Need to know wats the max memory does this Averatec av1000 takes?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
All depends on how much you use your Machine. IE do you have 15+ differant things open at once? Also depends on how many Ram Slots are on the board (Usually 2) So if you want a hassle free PC without any freezing windows, I'd say put 2GB in Max if you intend to run alot of programs altogether that is. Installing more the 2GB of Ram in a PC is pretty much a waste of money, as you won't see much of an improvement in performance.
Posted on Dec 03, 2008
Can I add more RAM to my Averatec All-In=One A2?
Hey Nella Coffey
Unfortunately, more RAM cannot be installed due the limit of Slots available. However, you may be able to upgrade the current RAM modules and replace them. It appears it has 2048mb (2GB) of RAM which is possible split into two 1GB sticks. You "may" be able to upgrade to 4GB (split into two 2GB sticks). This is the current set up for the computer: 2048MB (4096MB max) SDRAM ' Memory Slots available for Upgrade: 0 ' Maximum RAM per available slot: 2048MB
Good Luck
Jul 29, 2012 | Averatec AllInOne A2 Desktop
Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • Jul 20, 2011 | Biostar K8M800-M7A Motherboard
    How much ram can I install on my Averatec 2200?
    The ram maxes out at 2GB. There is only one memory slot, so you would need a 2GB memory stick. Hope this helps.
    Regards,
    Matt
    Apr 15, 2011 | Computers & Internet
    I would like to know the type and max ram amount that can be installed on my laptop part # av3270-ee1 it says it has 512 now so I would like to go to 1 gig. I also have some keys in operative, shift...
    Welcome to Fixya. Memory Upgrade for Averatec AV3270-EE1 Laptop, the Averatec AV3270-EE1 Laptop takes the PC2700 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your Averatec AV3270-EE1 Laptop to up to a maximum of 1.0 GB Memory, the system has 1 socket to install Memory, already with 512 MB (removable) standard Memory installed.
    Thanks for using Fixya.
    Feb 07, 2011 | Averatec 3200 Notebook
    RAM for AVERATEC 3120V
    Max for this form factor is 512mb. It can be upgraded. Here is step by step instructions
    http://www.gearhack.com/Forums/DisplayComments.php?file=Computer/Notebook/Max..ing_Out_Memory_on_the_Averatec_3120V_Slim_Notebook
    you can buy the ram here for about 18 bucks with a credit card and free account setup
    http://cgi.ebay.com/Viking-512Mb-PC13364X64CL3-512MB-PC133-SDRAM_W0QQitemZ120445441132QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0b1b946c&_trksid=p3286.c0.m14
    Good Luck! Your Amigo!
    Ruben
    Jul 28, 2009 | Averatec 3120V Notebook
    I need to update my AVERATEC 3200 memory how can I do that?
    Hi
    Buy the RAM and then connect to the notebook
    here u can buy the rams
    http://www.memoryx.net/av32senome.html
    http://www.memory-up.com/Memory/Averatec32002578.html
    Thank you
    Dec 12, 2008 | Averatec Computers & Internet
    Where to find the cmos battery on Averatec 5110
    I don't know if there are multiple revisions where the CMOS battery located, but this information is from my 5110H, built in September 2003.
    The CMOS battery is underneath the motherboard, between the main battery, memory, and wireless card. The approximate location is shown by the green circle in the picture below:0692552.jpg You might be able to just see it by opening the memory cover and looking sideways into the case.
    To actually get to it, I think you will have to take it completely apart and remove the motherboard. I don't think there's enough room to pull it into the memory bay, but I guess you could try that first.
    The battery is connected to the motherboard with wires and a connector, rather than being in a holder. It's stuck to the motherboard with thin double-sided tape, but that comes off fairly easily.
    The wires run around the right and lower edges of the thin black plastic chip cover shown above, to the white connector at the lower left corner of the cover. No need to peel off the entire black cover- you can lift the edges to get the wire out.
    Since my battery is still good, I didn't cut open the shrink wrap around it. So i don't know whether the wires are welded/soldered on or if there's some sort of holder inside.
    Sep 04, 2008 | Averatec 5110HX Notebook
    Memory location
    Is it an ED1 or EH1?
    Nov 29, 2007 | Computers & Internet
    Memory installation
    With the way computers are setup now it is plug and play and it will be recognized the very next time you reboot your PC. Find the appropriate memory based on your PC. Make certain to get the right memory based on your PC specifications. It takes a philips screw driver, locating the memory slots removing the old and placing in the new! If you need more help just let me know! It is really quite simple!
    Nov 26, 2007 | Averatec AV1020-ED1 Notebook
    Computers & Internet Logo
    David Payne
    David Payne
