Question about Motorola Talkabout T5500 (7 Channels) 2-Way Radio
No activation I hold the activation button down,and it won't activate
  • 123 Answers
Check if you are using the same channel and same squelch code in both radios. I´m not sure if you are talking about the PTT button, if is so, try using a audio accesory with ptt external just to be sure that your internal ptt is working or not.
Posted on Feb 05, 2007
Activation for Nextbook Intel inside, without my activation code or receipt?
by hard reset hold down the power button and the volume up button till the android man with no command comes up
press power button 5 times
writing will come up go down to the wipe data with volume down button highlight wipe data then press power button to ok it will wipe data
then writing will come back up go down to the reboot/restart press power button ok it then your tablet will restart
Mar 05, 2018 | Nextbook Tablets & eReaders
Hot point washing machine WMA76 stuck on child lock
Child Lock
?When activated all the buttons will be disabled and a child will not be
able to alter any wash programme or option settings. Once selected
this feature remains activated, even when the machine is 'off'.
To use this feature press the 'Child Lock' button and hold down for 2
seconds.The child safe icon will begin to flash.When the icon stops flashing
the feature is activated.If any of the control buttons are pressed, the child
safe icon will flash and the machine will bleep 3 times: no alterations to the
control settings will be allowed.If power is interrupted, at any time,pressing
any button will reactivate the child lock feature.
To deactivate this feature hold the 'Child Lock' button down for 4
seconds.You will then hear a bleep and the child safe icon will go out
Mar 27, 2016 | Washing Machines
My Fagor innovation washing machine is currently disabled by the child lock symbol we did not apply this how can it be reversed
STARTING UP AND
6
BLOCK FUNCTION SELECTION
Start/pause button
a To start up the washing machine you
have to press the start/pause button.
The minutes remaining until the end of
washing and drying will appear on the
display at all times.
Block function selection
The lock function ensures that the programme
will not be affected if any buttons are pressed.
It is used when children could press the
buttons, etc.
The block function should be activated after
the wash programme has been selected
together with all its options.
Activating the block function
a The block function is activated by
pressing the start/pause button and
holding it down for at least 3 seconds.
The display will show if it is activated.
Deactivating the block function
b The block function is cancelled when
the wash programme comes to an end.
If you want to deactivate the block
function before the end of the
programme, you have to hold the start
button down again for at least 3 seconds.
After 3 seconds, the block function
indicator will disappear from the display,
and it will go into pause status.
The ON/OFF button does not cancel
the block function
Apr 14, 2015 | Fagor Washing Machines
Washer won't drain
DIAGNOSTIC MODE
To enter diagnostic mode follow the steps below.
1. Turn the power on at the power point but off at the machine.
2. Press and hold WASH TEMPERATURE SETTING DOWN and then press POWER until the
machine gives 2 short beeps and lights up.
3. Release the buttons after the beeps as the beeps indicate diagnostic mode has been entered.
4.1 Last Fault Data
When in diagnostic mode the last fault can be found by pressing the SPIN SPEED UP or DOWN
buttons until the HOLD and SLOW lights are illuminated. Binary can then be read from the wash
progress lights.
4.2 Drain Pump Test
MW Washer
When in diagnostic mode press SMART TOUCH CYCLES to activate the drain pump. To
deactivate the pump, press SMART TOUCH CYCLES again.
GW Washer
When in diagnostic mode press REGULAR to activate the drain pump. To deactivate the pump,
press REGULAR again.
4.3 Water Valve Test
The water valves can be activated in diagnostic mode by pushing WASH TEMPERATURE SETTING UP to activate the Hot Valve and WASH TEMPERATURE SETTING DOWN to activate
the Cold valve as with previous models.
Pressing each button once will activate the valve. To de-activate valve press the same button
again. This is also good to use when installing machines as it takes the shock out of the fittings
and seals and allows checking for leaks on the inlet hoses, both machine end and tap or super-tub
end.
Caution: Do not leave the machine unattended when either or both valves are operating
May 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
My hp pavilion 522a i cant log in to it because it keeps coming up with this copy of windows must be activated with microsoft before you can log on. do you want to activate it no. and no mater what i do it...
You need to activate it, no way around it. When installed you have 30 days to activate it or it won't let you log on.
There should be a a choice to activate and it will only let you go to a activation window. You can do it over the net in a few seconds. After it is done it should work normally. If it is a valid installation you will click a few buttons and you are done. If there is a issue with a valid serial number ie your buddy gave you a copy then you won't be able to activate it (easily anyway) and need to get a new copy to install.
You may need to log on on under administrator before it takes you to the activation stuff but that depends on the windows version and so on.
Once you get it activated you won't forget and the next new computer you will probably get it activated after it runs for a few minutes to avoid this again. It's annoying, it's Windows! ;-]
Sep 01, 2011 | Computers & Internet
I formatted my imate jasjar. i dont know how to return the programs deleted...i dont have the manual..i dont know what to do.help me please..
Perform a hard reset to return it back to original state.......
To perform a hard reset on a Cingular 8125, I-mate Kjam, T-mobile MDA, or other similiar device:
  1. Hold down the communications manager button (top left) and the Voice activation button (top right).
  2. While holding down those two buttons, use the stylus to hold in the reset button for a couple seconds.
  3. Release the stylus but not the other two buttons. After a couple seconds, a black screen when come up asking you to press send to continue.
  4. Release the communications manager button and the Voice activation button and press send (green phone button)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 24, 2011 | i-mate JASJAR Smartphone
How do we get childlock off a hotpoint wm 864
When activated all the buttons will be disabled and a child will not be able to alter any wash programme or option settings. Once selected this feature remains activated, even when the machine is ‘off’.
To use this feature press the ‘Child Lock’ button and hold down for 2 seconds. The child safe icon will begin to flash. When the icon stops flashing the feature is activated. If any of the control buttons are pressed, the child safe icon will flash and the machine will bleep 3 times: no alterations to the control settings will be allowed. If power is interrupted, at any time, pressing any button will reactivate the child lock feature.
To deactivate this feature hold the ‘Child Lock’ button down for 4 seconds. You will then hear a bleep and the child safe icon will go out.
Oct 25, 2009 | Washing Machines
I can't remove the childlock on my washing machine! Can you help?
Sep 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
Activate the alarm
You can leave the window open then lock the doors with the remote.Wait for a few minutes then reach in and unlock the door with knob on the door and open the door.Your alarm should then activate.You can also hold down the panic button on the remote
Nov 30, 2008 | 2007 Toyota Camry
Motorola Talkabout T5500 (7 Channels) 2-Way Radio Logo
115 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Damen Wong
Damen Wong
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
