Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Flashing green light on Sears garage door wall opener HBW0777 1/2
What is causing this flashing green light . The door is not operational using the car remote, and more often than not it won't open using the wall remote either. Sometime the door will open using the wall remote. It just seems to have a mind of its own. this unit was manufactured in 2/93. Is it worth repairing?\ Thanks very much
Dianne.
  • Anonymous Dec 06, 2008
    I've heard that the flashing green light means that the remote lock has been activated from the hard wired opener control. I was told that if you press and hold the lock button for two seconds it is deactivated, but even after doing that my remotes will not work.
  • Anonymous Feb 26, 2009
    Pressing the green button on the opener made my remotes start working again. I had the same blinking light problem and have no idea how it got into that mode.
Same problem - The flashing wall button indicates the remotes are locked out. I fixed mine by pushing the green button on the back of the opener. I did nothing else , just left the LED time out.
Posted on Dec 13, 2008
  • tanderson007 Dec 10, 2010
    This is what worked for me! Thanks so much! Mine is so old school that there's just the "doorbell" button on the wall with the light but no "lock" button, so I just pressed the green button on back and poof, good as new! :-D Thank you!
  • Pat Mahoney Jan 07, 2013
    Thanks so much for all your help. I fixed my flashing green light by depressing the orange learn button but my remote would still not work. Then I pressed the learn button and then my remote and the whole thing was fixed. You guys just saved me a big bill.
You are correct it locks the door in place and can be unlock by holding the button in place then the light should go solid.
You might have to reset or recalibrate remotes to activate them.On newer units there is a button on back of the opener that you push to reacivate the remotes. Look in your owners manual.Maybe by chance you need a battery?
Posted on Dec 10, 2008
Good suggestions!
I had the same problem and was going to buy a new printed circuit board until I read these postings. All I had to do was re-program my remote (duh!). Instructions for this are on the rear of the opener unit.
Posted on Feb 13, 2009
Just read the post, and got up on the ladder. Mine is a dual light unit, opened the cover where the ceiling wires lead, and depressed the LEARN Button.....All Good
Posted on Sep 03, 2010
Craftsman Model 139.53684 Security+ Keyless Entry Garage Door Opener... Green light flashing on door control push button. Remotes no longer work. Can open and close garage door from keypad. Why is light...
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Dec 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
One of the buttons has a lock icon. Hold that button in for 3 seconds.
May 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage opener not responding with remotes, keyless pad, or wall console. Can hear it click but nothing happens. Green light in opener blinks 5 times. When i reset the green light stays on until i try to...
UNPLUG UNIT TO RESET.
IF IT STILL FLASHES 5 TIMES AND MOVES 6-8 INCHES REPLACE RPM SENSOR.
IF IT STILL FLASHES 5 TIMES AND DOESN'T MOVE REPLACE LOGIC BOARD.
Apr 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Opener Lights
Some craftman operator don't have that feature. Are both photo eye lights green? Feature not available. If the photo eyes are yellow and green feature should be avilable. The operator needs to have a three button wall station. With the light on the operator off press and hold the "light" button for about a minute until the light flashes.
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage Door only opens with wall unitq
The unit is in the lock mode, push and hold the lock button in for about two seconds and the green LED should stop flashing. Your remotes should work.
OLDER SEARS GARAGE DOOR OPENER WONT OPEN GREEN LIGHT FLASHING
do you have the sensors at the bottom of the door? if so they might be out of alignment. all you have to do line them up by getting the green light solid. let me know if this helps you.
Dec 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Green light is flashing on my garage door opener on the inside of my house/craftsman opener
Hi. The green light was flashing and ny transmitter in the car would no longer operate the door. On the back of the liftmaster, just below wker the small wires go in, there is a small, flat, green button. I pressed that with a stick and it solved the problem.
Jun 27, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
9,188 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
