Question about GE 25GT240 25" TV
T v suddenly went off
T v went off. All cable connections are okay. Try turning on manually and it makes 3 or 4 short beep like sounds and doesn't come on. No warning or problem, just went off.
    Problem Solver:
  • 11 Answers
How long did you have it for?
If you had it for long then it could possibly be the fuse.
I recommend you take it to PC World and get it checked out for FREE!
but the repair will cost.
Thanks
Posted on Dec 03, 2008
I am unable to get a picture on hdmi when i connect my ps3, but am able to get sound when i use ps3 controller. any ideas ?
Steps
  1. Step 1 Check for an HDMI port Check the back of your television for an HDMI port and refer to your owner's manual for your television's resolution. A resolution of 1080p offers the highest quality.
  2. Most PS3 systems support 1.3 HDMI, but older systems may need a software update from the 1.1 or 1.2 version.
  3. Step 2 Disconnect cables Disconnect all the cables and adapters from the back of your PS3, and then unplug your TV to reduce the risk of shock as you work.
  4. Step 3 Connect HDMI cable Connect the HDMI cable. Reconnect the power cables on both the TV and the PS3 system.
  5. Step 4 Hold power button Hold down the power button until the PS3 beeps and continue holding it for an additional five seconds until the system makes a second beep.
  6. The Playstation 3 should detect the high definition cable and automatically adjust the settings to give you the best picture and sound possible.
  7. Step 5 Test the connection Test the connection. If the HDMI cable isn't working, turn everything off and reconnect the original cables to manually change the settings.
  8. Step 6 Adjust the settings Turn the system back on, select Settings, Display Settings, Video Output Settings, and then HDMI. Repeat the process for your Audio Settings. You can now experience your games with the highest video and audio quality available.
Dec 01, 2014 | Sony KDF-E50A12U 50" LCD HDTV
HP Pavilion not turning on, orange light and alarm sound.
Try a Hard reset!
1. Remove all connections from the computer including the power cable
2. Press and hold the power button for 20-30 seconds and then release
3. Only hook up the mouse, keyboard, monitor and power cable
4. Turn the computer
let me know what happens!
Oct 15, 2014 | HP Pavilion Computers & Internet
My tv has no sound all of a sudden
Check the obvious first, such as whether the mute button is on or whether the volume is turned down. If that's not the issue, try the following:
1. Verify that all of the cables are firmly seated by reinserting each one. Loss of sound from bumping into equipment is common, especially if your TV is connected to a sound system. You need tight connections to hear the audio.
2. Make sure the cords are connected correctly. Some TVs have color-coded inputs that can be matched up with cable boxes and sound systems.
3. Try a new cable to see if that fixes the problem. Over time, cables can malfunction too.
4. Make sure the remote is set to 1) the proper video input (TV, satellite/cable) and the correct audio input.
5. Check all channels to make sure it's not a TV provider issue. You can also call your provider first and make sure the problem doesn't originate with them and not your TV.
6. If you have an external sound system, test another input such as a radio, CD player or game console.
For more tips and tricks on restoring sound to your TV, check out No sound on TV for more troubleshooting steps. I hope this helps!
Sep 26, 2012 | Televison & Video
Laptop display went black after inserting a USB cable for iPod.
count the beeps on startup, and makes sure that you count if any are long beeps and short beeps as these are bootup error codes.
Mar 24, 2010 | Compaq (169174-002) - (Refurbished)...
PS3 wont display video or audio
This is a rare problem ............ i faced similar kind of problem
i solved my problem with the help this repair guide you can also try this out i hope this will help you a lot .......
all the best
Click Here
Feb 11, 2010 | Sony Playstation 3 (PS3) Console
My ps3 suddenely turned itself off mid-game. turned it back onto standby mode, then when i turned it on the light went green as normal then suddenely red light came on with the green, three rapid beeps...
try this:
it works for slimline PS2. might work for PS3.
1) turn off PS3
2) unplug PS3 and wait a minute or two before plugging back in.
3) turn on PS3
hope this helps.
it could also be overheating.
Aug 19, 2009 | Sony Playstation 3 (PS3) Console
Turn it on it beeps cdc
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
Jul 16, 2009 | E-Machines T6520 PC Desktop
No output at all
okay close laptop remove battery, open ram / memory compartment, remove memory. try holding down power button for 3 minutes. THEN INSTALL BATTERY , NOT RAM/ MEMORY AND PRESS POWER BUTTON AND IF YOU HEAR A SOUND THAT GOOD NEWS THE SCREEN MIGHT COME ON, OR IT MAY NOT, BUT YOU SHOULD HEAR A BEEP, IF POWER BUTTON REMAINS LIT HOLD DOWN TILL COMPUTER TURNS OFF, THEN INSERT MEMORY/ RAM AND FIRE IT UP. WORK THESE STEPS
Jun 02, 2009 | Dell Vostro 1500 Notebook
Iam using lennovo y410 series.my lapton suddenly making some beep sound continuously on running and its not getting turned off. i removed battery and shutted down,i have been running laptop continuously ...
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Feb 22, 2009 | Lenovo 3000 Y410 Notebook
GE 25GT240 25" TV Logo
42 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
