Question about EnGenius Computers & Internet
Resetting EnGenius EOC 3610
How can i reset EnGenius EOC 3610.I fogoten its IP Address.
    Master:
  • 351 Answers
Dear Venmattey,
please follow these steps, it works:
1. Connect the EOC-3610 to your computer with a null modem serial cable.
2.Start a HyperTerminal session: Click Start and then select Programs-> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3610.
b. Select correct COM port. Ex:COM1.
c.Set baud rate as "38400", data bits "8", parity "none", stop bits "1",and flow control as "None". Then press “OK” to bring up theHyperTerminal window.
d. Unplug the power on the POE injector and wait 5 seconds then plug the power back in.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
NEW: Keenan Systems has written a software that will soft reset the 3610 series back to factory reset. Thisfree software is provided "AS IS" by Keenan Systems and is notsupported or guaranteed by EnGenius Technologies. Use at your own risk.
Be Happy Always
Regards
Posted on Dec 03, 2008
I have a Engenius 3220, can't access on 192.168.1.1, I was change the firmware and can't connect now... are another IP to access, I try whit DDRT tool but not can see the IP.-
Try the program Belarc Advisor. It worked for me. I had the same problem when I updated the firmware of my EnGenius ERB9250 Extender. Once Belarc has displayed everything it has discovered about your computer, scroll down to the area labeled Network Map. There you will find your EnGenius 3220's IP.
Aug 22, 2011 | EnGenius EOC-3220 (EOC3220)
My Engenius access point is having problem wth the resettings. when i reset it, it fail to recongnise the default user name and password, but it recognises the default IP address
Assuming you are using the proper serial channel reset procedure, this should not be occurring. If it is occurring, your unit is probably malfunctioning and cannot be corrected.
Aug 05, 2010 | EnGenius EOC-3220 (EOC3220)
I forgot ip address of my EOC 8610. how do i
Try address 192.168.1.1 in most cases this is default IP for the routers.
Sep 23, 2009 | EnGenius / EOC-8610 EXT / 54Mbps /...
Username password
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
Apr 18, 2009 | EnGenius EOC-3220 (EOC3220)
Trying to get into my engenius 3220.using 192.168.1.254
If you have lost track of what IP address you have assigned your 3220, you can use the serial reset procedure documented here to return it to factory defaults:
http://www.engeniustech.com/datacom/support/general-details.aspx?id=65
Apr 16, 2009 | EnGenius EOC-3220 (EOC3220)
How do i reset my engenius senao eoc 3220 outdoor radio
back side one reset button is there pull out the power cable then pull in that same time you have to press the reset button for three to five sec then all lied's blink all to gather then your default ip address is came then you again configure at default ip
Apr 15, 2009 | EnGenius EOC-3220 (EOC3220)
Eoc3220+ ip finder
hi
reset your eoc 3220 and put the default ip address is 192.168.1.254 bridge mode and ad mode ip is 192.168.1.253 and put your pc ip 192.168.1.10,12,14,16 and open the web page and browse the 192.168.1.254 or 192.168.1.253 put user name and password ok!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Oct 07, 2008 | EnGenius EOC-3220 (EOC3220)
Engenius EOC-3220+
if you have a the router's manual,there is a guide on how to do that.
but in case you dont have the manual go to the device website and get some guide.default ip varied from different manufacturer
Apr 18, 2008 | EnGenius EOC-3220+ (EOC3220PLUS)
EOC-3220+ flash reset probs
Hi..
I had that problem too.. I scan the radio IP with Dude, software that come free for mikrotik.. and I got 192.168.1.245 for my radio. since that day I know that 3220 will go to that IP after flash reset. the mode will be Ap only, if you change to AP on operational mode than it will go to the standart Ip either 192.168.1.1 or 192.168.1.2
Hope this will help
Apr 02, 2008 | EnGenius EOC-3220 (EOC3220)
Computers & Internet Logo
3,096 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
