Question about Kenmore 62622 Microwave Oven
Kenmore Microwave hood combination model 721.62624
The power (noise while operating) drops as soon as I turn it on. The food gets hot but not as much as it used to for the same amount earlier. For example a cup of water is tepid after a minute now, whereas it used to be pretty hot earlier. Somebody please advice.
  • William Miller
    William Miller May 11, 2010
    Is your voltage at the power outlet correct at 110 to 125 volts AC?
    Is the internal cooling fan running when you cook?
    When I say internal
    cooling fan, I do not mean the hood vent exhaust fan which you can turn
    on and off manually.
    I'm instead talking
    about the internal fan which comes on automatically whenever you
    microwave.
    It is vital that the
    cooling fan runs, or the magnetron will be destroyed.
MicrowaveSvc
  • 9086 Answers
SOURCE: kenmore microwave 721.80412500
The owner's manual should spell that all out.
But if you don't still have yours, you can download one via Sears' "Manage My Home" site here. While it's free, you will have to register.
(You *may* be able to download it here without logging in. If not, go ahead and register. It's free.)
Posted on Sep 25, 2008
SOURCE: F7 Error code on Kenmore
On the tech insert found in a cavity under the cover of my Kenmore MHC, the F7 code means the inverter board ($90 - $130 street price Fall 2008) is bad and needs replacement. I am having this problem, and verified that the magnetron was not shorted to ground with an ohm meter. I verified with a volt meter that the magnetron was not getting any voltage applied across the cathode from the inverter board when the microwave is running ("WARNING"- don't do this test with the magnetron connected.) I have an inverter board on order.
Posted on Oct 05, 2008
SOURCE: Kemore Microwave Hood Combination
I HAVE KENMORE 665/61629 LIGHT STAYS ON. AND DO NOT COOKS. AND THE FAN DOES NOT WORK.
Posted on Jan 19, 2009
SOURCE: I have an error code
I would like to repair the kenmore mocrowave myself, it has the error code f-9. Do I need to let the micrwave sit for a wile so the hi voltage can disipate from the inverter or magetron
Posted on Aug 07, 2009
SOURCE: Kenmore Microwave Hood Combination oven Model Service code (SE) ?
I have Microwave Kenmore model 401.80082700 about more than a year. After about 6 months, it stated to have some probles such as some number keys not working. Then button START become nor working some times. I can use only button of 30 secon increment to cook something. OK, the fan is working for most of the time but the levels are stuck, not adjustable. I can't changer the fan levels. Now the lamp buton is dead. Sometime, the fan level control is working by itself level 1, 2, 3.... then it appears -SE- on the display. nothing work now. I unplug.... then plug back, it ask to input the time or date... I can't do any thing. Later some time I can cook by using 30 secon button.... It is anoying. Please how I can fix it? Thank you.
Posted on Nov 09, 2009
Speed queen noise when on spin
follow this test and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Nov 19, 2013 | Microwave Ovens
Microwave occasional loud buzz
make this test and fix it. God bless you
Nov 14, 2013 | Jenn-Air JMV8208AAS Microwave Oven
GE microwave occasionally buzzes loudly.
Nov 14, 2013 | Microwave Ovens
Made a grr noise then shut off will not turn back on
Nov 06, 2013 | Emerson MWG9111SL Microwave Oven With...
Buzzing noise
follow this steps and fix it. God bless you
Oct 23, 2013 | Panasonic Microwave Ovens
Sharp sound bar buzzing
test this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2hVe8AHvJ
Oct 12, 2013 | Microwave Ovens
Buzzing noise
follow this instruction and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2ZYUSVYSH
Jul 19, 2013 | Morphy Richards AM925EF Microwave Oven
Gh5184xps3 microwave
this cause noise ; God bless you
  • MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  • Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  • Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  • Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replace
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2ZPm395lp
    Jul 18, 2013 | Whirlpool Microwave Ovens
    The microwave is making a humming noise as it runs and the food does not get hot.
    your high voltage capacitor or diode in the high voltage doubler circuit is open and can't help double the high voltage to operate the magnetron tube to make food heat
    May 16, 2010 | GE JVM1630 Microwave Oven
    Kenmore 62622 Microwave Oven Logo
    118 people viewed this question
    Top Kenmore Microwave Ovens Experts
    William Miller
    William Miller
    Chuck
    Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
