You are awesome
For so little having to be said, you are "THE BIG WIZ". You sent me to two locations that I have spent hours looking for. This is one site I have bookmarked for future advice. Well worth the money, no matter how much it costs. Again thanks for help. When time is money, FixYa saves mucho time.
Ron
With out on
I hope you have another computer by you because you need to link your Datawind UbiSurfer 9" Netbook to a PC or laptop via USB cable. On the PC Google :Driver Wiz and download it.
Click My Computer and locate the main drive of the Notebook,
Go to the desktop of the PC and find Downloads, locate the downloaded Driver Wiz, hold down the Ctrl botton and let mouse button and drag and drop the Driver Wiz file on to your notebook drive. Having done that while still wired to the PC Click the Wiz Icon, Install it and then Run it. Then boot up your notebook, with refreshed and updated drivers on board I think this might do the trick. Goog Luck and Feliz An'os, Happy New Year. Arnie
Jan 07, 2014 | Datawind UbiSurfer 9" Netbook
HI there - I just spent several hours fastidiously cleaning my stove, per the last email advice sent to me, and they still only turn on and stay on if you leave them on, clicking away, for about 15...
Hi jenny621,
Moisture or water is shorting out your ignitors. Please follow my below Tip on repairing the problem:
GAS COOKTOP CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 04, 2011 | Cooktops
The faxes being sent print out with vertical lines down the middle
There is a little scanner in the fax machine that reads the page so it can be sent out. You should be able to open the top, similar to changing the toner, and locate the scanner. This should have some glass over top protecting it. Just take a damp cloth and clean that piece of glass. There is most likely a small piece of dirt on the glass, but when it scans paper it looks like a big streak.
Jan 10, 2011 | Samsung SF-560 Plain Paper Laser Fax
WD52525 Mitsubishi Tv will not turn on with remote or panel swt. Unit has power but nothing happens. Tried reset on front.
LOKK UP THIS GUY , HES NOS HIS STUFF HE FIXED MINE FAST CHEAP, GET ON EBAY LOOK UP TVB SERVICE HIS NAME IS HONG BUI LITTLE HARD TO UNDERSTAND , BUT YOU WILL , HIS NUMBER IS 713-401-7701 HE USED TO WORK FOR MITSUBISHI AND HE A WIZ AT THESE TVS TELL HIM DAVE SENT YOU
Aug 16, 2010 | Mitsubishi WD-52525 52" Rear Projection...
TV want power on, timer light is flashing green, but system reset button will not work.
GET ON E-BAY AND LOOK UP TVB SERVICE, E-MAIL THIS GUY WITH YOUR PROLEM OR CALL HIM NAME IS HONG BUI 713-401-7701 HES A WIZ AT THESE TYP OF TVS HE JUST FIXED MINE , I HAD LITTLE WHITE DOTS ALL OVER THE SREEN AND EVERONE I TALKED TO TOLD ME LIGHT GEN WAS BAD TOLD ME 750-1000 TO FIX HE FIXED FOR 150.00 AND IT LOOKS BETTER THAN IT DID WHEN IT WAS NEW . TELL HIM DAVE SENT YOU
Aug 16, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Same problem with the black ink.
I have the same problem; have spent hours and days on this...no help from HP; they sent me to a web site for cleaning and the pictures did not even look like the C5180. Am ready to toss and go by a Canon.....
Aug 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
Can not locate fuse box under instrument panel
I spent a good hour trying to find the "instrument panel fuse box". I almost started ripping the wrong stuff off. Think they could have stamped it to identify it a bit better?
You must open the door, it's right there on the side. It doesn't look or feel like it should come off (piece with a vent hole of sorts). You have to really reef on it, it does come off.
Probably get a little needle nose pliers for getting the fuses out now.
Mar 11, 2009 | 2006 Pontiac Montana SV6
Vacuum hoses
They are the little (3/32 to 1/4 inch) black rubber hoses in your engine bay
Nov 27, 2008 | 1984 Ford F 150
Epson aculaser c1100
What you hoovered off is the developer. This is required by the print process. Hoovering it off means there is no way for the toner to get onto the paper. You must replace all the developer units and possibly the toner too. It will be cheaper to by a new printer i think.
You could try a claim on your insurance if you are covered for accidental damage.
In future, maybe you should call an engineer - it is usually cheaper than a new printer.
Nov 06, 2008 | Epson Aculaser C1100 Printer
A/C condensor location
Response on condensor. As I am not a mechanic, only a vehicle owner, I haven't spent much time under the hood, only to make temporay fixes I discover. Accessing the condensor is a mystery to me. The shop guys say "It's under that big boxy looking thingy against the firewall on the left." (And shop rates are $125.00 an hour!!!!.... I should be a millionaire!!) Sorry I don't have a good answer for you. Good luck!
Aug 01, 2008 | 1998 Dodge Dakota
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
