Question about Panasonic CT-34WX54 34" TV
Picture on Panasonic tv intermittently becomes striated and bottom half of picture shows on top half of screen
I recently bought a Panasonic tv (28 or 32 inches, non-flat screen) from a thrift store, and it seems in very good condition. Sometimes a movie will play all the way through fine, but frequently the picture becomes striated and flickers, and the bottom part of the picture will show on the top third of the screen. The effect resembles when the tracking on a VCR is off (except the picture doesn't scroll up or down). Any help or ideas given would be greatly appreciated! Thanks! Leah
    Novelist:
    Champion:
  • 236 Answers
Hello! What you're describing sounds like a vertical deflection problem if it also occurs when you're watching a TV program. This type of trouble is a component failing in the vertical circuit of your set. A loose solder connection could cause this. On the other hand, if it just happens when you run the VCR, your problem could be somewhere in the tape drive mechanism or possibly a bad tape. Things like slipping clutches,bad belts sticking guide rollers are a few things that will cause this in a VCR. You need to have a tech check it for you. Hope this gives you some help. Stargazer
Posted on Feb 12, 2007
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
I had my 50 inch panasonic veira flat screen tv on when it was thundering in lighting in now i have no hd
Hi Carlos,
Thundering and lightening can damage your set in many ways. Sometimes if you are lucky, you escape with a blown fuse and some minor safety components damaged. Well open the back cover and see if the fuse is blown. If there is no other visible damage, try a new fuse of the same rating. If the tv works, well and good and if the fuse blows again, please consult the TV tech.
Good luck.
Apr 16, 2015 | Panasonic Tc-p50x3 50-inch Viera 720p...
Hi , I have a sony wega Trinitron 29" TV ,but my tv screen is not rectangle form and is vertical side is zoom in??
The driver transistor is gone . get another wega from a thrift store if you want for $10 or craigslist. CRT 's are getting harder to dispose with the lead shielding. you could pick up a flat screen for not much these days, Plasmas look more movie like
Mar 08, 2015 | Sony Televison & Video
WHITE PICTURE
my TV has a half black & half white screen & half of the TV is showing the picture including the normal sound,what can I Do,?
Dec 11, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic plasma tv th42px8ob 2 inche vertical line showing
do the proper isolation proceedure and try unhooking the Su from the SC board to see if you then get a normal picture all the way across the bottom half of the screen? I am assuming the Vertcal extends extends all the way from top to the bottom of the screen?
Aug 06, 2012 | Panasonic Televison & Video
I have a rca truflat i can't get the dvd to play
are you sure you have plugs and source input the same.the tv has several diff.inputs look on back what inputs you are using then go in menu move input to the same
Dec 24, 2011 | RCA TruFlat 27F520T 27" TV
MY Panasonic TV Model TX -33P100X showing half picture and half black screen. When switch off and on again sometimes the picture reappear.
hit your TV on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board ( also on CRT circuit board ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width, or rolls etc ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears normally for some time............so solution is .....TV main board & CRT circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer & just ask him to resolder joints ...........
Jul 29, 2011 | Panasonic Televison & Video
Panasonic CT-34WX54 34" TV Logo
121 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
