Question about GPS
Unable to unlock maps for garmin nuvi 200 - GPS
  • 1 more comment
  • likemydrums Apr 24, 2009
    cannot get nuvi 200w to show map after connecting USB cable to register and download map update. Unit is reflecting message on screen that the unit has no detailed map info for routing and will not function. What can be done?
  • JOCARVA May 17, 2009
    I DO NOT KNOW WHERE IS DE THE UNLOCK CODE
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    We need more information. What did you try to do prior to this message? Please be more specific.
    - Jim
Soution:
1. Use Mapsource to find the unlock code for NT v8 (from Utilities->Unlock Maps...).
2. Using Notepad, edit gmapprom.unl file on the unit (under Garmin folder) to replace invalid code with the correct 25 character unlock code (no spaces or dashes) and hit Enter key and save.
3. Reboot.
Posted on Apr 04, 2009
My garmin nuvi 200 says no detailed maps found
From the Garmin web site:
Question: What should I do if my Garmin nuvi / zumo displays the message "No Detailed Maps That Support Autorouting."?
Answer: Please follow these steps to troubleshoot the error message:
Checking the unit:
  1. Hold your finger down on the screen until the message "No Detailed Maps That Support Autorouting" disappears.
  2. If you get a locked maps message following this error please remove any SD cards in the device and skip down to the instructions for "Getting your unlock codes".If you did not get a locked maps message then please select tools>settings>map>mapinfo button.
  3. Check the box next to the mapping product City Navigator and you should no longer get the "No Detailed Maps That Support Autorouting" message.
Aug 14, 2012 | Garmin Nuvi 200 Automotive Gps Receiver
My garmin nuvi 200 it say no detailed maps
my garmin 200 nuvi say no detailed maps found that support routing
May 21, 2010 | Garmin nuvi 200 Car GPS Receiver
My Garmin Nuvi 200 has a message that says No detailed maps found that support routing. The nuvi cannot be used without them. I just used this garmin a few hours ago, and it was fine. Now I can't get...
You need to call garmin to have them help you unlock your unit. It sometimes requires the 25 digit unlock code which they have on hand. 1-800-800-1020 I believe.
Aug 15, 2009 | Garmin nuvi 200 Car GPS Receiver
Garmin Nuvi ~ No detailed maps found that support routing.
Please see this link for more inforamtion on this problem. I can help you resolve the issue. Your map unlock code is either corrupted or missing.
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
Jul 11, 2009 | Garmin nuvi® 200 Car GPS Receiver
Unable to unlock new maps
Where did you download the Australian maps from? If from Garmin, contact Garmin for the unlock code. Maps have to be unlocked to a specific unit.
If you downloaded the maps from the internet, you will still need to contact Garmin for an unlock code.
Jun 14, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Hope this helps!
I wanted to add maps to my 250W. I found the maps I wanted on a Torrent. However, many searches around various forums never revealed how to install these. Found the following through reading and experimentation.
1. Downoaded map image file GMAPSUPP.IMG. Download also gave me "Use code XXX when generating unlock code for maps"
2. Downloaded Garmin Unlock Generator 1.3 by JetMouse
3. Looked on my GPS to find the UnitID
4. Entered the UnitID into Garmin Unlock Generator. Ignore the GM XT device unlock code and the top Generate button.
5. Selected Map Product as Custom and entered the code given for the downloaded image file.
6. Hit the bottom create button to generate a 25 digit code.
7. Download Img2Gps and run
8. Click Load Folder to load the image file. Select the tick next to it.
9. Check the Use Unlock Key option and paste the 25 digit code in.
10. Load a blank SD card into your Garmin
11. Connect the Garmin to your PC using a USB cable. You should see two dirves in windows: one is the Garmin and the other is the "Removable Disk" SD card.
12. Create a folder called "Garmin" on the SD card
13. Select Folder/Card in Img2GPS
14. Click "Copy Maps". Select the folder /Garmin on the SD card. You may need to click copy again.
15. Upload will take a while.
16. You should now see a file GMAPSUPP.IMG on the SD card in the /Garmin directory.
17. Create a new text file called GMAPSUPP.UNL in the same directory (make sure it does not have a hidden .txt extension).
18 copy the 25 digit unlock key into this file.
19. Close the file.
20. Disconnect the Garmin.
21. On Startup it should load your original maps and the new ones.
May 28, 2009 | Garmin nuvi 200W GPS Receiver
GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
This error is caused by a corrupt or missing map unlock code. Please email me @ sharcnet-usa@sharc.net and I will talk you through on how to fix the problem.
- Jim
SHARCNET-USA
Apr 22, 2009 | Garmin nuvi® 200 Car GPS Receiver
I had the same issue..what a pain in the ****.
I came up with a solution that worked for me.
After the update i deleted gmapprom.img and then created my own map using the garmin MapInstall program. start>programs>garmin>mapinstall
Apr 11, 2009 | Garmin nuvi 200W GPS Receiver
Unable to unlock maps for garmin nuvi 200 I am having trouble getting new stuff on my Garmin Nuvi 200. I registered it thinking it would let me download mapsource and it didnt. So then I got a pirated...
Here's a thought: instead of trying to install pirated maps which don't/won't work on your unit, how about actually buying the maps which are guaranteed to work. You will get a free copy of Mapsource on the disk with the maps of Europe.
Feb 01, 2009 | Garmin nuvi 200W GPS Receiver
- Jim
SHARCNET-USA
Jan 11, 2009 | Garmin nuvi 200 Car GPS Receiver
GPS Logo
1,488 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
