Question about Samsung SCX-4100 All-In-One Laser Printer
Printer stays in 'warmup cycle and stop' and repeat over and over again
Suddenly stopped working normally. Stuck in warmup cycle. Suggested fault in fuser area. Any ideas.. Sensor, 'flag' stuck. how do I dismantle this machine. I like the printer is just sad its stuck in warm up... thanks
    Novelist:
    Champion:
  • 202 Answers
AC, this link should take care of your questions. You can download the manual and check out the specs. http://www.samsung.com/support/productsupport/download/Model_Select2.aspx?type=Printer+and+Multifunction&subtype=Discontinued+Products&model=SCX%2D4100&fileType=UM&LSSI=%2Finclude%2FSSI%2Fus%5Fleft%2FLMenu%5FPrinterandMultifunction%5FDiscontinuedProducts%2Esec&RSSI=%2Finclude%2FSSI%2Fus%5Fright%2FRMenu%5FPrinterandMultifunction%2Esec Good Luck, Tim
Posted on Feb 04, 2007
Sir, carrier model42QG24-C comeing to off after 5 mint and then on after some time it repeate this cycle again and again. The red led on pcb is blinking regulerly..
More than likely it is cycling on its low pressure control.. It is an automatic reset device but each time it cycles off, the TDR (time delay relay) keeps it from restarting for approximately 5 minutes.
A steady and rhythmic 'heartbeat' on the circuit board typically means 'normal' operation. If it flashes, stops, flashes, stops etc, it would be giving you a fault code telling you what is cycling it off. You have to count the flashes, slow or fast or a combination of slow and fast and look up the fault codes.
Apr 28, 2015 | Carrier Heating & Cooling
Canon Imagerunner C2620 stuck in warmup
you must read your troubleshooting section instruction manual If you do not have download
www.fitness.manualsonline.com or www. retrevo.com or www.manualsfactory.com or www.2manuals.com or www.eserviceinfo.com
see the diagram .God bless you
May 09, 2012 | Canon imageRUNNER C2620 Color Copier
Machine turns on and off by itself and keeps doing it
Hubby says it could be a stuck button. Otherwise there could be a fault with your front control panel. Feel special, he's never come across that before!
May 20, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Brother Mfc9840cdw (except for fax send) has been very good. During print job (2nd computer sent job during print from 1st computer), red light suddenly came on. everything stopped. No sign of a jam. No...
the machine is nearing service time.. Normally this is maintenance and resetting the print clock..
  • press both 3 and 9 buttons at the same time and hold
  • select each item 1 at a time and press ok
  • press 1 to reset it..
  • do this for each item in the list
  • repeat for each item.
Apr 05, 2010 | Brother MFC-9840CDW Laser Printer
I have a calypso washer it seems to be stuck on the heavy cycle no matter what i dothe display says 53 mins it wont do anyhting wont start if i hit the button wont let me choose another cycle like quick...
I just ran into a similar problem. Ours was stuck on Normal with 42 min. Started beeping every couple minutes last night after bad rain storm. Couldn't get it to stop. it would turn off if I hit stop and a couple minutes kater (like 2min) it would come on by itself. Left it unplugged overnight until about 6:00pm. Plugged it back in and it wnt right back to the normal mode after about 2min. HOWEVER, I keft it sit with the lid open and it beeped every couple minutes for a while then suddenly stopped. I checjked it and it is off, hasn't come back on. I haven't tried to run a load through it yet, so I don't know if it is fixed or not..
Oct 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
Apr 10, 2009 | Kenmore 15762 Dishwasher
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
ASKO 1595
yes have you tried what i suggested yet
Mar 29, 2008 | Asko D1776 Stainless Steel Built-in...
Dishwasher stuck in cycle tricity bendix DH 104
if this is stopping early in the cycle, the timer has just moved a little before it stops then it is highly likely to be a heater fault, check the element for open circuit, this can be accessed from under the machine, work with safety,
Sep 16, 2007 | Tricity Bendix AW1000W Front Load Washer
Samsung SCX-4100 All-In-One Laser Printer Logo
365 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
