Question about Food Mixers
Hobart d300 mixer
Hi bigg t,
on my d300 mixer, the motor runs fine, but the planetry turns very slow and weak. can stop it easy by hand. how can i take out the mainshaft with the gears?
planet came off, no problem. the top screws and bolts came off with no problem as well. but nuw, i can push the shaft up only about 5mm.
can you give me some advice please? - and send a servicemanual.pdf if possible? (
thanks in advance
  • 41 Answers
The main shap on this type seizes onto the bearing hub you need a shaft puller or use a jack placed under the the main shaft aand a board across the bowl lift arm and slowly jack up the shaft make sure you take off the lower mixing hub assy. first also remove as much as you can of the secondary shafts first and the shifter
Posted on Dec 11, 2008
Hobart Mixer D300, When mixing mashed potatoes paddle will only turn in low gear. When product is mashed with milk added it sometimes will turn in 2nd gear, but never in top. When this happens, motor is...
Sounds like the keys in the shifting sleeve may be sheared. The transmission will have to be disassembled and checked for broken parts. Check for your local Hobart office.
Jul 07, 2011 | Hobart D300 Stand Mixer
Having problems figuring out what is wrong with my older d300 hobart mixer. Mixing dough the other day the agitator slowed down until it stopped, then the motor just buzzed. It did this twice and the...
Could be a bunch of different things. Depending on how old the mixer is, brushes at the back of the motor. If the brass armature is worn down I have been told its too expensive to replace. They haven't used brushes in 25 years. There are a number of bearings that could be going bad. If the main bearings at the back housing or at the gearbox are badly worn, they may be letting the armature come in contact with the windings. If that is the case the motor will be really hot when running. One obvious question is do you have the proper lubricant and have enough of it? Remove the top cover then pop the inspection hole cover off with a screwdriver. The grease inside should be the consistency of heavy wheel bearing grease. If you had a slug of it on a tablespoon it would stay on it if you turned it upside down. It is a food safe grease available at Hobart parts stores. If the lubricant is thin like motor oil, it is totally worn out and is probably not lubing your bearings at all. One other thing to look at is capacitors. A capacitor looks like a large flashlight battery shaped black object with two wires running from one end of it. It is usually located behind the mixer bowl behind a plate held on by two screws. If your mixer has a "run" capacitor, it may be bad. Remove it and head for WW Graingers or such supply house. Get a capacitor of exactly the same voltage and microfarads. Hook it back up and give it a shot.
Back to the bearings. The main motor shaft should have no play at all if you try to wiggle the shaft up, down or sideways. If it does, the bearings are available at industrial supply houses and are not realy hard to replace if you go slow and have a lot of patience in taking things apart and keeping them in the proper order to reassemble.
Sep 10, 2010 | Hobart D300 Stand Mixer
How to remove key from D300 Mixer to replace stripped gear
Keys are removed using a small punch and a hammer. The punch of choice is called a ***** punch
Jul 10, 2009 | Hobart D300 Stand Mixer
D300 Floor Mixer faulty bowl guard switch
If you remove the bowl guard you will see a magnet that attaches on iy in a white housing.The scews come loose and prevent it from closing the switch.Also the switch which comes out of the top pedestal can be adjusted.Let me know.
Mar 29, 2009 | Hobart D300 Stand Mixer
Hobart D300T mixer oil change.
Call your local hobart branch and tell them you need grease for a d300 mixer.Yes this mixer uses grease now.If it's older they used oil but is no longer available.
Mar 15, 2009 | Hobart D300 Stand Mixer
Beater mechanizim runs very slow and will not change speed
It sounds like you sheared a key in the transmission.Does any gears work?were you using 1st gear for dough?
Jan 15, 2009 | Hobart D300 Stand Mixer
Second Gear
Sorry so late for the reply.When the product slows down---how slow?can you grab the shaft and stop it from moving?What product are you mixing?
Feb 05, 2008 | Hobart D300-6036 Mixer
Motor is not running now
Im a service tech for hobart and repair these mixers often-is it worth repairing the unit?YES it is.I have never seen a motor burn up on these units,i have seen keys sheared and gears broken but thats the extent.There is a overload/reset button that sits on the back of the mixers pedistal,if its tripped when you push it in it will click.when these units need service it is usually from overloading the unit with too much product.Any other questions let me know.
Nov 30, 2007 | Hobart N50 Stand Mixer
Food Mixers Logo
160 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
