr is left on and not used for a few days the water in the tank evaporates..it takes approx two and a half pots of water to fill up the internal tank...try pouring another pot of water in...also turn machine off and take the 2 screws out of the top and see if there is lime blocking the drain hole in the fill pan. Hope this helps...please feel free to comment again if you have any other questions...Good Luck!!! Mike
Jul 14, 2009 | Bunn (VPRBUNN) 12-Cup Coffee Maker
How do you drain all the water from the resavoir of a Bunn VPS?
Hello. Take the funnel out, under it is the spray head, remove it, unplug the unit, take it over to a sink and tilt the end that the spray head was on into the sink slowly, the water in the tank will drain out through the spray head pipe until mostly empty. You also could take the top off, take the tank lid off, and use a shop vac to vacuum all the water off, or just pour it out, probably faster, but messier :) If you need information on you unit, go to www.bunnomatic.com , chose commercial, and then on the left, choose coffee, and pour overs.
Hope that helped, and thank you.
Mar 23, 2009 | Bunn VPS Coffee Maker
My bunn coffee maker is just dripping when it is making coffee. Then the next time it makes it just fine.
Hello, I am wondering how long between times you are stating, as most Bunn commercial units, stay heating 24/7, and if water is not poured into the machine every couple of days, they will evaporate off water that is held in the tank. This drop in water level can cause short brewing, slow brewing, etc.. as the unit relies on a vacuum or suction to brew properly. You could also have a leaking tank gasket, or brew tube gasket, and it is seeping air into the tank, breaking the vacuum/siphon action, and then seals with water, or expansion at other times. Another cause would be scale build up, and pieces are floating in the tank blocking the flow of water, or your spray head may be clogging/clogged, which minor cleaning should take care of the sprayhead, and tube, or a major cleaning necessary for the tank.
Hope that helps, and thank you.
Mar 04, 2009 | Bunn VPR Coffee Maker
Bunn commercial coffee maker plug overheats, no hot water
Most likely this is your heating element, but it could also be your main thermostat
Feb 13, 2009 | Bunn Coffee Makers & Espresso Machines
Commercial bunn coffee maker that the water only dribbles out
In addition to running vinegar thru your coffee maker, remove the sprayer at the point where the fresh coffee comes out to enter the carafe. It is a disk about the size of a half dollar with several small holes in it. Use a small piece of wire to clean out each of the holes and you should have the speed back. good luck.
Jan 27, 2009 | Bunn Counter Top Coffee Brewer Commercial
Bunn Coffee maker leaking out of the bottom of the coffee maker when the coffee maker is not making coffee.
that needs to go back to bunn for a replacement tank, they will likely only charge you for return shipping
Dec 10, 2008 | Bunn NHB Coffee Maker
Bunn commercial coffee maker does not pour water
clean your spray head by removing it and at the same time run the cleaning spring up through where the spray head screws to. before replacing spray head place your pot under and pour a pot of water through,to rinse.when done replace spray head .wait for it to heat up and your set to brew again...
Oct 28, 2008 | Bunn GR10 Coffee Maker
35 people viewed this question
k24674
jasbo
jasbo
