Question about Panasonic AG-455 Camcorder
Image in viewfinder
I have a Panasonic ag-460, the problem is that the image in the viewfinder looks like a black and white negative. This image is recorded on tape as a color negative. I did take this camera to an authorized repair facility,but their answer to the problem was hard to believe (I am technically incline). Then they wanted to know if I wanted them to throw the camera away for me. I would like to know where the problem with this camera lies,is it one of the circuit boards ?? ANY HELP would be greatly appreciated , Thanks, Mark
    Champion:
  • 221 Answers
Problem is most likely surface mount capacitors on the video process board. Best solution would be replace the process board, but parts for this camera are long out of production. It would probably cost less to replace the camera.
Posted on Jun 28, 2007
  • 71 Answers
If the camera has no invert switch in its body then you have a fault in the Y signal board it should be checked by qualified but try to look up for the invert swith inthe camera body !!! regards and please don't forget to rate
Posted on May 03, 2007
SOURCE:
Image through Nokia F80 viewfinder dark and cloudy
Please also ignore this answer, (see askers comment above). I've only posted it so that this question doesn't continue to appear as an unanswered one.
If anyone else has this problem please go to
http://www.fixya.com/support/t2637498-image_nikon_f80_dark_cloudy
for an answer.
Jul 20, 2009 | Nikon F801S 35mm Film Camera
Fuji S6000fd; black display, both lcd and viewfinder
I have the same problem except everything is white, not black.
Jul 05, 2009 | Fuji FinePix S6000fd Digital Camera
Zebra effect does not go away. The menue does not work
inside the viewfinder there is a button, called amazingly enough ZEBRA, next to the OIS button,(optical image stabilizer button). You push this button to turn zebra on or off. In the menu, you adjust the zebra to show at 80% or 100% of optimal exposure on the brightest spots of your shots. You need to dial your iris up or down to make the zebra go away, then turn it back up until it barely registers on the brightest spot of your image, then you are using zebra to it's effective use. When shooting in zebra 80%, try to make the people's faces barely register a tiny bit of zebra striping to have their faces exposed at the best light. The white shirts will be blazing, but then again, they should not be wearing white shirts anyway if your pre production crew did their job when advising talent what to wear. (No stripes, solid colors are best. Dark colors are even better, especially for dark skinned people.)
Jun 06, 2009 | Panasonic AG-DVX100B DV Digital Camcorder
MY Hvx 200 Is totally Black when I turn it on. the display and playback of my old footage works fine but the picture is totally black. any Ideas When I switch the camera on, the view finder is totally...
You should go into the menu, camera settings and set the evf to on. EVF stands for electronic view finder. This can be set to be on when the lcd is open or closed. CAreful, if the evf is set to on and you point the viewfinder towards the sun, it will burn white marks into the viewfinder and ruin it.
May 09, 2009 | Panasonic AG-HVX200 Mini DV Digital...
No color in the viewfinder
ag-456 vf is black and white only.
Apr 24, 2009 | Panasonic AG-456 Camcorder
Tried all advices but no solution...
cleaning with rubbing alcohol may have aggravated your problems - rubbing alcohol contains glycerin, which may tend to worsen the connections. to clean the connectors, use only _denatured_alcohol or electrical contact cleaner. the only connectors I have had to clean are the two leading to the video head.
Mar 29, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
Color unbalanced, uneven across the frame
Things to try. I don't promise solutions. Check your Monitor. Reading the description lead me to think of a tube display rather than a chip. Otherwise order a head cleaning tape and give it a rotation.
Mar 09, 2008 | Panasonic AG-DVC200 DV Digital Camcorder
Panasonic PV-GS35 Viewfinder screen connection problem in hinge joint
the hinge is definetly damaged and is going to need replacing. these hinges do need replacing if used allot because this is a moving mechanical part. This is not a easy thing to do, it needs to be done by a panasonic technician.
Oct 11, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
AG 460 panasonic camcorder" FUSE LOCATION"
just follow the battery and you will see the small fuse color white and have a mark of 3.15 at the bottom of the battery socket..
Aug 10, 2007 | Panasonic AG-455 Camcorder
Panasonic AG-455 Camcorder Logo
213 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
