Question about Sony Cybershot DSC-T200 Digital Camera
How to set up camera for Automatic Pictures?
I'm trying to take a picture of me and my friend but no one is around to take the picture. How do I set it up to take a picture automatically by itself after say 5 seconds?
You can easily set you self timer - it's on the back touch screen -
Posted on Dec 03, 2008
Why are my pictures are blurred and have a pinkish hue
I don't know why. But if I had the camera in my hands I would check the settings. If the camera was in Automatic In the menu settings. Also how the White balance was set. It also should be in automatic.
It is great to try to achieve better pictures, by changing the settings, but the best thing to learn is to switch all settings back to automatic, when ready. So the next time you use the camera you won't get surprises.
If the quality of the pictures does not become better after you switched to automatic, you should contact a Nikon certified repair centre close to you.
Jul 26, 2014 | Nikon Coolpix S6200 Digital Camera Red...
THE PICTURES ARE WAVY.
Try messing around with the lighting options in the camera, since certain lighting settings give different results than expected, for example, setting the camera for low-light pictures in daylight.
Setting it for automatic should solve the problem
Jul 26, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
WHY DID MY PICTURES LOOK DARK WHEN I TOOK THEM OUTSIDE USING THE AUTOMATIC SETTING?
Was everything set automatic?
Was it a cloudy day?
Did you take pictures in the sun of an object in shadow?
Are your indoor pictures normal?
If you are sure everything was OK, no shadows, no bright objects in the picture, ISO was not set 400, flash was not forced on, etc., call Canon. There are adjustments that calibrate the camera for outdoors. It may need to be recalibrated.
Apr 02, 2010 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Fuzzy pictures
If you have not dropped your camera or otherwise caused damage that would explain the change, then you should first check the settings.  Your camera has both automatic and manual exposure controls.  From what you wrote I expect you want to use the automatic settings.  First check the "dial" on top of the camera, which has a green AUTO setting.  Your manual should explain the settings in  further detail  if necessary.
May 21, 2009 | Canon PowerShot A540 Digital Camera
I take pictures for a very small school. One of the issues that I continue to run into is while taking pictures in the gym (1932) the lighting makes the pictures turn out mostly yellow. Is there a way
By using the manual white balance adjustment on most cameras, you can "filter" out the yellowish color cast you are experiencing. The adjustment is best made while standing in the area in which you will be shooting. You will see the shift in color on the camera's LCD as you switch from setting to setting. On most cameras adjustment to white balance requires you to take the camera off it's fully automatic setting.
May 21, 2009 | Canon Cameras
My daughter tries to take pictures with her Sony Cyber-shot S650, but all she gets are blurry pictures. What can she do to fix the problem.She has been taking pictures all along with no problem.
She may have shut off the automatic setting for the flash. This will cause blurry shots in darker areas. See if her pix outside in day light are okay. If so, the main wheel on the back of your Sony (I believe it's the top of the wheel) controls the flash. Be sure that is set to on or automatic. Let me know.
Jeff
Mar 27, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
INDOORS PICTURES - NIGHT PICTURES
The best basic setting is FULL AUTOMATIC. Otherwise, there are too many variables to give you an accurate answer.
Feb 20, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My Canon EOS Digital Rebel XT is taking pictures darker than normal. Why?
First, to test be sure you are in Automatic mode. The dial should be on the Green Box setting. If its on other settings its in manual mode and can be set wrong. take a test picture in this mode, If its looking normal, then you were either int he wrong mode or your manual settings were off. But if they are still dark try your ISO settings, if too low a number it will result in dark images. For example ISO 100 is perfect for outdoor daylight, but ISO 400 is better indoors.
Next try the F stop settings and arppreture. If things improve, you have found the issue. This camera is professional grade so it will do exactly what its set to do even if the outcome is not what you want!
Whe all else fails use the menu and reset the camera to factory defaults.
Dec 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
My pictures are too bright
How much do you know about your camera settings? Possibly you changed a setting. Try taking photos in full automatic mode.
May 02, 2008 | Canon PowerShot A520 Digital Camera
Poor quality images outdoors
try setting your camera's auto balance into Automatic or Outdoor. So the camera could adjust the light or diable flash.
Nov 27, 2007 | Canon PowerShot A430 Digital Camera
Sony Cybershot DSC-T200 Digital Camera Logo
91 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
