Question about Plumbing
Kitchen faucet Remove
How do I remove my old faucet? I have a single spout for hot and cold water. Is the solution the same for two valves? The leak is just under the single spout for hot and cold water.
    Problem Solver:
  • 9 Answers
All faucets have a hot and cold line input. The single handle units have a mixing valve within the handle. Aside from removing the water lines there is usually some type of connecting bolts for the base plate as well that will need to be removed prior to removing the faucet. Do not forget to turn the shut off valves off at the wall before you remove the water lines.
Good Luck
Posted on Dec 04, 2008
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Faucet leaking at tee where hot and cold connect to spout
    The designs of the Kitchen Sink Faucet mainly exhibit differences in its handles and spouts. Differently curved spouts and handles diversify the range of products. Some have long spouts and some are with short ones. The spouting of water may also give different flow patterns with the external fixtures. The handles are mainly in single or double.
    source Best Kitchen Faucets
    Feb 03, 2012 | Kohler Fort© Widespread Lavatory Faucet...
    Our single handle faucet began leaking severely today. After taking apart and getting some new gaskets & replacing, I can't get the water to turn on after puting back together. What could be the...
    Take the cartridge out, Place a mug style cup over the open faucet. Now if your arms are long enough you can do it alone. If not have some one under the sink and open the valves both hot and cold.
    You might have left junk inside from the old cartridge. Then place your hand on top to cover the hole where the cartridge was and see if water comes out of the spout,
    If you done get water out remove the spout and clear ir and put it all back together again.
    Be safe. Best of luck
    Tom
    If you could please rate us so we can know if we are doing a good job. :)
    Sep 10, 2011 | Moen 7840 Camerist Single-Handle Kitchen...
    No Hot water coming out when single handle on hot water side.Cold water comes out fine. Water in the lines leading to the taps, but no hot water coming out. This is a bathroom faucet Moen single handle.
    Cartridge removal is a simple matter of exposing and pulling out the old cartridge. Before getting started, turn off both water valves underneath the sink and allow the water to run until the line is clear. Using a screwdriver, gently pry off the cap on the lever of the faucet handle to expose the cartridge. Remove the U-shaped retaining clip that holds the cartridge in place and pull the cartridge out. If dirt or residue makes removal difficult, use a Moen cartridge puller to assist you. A cartridge puller fits over the cartridge and gives you greater pulling power.
    Soak the dirty cartridge in vinegar for four hours and replace.
    If cleaning the cartridge does not work, call the Moen Helpline at 1-800-465-6636 or Customer Service at 1-800-465-6130 to order a free replacement. Locate the part number on the cover page of your instruction manual. If you no longer have the manual, look on the underside of the spout.
    Feb 08, 2011 | Moen Monticello Single-Handle Kitchen...
    Leaky moen 2 handle faucet
    if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
    Apr 26, 2010 | Moen Monticello Single-Handle Kitchen...
    The hot water side has low water pressure. The
    start by making sure the valve that supplies hot water to the sink and dish washer is fully open. If there is low hot water pressure in any of the other kitchen/bathrooms, then trace the line to see where the pressure drops. If it is only in the kitchen, it should be an old valve, (causes restriction)Good Luck.
    Oct 10, 2009 | Whitehaus Kitchen Single Handle Faucet...
    Leaking Kitchen Tap
    I am assuming that your kitchen tap is leaking through the spout
    if it is single lever you will need to remove the crown and spout by removing a small erasure size cap on the housing right under the spout or up near the back of the ever then use a hex wrench to remove the set screw( plug the drain holes do it does not go down the drain)
    turn the water off (hot and cold ) under the sink
    remove the set screw and lift off the lever
    at his point you can take an adjustible wrench(channel lock and tighten the big ring nut that holds the cartridge in place
    temorairly put the handle back on and put the handle in the off position turn the water on under the sink and see if it stopped leaking
    if it still leaks you have to turn the water back off and remove the lock nut then the cartridge and go to big box store with old cartridge and name of mfg and get a new one and install
    If you have seperate hot and cold valves on top of sink deermne which is leaking by turning one off with oher on undr the sink
    once you have determined which it is (hot or cold)
    take a phillips head screw driver( remove plastic clear cap on top of faucet handle with sharp crewdriver of knife blade) and remove the screw holdin the handle on to the stem(turn counter clock wise
    be sure to turn water of under snk on both faucet risers after removing acrylic handle you then take an adjustible wrench and remove the crown nut turn counter clockwise until it comes off over stem
    remove stem( looks like size of a pretzel about six inches long with washers on side and one on end
    take the stem to local hardware(ace) or big box store and go to lumbing section ask clerk to inspect and recommend replacement washers or replacement stem (if needed)
    go back reinstall and tighten crown nut snug( open (turn counter clockwise) tem valve before you snug it down with crown nut
    install acrykic or chrome handle with brass phillips screw then ut cap on and turn on water and check for leaks
    good luck
    Dec 30, 2008 | Home
    Sprayer loosing presure
    If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)
    Here are the instructions:
    1. Turn off water to faucet.
    2. Remove handle.
    3. Remove top cap.
    4. Turning spout back and forth gently lift and remove.
    5. Remove and replace diverter.
    Hope this helps and please remember to rate this!
    Dec 09, 2008 | Delta 2402 Classic Single Handle Kitchen...
    Loss of pressure in kitchen faucet - Price Pfister
    Your problem is a simple one.
    2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
    3. Remove the handle to the faucet. (single handle only)
    4. If not a single handle then remove spout from faucet.
    5. If a single handle remove cap carefully and any loose parts.
    6. Gently turn spout side to side while lifting to remove.
    7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
    1. Remove this valve (which is a backflow preventer) and replace.
    2. Reassemble and test.
    Problem solved.
    Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
    Low pressure and flow on hot water side of single handle faucet
    It could be one of two problems, one simple, one serious.
    • Easy fix
    1. Turn off hot water angle stop under sink to faucet.
    2. Remove supply line from hot angle stop.
    3. Place end of supply line in a small bucket to catch some water.
    4. Turn on cold water for a couple of seconds and backflush debris from faucet.
    5. Reconnect supply line.
    6. Turn on angle stop and test
    • Complex fix
    If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
    Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
    Nov 14, 2008 | Delta Faucet Plumbing
    Plumbing Logo
    222 people viewed this question
    Top Plumbing Experts
    Paul Carew
    Tom Chichester
    Are you a Plumbing Expert? Answer questions, earn points and help others
