HP vs17e sleep after 15 sec when turn on. How to fix it working? tron on it sleeps turn on it sleep
  • skytrader Mar 31, 2009
    sleeps after about 15 seconds
  • 4 Answers
Usually it is from power supply ... cheack it with other power supply... or adaptor..
Posted on Dec 03, 2008
Came home to find computer off. It was left in sleep mode. The moniter keeps saying there is no signal and the keyboard has no power.
If its truely in sleep mode, and won't come out of sleep mode. Unplug the computer from its power, hold the power button down for 5-15 sec, then wait 2-5 full minutes. Then plug it back in, and turn it on.
If that doesn't work it is NOT stuck in sleep mode. Most dell computers I've worked with the caps go out in the power supply and/or the motherboard. I would next clean out the computer with canned air, check the caps on the motherboard, and in the power supply. If there are any bad caps, replace them, and it should fix it. Hopefully though the above paragraph fixes your problem.
Sep 13, 2013 | Dell Dimension 4600 PC Desktop
HP LP2065 MONITOR goes to sleep
Hi There The Monitor setting you set through the computer, may you select the sleep mode or hibernate. Chang the mode and fix the problem.
Thanks http://pacificbits.ucoz.com/
May 08, 2012 | HP Pavilion F1503 15" LCD Flat Panel...
Hp L1706 Monitor Keeps Going Into Sleep Mode
I have an hp media center that runs windows xp with service pack 3 and my monitor is an hpL1706 monitor and was running fine now it says no input and goes into sleep mode how do I fix it?
Apr 10, 2009 | HP Pavilion F1523 15" LCD Monitor
HP vs17e My screen went black for a few moments and when it
Switch off and on your PC and hold down the F5 key and this should bring up your PC in Safe Mode. If this fails, then find a PC repair shop to replace the power supply.
Mar 22, 2009 | Computers & Internet
Hp vs17e monitor says it's in sleep mode then goes blank
If you are running Windows Vista,do the following,
  1. Click start,Control panel,
  2. Double click Power options,
  3. On the left menu bar,Click Change when the computer sleeps,Change "turn off the display" to never,
  4. Go down to the botton and select "Change advance power settings,
  5. Scroll down to Display and click the + symbol,
  6. Click the + symbol beside "Turn off display after" change to never,
  7. Click on the next plug + symbol beside Adaptive display and change to off (You may or may not have the adaptive setting)
  8. Click apply ,click ok,
  9. Restart your computer.
If you are running windows Xp
  1. Right click on an open area on the desktop
  2. Click properties
  3. click the screen saver tab
  4. Click the power button at the bottom
  5. Change the "Turn off monitor settings"To Never
  6. Retart computer
if this doesn't fix your problem,please let me know
Please rate this a fixya
Feb 02, 2009 | HP Vs17 17" LCD Flat Panel Monitor
check the board postings for the HP f1903 monitor.I recall seeing a problem of the same there and a solution or fix. As it is only a newer version of the same model, it may be the same fix. Appears HP has a big problem with QA and this particular model. Lots of people have same or similar problems, and all appear to have a similar fix or solution. Tricky part... figuring out how to "Open" the monitor to check it inside!
Good Luck.
PS - if you figure out the opening part, let us all know!
Feb 02, 2009 | HP Pavilion F1703 17" LCD Monitor
Monitor in sleep mode
my computer is on but screen is black and has power. How can I fix it?
Aug 27, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Goes to sleep
Hi
Pls check the power option settings in control panel.
Also pls check if the power management options for keyboard and mouse in device manager are enabled or not.
Pls try to create a new profile and check if the sleep mode is working in the new profile.
Pls try a System restore if the above steps don't work.
Dec 24, 2007 | HP Vs17 17" LCD Flat Panel Monitor
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
