I have a HP NC8430 Business notebook. When i plug my charger in there is no light indicator showing but there is nothing wrong with the charger itself or the notebook what could be wrong?.
    Master:
  • 351 Answers
Dear Masonmarley,
As per you that your charger is right then its motherboard related problem , maybe the charging section is not working of your Laptop's motherboard.well please contact to any HP Authorised service centre for proper solution .
Be Happy Always
Regards
Posted on Dec 03, 2008
    President:
  • 2,110 Answers
Check the port on the laptop,Is it fitted correctly or loose...
Bios hp nc8430 password reset
The messages you see are telling you that smthing is wrong with the hardisk.
If you have set a bios password and you forget it, you could remove mobo's battery for a while-not an easy task on a laptop- otherwise please write down your bios type version
Jan 20, 2014 | HP Compaq nc8430 Notebook
HP Compaq NC8430: Laptop does not want to charge battery
Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
Jan 30, 2013 | HP Compaq nc8430 Notebook
I lost my charger and bought a new universal charger now my notebook charges and goes on but after a few minutes it switches off, what could be a problem?
wrong spec of universal charger,check connector plugs (if you have them) are corect way round ,will cause seriouse damage if you cannot define correct set up(look for marks on the side of plastic adapters) and the polarity is correct
Sep 06, 2010 | HP Compaq Business NX9110 Notebook
MY COMPUTER WON"T TURN ON YET INDICATOR LIGHT WHERE CHARGER GOES INTO IT SHOWS LIGHT> Plugged in but will not powerup screen black. THIS IS A G60 HP Laptop
Take out the battery and try running it on the power adaptor alone. If this works, you have a dead battery. If not there's something more serious wrong in the machine.
Apr 16, 2010 | HP G60-235DX Notebook
Unable to pair samsung t729 blast with bluetooth on hp nc8430
Read the manual that came with your device. It should tell you in the manual what the default pin is. You can try 0000, or 9999, or 1111 just for the heck of it...it's usually something like that. (not sure on the number of digits for your device, but I think it would be 4)
Jan 13, 2010 | HP Compaq nc8430 Notebook
My hp pavillion dv1000 wont turn on it is plugged in but the charging light doesnt show up and when i push the power button nothing happens
Problem with your charger, try this :
1. Check whether the charger plug is properly inserted in the Power port/jack of your Laptop!
2. Check the power cord (any cuts OR torn-out)!
3. If above steps don't work, replace your charger.
Jan 02, 2010 | HP Pavilion dv1000 Notebook
My laptop wont turn on at all,is different to the other problems on here.help
Try removing the battery (instructions in your manual). Now run the computer with just the new charger. Does this work? Try holding down the power button for 10-20 seconds.
Nov 08, 2007 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
