Question about Microsoft Windows XP Professional for PC
Virus Please help me My cool disk has a terrible problem. When i have a data in it suddenly all folder change to folder that their name is unintelligible and when I open this folder it appear nothing in it. And i can't delete them. i had to format my cool disk to delete . I use avg anti virus or remove run auto play but it doesn't work. Please help me
    Problem Solver:
  • 11 Answers
Looks like you have a trojan horse in your PC.
Steps To Remove It.
Step1: Disconnect the PC from the internet.
Step2: Use a different pc or laptop to download a good antivirus trial version and install it in the infected pc.
Step3: Scan all the files until you find the trojan horse(WARNING THERE WILL BE A LOT OF INFECTED FILES!)
Step4: Remove All found infections and restart your PC.
Step5: Now that the ttrojan is removed you PC should be fine. if it is not then you will need to flash your hard drive and pc. reinstall windows and start all over.
Hope this helped.
Posted on Dec 03, 2008
My external hard disk has been infested with viruses and files and folders made shortcuts. how can i recover the files and folders?
I have faced same problem. Shortcuts everywhere.
Not once, many times.
I tried many solutions.
Shortcut Virus Remover is the best solution I found.
A 100% free simple application.
You can download it from this link - http://www.shortcutvirusremover.com
Place it in your pen drive and double click to run. Press Enter to confirm its process. That is all. Shortcuts will remove and your data will be back in a second.
Mar 05, 2014 | Computers & Internet
I don't see my folders on my external hard disk. When I scan the disk for viruses I can see my folders while they are scanned. When I add new folders to it they don't disappear.
It is due to virus activity. Some virus make the contents of the drive hidden, that is why user can't see the files. This can be fixed and data would be available to you. However, there are number of steps involved.
It is suggested that go to FOLDER OPTIONS - and select 'SHOW HIDDEN FILES & FOLDERS' and uncheck/ Deselect 'HIDE PROTECTED SYSTEM FILES'.
It would show the hidden files/ folders, if the system not infected Otherwise, from the clean/ virus free system you can see your data and copy all the required files/data. Select the required files and right-click and change the properties of the file by un-checking the hidden attribute. Please note that you can not change the properties (hidden attribute of the files) if the files are marked as system files. To change the attribute of such folders you can download and use iReset.
Dolwnload iReset and drag and drop the files/ folders on to its window to fix.
Also, make sure that you have a good antivirus installed and its updated. Scan your system and clean it. As long the the virus is there on you PC, you cannot get it fixed. However, if new folders don't disappear, it is likely that you would be able to fix the issue.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 24, 2011 | Microsoft Windows XP Professional With...
All folders on usb flash memory card changed to be shortcuts , I can't display their contents directly , there is folder called recycler contain an index for the data inside my folders ... i want...
Hello there, sadly you have been attacked by a virus named - RECYCLER. This is a very common virus, I also had an encounter with it recently. What zou are going to do in order to delete is:
1.Look for all folders with shortcut arrow.
2.Right click then properties.
3. in the field TARGET delete everything before path to your usb (before eg. F:/Kobac usb).
4.Save settings. Open folder and copy it to harddrive
5. Do this for all folders.
6. When zou finish coping your data, format your USB.
7. To Format fo to My Computer, right click on USB and format.
8. Copy files from harddrive to your USB back
9. Enjoy!
Good luck, Kobac
May 24, 2011 | Computers & Internet
4 gb usb creating shortcuts folders
I think you are referring,that there are folders and shortcuts which are not created by you and its generating automatically?
if this so, Its an action of a virus. - Run full system scan using a up-to-date virus scanner.
Mar 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have a autorun.inf virus in my cimputer that disable my task manager and regedit. please help me!!
Remove the disk-drive from your computer.
Attach it as a "slave" disk-drive in a different computer that has up-to-date anti-virus software installed.
Run the anti-virus software, targeting "all" the files on that "slave" disk-drive,
if you believe that it is possible for any anti-virus software to remove 100% of any computer-virus.
Or, read: http://technet.microsoft.com/en-us/library/cc700813.aspx
which describes "best practises", namely to copy all your data files, "flatten" the disk-drive,
reinstall Windows, and reload your data.
Or, take this incident as an "opportunity" to install a new (larger? faster?) disk-drive into your computer, disconnecting the old disk-drive, and to reinstall Windows,
and to install an anti-virus software package.
Then, temporarily attach the old disk-drive as a "slave" drive, and copy all your files.
When the copy completes, FORMAT the "slave" disk-drive, to wipe-out ALL the files on that disk.
Nov 02, 2010 | Computers & Internet
Sudden slowdown while playing games
R u sure that there is no virus on your PC
If then Use
3D analyzer
PLease inform me if my suggestion helped u
Sep 11, 2009 | Computers & Internet
Recycler folder virus
You don't have a virus, you have the folders without an executeable link. Use windows explorer to delete the files you want to get rid of.
Sep 07, 2009 | Microsoft Windows XP Professional With...
Doesn't show any files and folders when drive opened
Congrats, You got a nice virus. Its better you backup your drivers and data from ur root partition format it. reinstall your operating system and install avg 8.5 before browsing any of the other partition. I can surely tell u your task manager, registry editor or show hide folder won't be working. There is no permanent solution to this other than format. But beware don't browse other partition before installing avg 8.5. Your earlier installed antivir has given its way to virus its of no use. You won't be able to install antivirus or visit any malware removal virus site. welcome back.
Jun 14, 2009 | Western Digital Passport WDXML800UE...
PEn drive
You have damaged the file allocation table on the drive. You may be able to recover a little of the data. There are a couple of utilities you can use to attempt to recover data from the drive:
One is ZAR Recovery. It is a trial version that only allows you to recover a few folders at a time but give it a shot:
http://www.z-a-recovery.com/
The other is called PC Inspector:
http://www.pcinspector.de/Sites/file_recovery/info.htm?language=1
They may be able to get some of your data back, chances are you may be able to get the data back, but the file names will all be unknown, so perhaps you can figure out what file was what based on its contents when these program recover the data.
Jan 25, 2008 | Computers & Internet
Files transfer to pc
I had the same problem, what I did is I executed AVG anti virus software and selected the camcorder drive, I was able to see all the folder names. My camcorder shows as E drive but when I open by double clicking it shows only hidden folder, so I entered in the address as follows E:\MP_ROOT\101PNV01 for videos and E:\DCIM\101MSDCF for photos and I was able copy all my data. Your folders may be different I don't know if there is any other way of knowing your folder names but if you want to download the anti virus software which I used go to link http://free.grisoft.com/doc/downloads-products/us/frt/0?prd=aff.
Hope this helps!
Jan 06, 2008 | Sony Handycam DCR-SR200 Camcorder
Microsoft Windows XP Professional for PC Logo
134 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
