Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Pioneer Tv SD-P4553
We have moved this tv a few times and now we have a black bar acrross the bottom of the screen, seems like the whole picture has shifted, is there a way to re-align this without a technician. I have tried changing the convergence settings.
  • mbusinger Mar 17, 2008
    i have the same problem, but the top of it is streched
  • sasmalley Mar 16, 2009
    Pioneer sd-p4553 rear projection need to adjust horizontal line at bottom of screen. Black line is at bottom of screen which makes remainder of screen distorted.
Also where can i find a schematic to replace that part?
Posted on Mar 17, 2008
    Genius:
  • 1,153 Answers
You have incomplete vertical deflection at bottom of screen. Replace C155(2.2uf@16v) on video/deflection assy. Use part number ACH1131
Posted on Aug 16, 2007
Pioneer Elite Pro-118 rear projection tv
ya mine did something close to the same. at the moment i covered the blue canon inside the tv now the picture isnt 2 of eveything. the tv comes apart easy from the front good luck mike
May 02, 2010 | Pioneer PRO-200 60" Rear Projection...
Bowing top and bottom temporary on cold TV
problem with unit is convergence--i would resolder convergence ics(they start with stk932-......)if that does not work replace them--if you need the exact part numbers email me at djstvrepair@comcast.net
Sep 15, 2009 | Pioneer SD-P50A3-K TV
Dvd's aren't fitting my screen, the sides and top/bottom is being cut of. I've tried the display menu, zoom, and making it widescreen, and it doesn't work.
Are you playing wide-screen movies on a 4x3=1.33:1 (standard=SD) TV? DVD output by default is SD. Even 16x9=1.78:1 (HD) movies with have top and bottom bars. Many "wide-screen" DVDs are squeezed horizontally so that you have to stretch them. Many theatrical releases are up to 2.7:1 or so. Side bars indicate you have the DVD output set for 4x3 and your TV is HD-like. There are usually controls for the screen format on HD TVs--no controls on SD TV. Hey, early movies were 1:1--take them side bars. More on aspect ratio (AR) in Wiki, I bet. With letterbox of SD you can get "pillar box" with black on all 4 side. Get a better source and/or choose a different AR. -Ken
Jul 15, 2009 | Pioneer DV-400V DVD Player
How to remove front screen
The screen comes off from the front. First take off the speaker grill and you can access the frame screws they are right below the screen. This only takes off the frame with the filter. After the screws are out swing the bottom out a bit and lift straight up on the frame then pull it out away from the set. I have found these to be very stubborn somtimes, but you should be able to get the frame to move then work it up and off. I hope this helps you. let me know if you have any more quesitons.
Apr 28, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
My Pioneer 55 inch screen tv SD-P5553 has a solid black horizonta
This sounds like a picture mode issue. You maybe in a ZOOM mode. Try adjusting your set to FULL mode. If you are using a Sat receiver or cable box, some of these may have picture viewing mode as well, wich may need to be set in FULL or NORMAL viewing mode.
Good Luck!
Jan 18, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
50" Pioneer TV blacks out and has shadow on the bottom third
yes it is worth fixing.if you r getting it repaired for the first time.
but you will have to wait for some long time to get it repaired as the tv is very old its very difficult to get the parts for reparing it.
the problem what you r facing is the problem of the convergence in your main board of the tv.
it has to be repaired.
i will advise you to get it repaired as it will work.
for doing it your self you can try clicking this link and following the given instructions in it
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
thanks.
Jun 25, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
356 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
