Question about Cameras
Technics SUX 902 AMP when switched on the lights do not light up,so im unable to play anything there is power going through as the other components light up tape dec tuner etc
2 Suggested Answers
SOURCE: no lights to sux 902 amp when powered up
Have now taken amp to a local repair shop as there does not seem to be any answers on this site :-(
Posted on Dec 04, 2008
There is power going through my technics 1210,but the platter & strobe light still will not work
how do you know theres power to the unit if theirs no strobe light pitch adjuster light & the platter doesn't spin?
the power comes in & to the transformer first,then through the strobe switch, the transformer is what blows when you short the target light out.....i've seen this many a time when people try & change the target lights to blue neon.
Mar 04, 2013 | Technics SL-1210 Turntable
I HAVE BT INFINITY BROADBAND - WORKING OK - I AM USING IT NOW VIA ETHERNET CABLE TO LAPTOP. HAD COMTREND POWERLINE 902 NETWORK SET UP AND WORKING. WAS ABLE TO ADD 2 MORE ADAPTERS - OK. BOUGHT 2 MORE AND...
The modem is probably still looking for the MAC address of your laptop at this point.
You need to unplug the modem AND the 902.
Power up the modem first and give it a minute to let the lights settle then power up the 902
Once the 902 is powered up and it's lights have settled down, start powering up devices that connect to the 902.
You may be surprised that this is all it takes!
Mar 12, 2011 | Comtrend Computers & Internet
2 green lights on console, switches off and menu comes up in game play
no this is easy to fix go into your settings and change the option that say sreensaver and power off its what lets your xbox 360 to go "im being used so im gonna turn myself off now" now about the profile thing im not sure but how to fix that problem but i hope that i helped with the first problem
May 07, 2009 | Microsoft Xbox 360 Pro System Console
No lights to sux 902 amp when powered up
Dec 03, 2008 | Technics Audio Players & Recorders
My amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
Nov 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
Wont boot fully boot up.
Try reseting your PS3. Turn your PS3 completely off by the switch in the back. Then flip the switch back on. Press on the power button and hold it until the green light comes on, beeps twice then the green light should go out, replaced by a red light. Then turn it on normally.
Nov 21, 2008 | Sony Playstation 3 (PS3) Console
Problems with the Operation circuit on Technics SU-A900 MKII aplifier.
Hi There Cushy,
The Amp needs Power.....and if the power switch is turned on and the light doesnt come on then there is no power....
Have a good look around the back of the amp and see if you can find a fuse please...
Its a small circular plastic item labelled "FUSE" with a screwdriver slot in it..
Turn the power off at the wall socket then unscrew this fuse holder, the glass / ceramic fuse will come out,,, replace it with one of the same physical size and of the same rating probably 1.5Amp.
Turn the amp back on and it should go if not then there is a major failure inside the case.....Needs a serice call Im afraid....
Cheers From YUBEUT
Nov 17, 2007 | Audio Players & Recorders
Expensive garbage???
Were you playing in Vinyl mode? These are very good CD players, however, there are some glitches with the firmware, which just needs to be updated. If you sent the warranty card in, you would have been sent the firmware upgrade and instructions. Were you playing a CDR? Or was it a regular CD?
Oct 08, 2007 | Technics SL-DZ1200 CD Player
Playing my music, then amp goes out? anyway to fix it?
Looks to me like u are having a power problem. Check if power is going to your amp, if yes, check the fuse on the amp. If ok, check the powersupply section for any damage components and replace.
Dec 18, 2006 | Sony XM-2200GTX Car Audio Amplifier
Cameras Logo
83 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
