Question about Westinghouse Refrigerators
My upside down fridge (BJ505SR) freezer keeps icing up dramatically
5 Suggested Answers
SOURCE: ice tray stuck
Hi My Samsung freezer was nor a RB2155 it is a RS2630SH however after not making any ice because the tray was stuck in the upside down position or thereabout after 6 weeks it suddenly started making ice again, we had not done anything to it but we heard it dropping ice one evening and we had a look in the ice container and low and behold the ice box was full to the top, I would still like to know why it went like that in the first place in case it happens again it is a mystery. Larry
Posted on Dec 23, 2006
refritech08
  • 149 Answers
SOURCE: rs21/fcns fridge freezer fridge keeps
suspect a bad defrost element and defrost thermostat. but if your handy with a volt meter, check out the defrost heater with the "beeping" option if good,if it doesn't beep, bad defrost element.replace element and defrost thermostat. one step less. second, try to locate the timer, sometimes the timer just gets stuck in cooling cycle and won't defrost. if it's an adaptive defrost board, suspect it faulty. if its an mechanical timer it has a small wheel ,try to turn it if you can't turn it, well there's your problem. your third piece to suspect is the thermostat but I'd change it if the unit never shuts off but i recommend to change the timer first, with defrost thermostat just for safety.
Posted on Apr 21, 2008
woodchuck789
  • 4059 Answers
SOURCE: hoover contour fridge leaking
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 30, 2009
Testimonial: "thanks, all fixed!!"
BIKER T
  • 909 Answers
SOURCE: hoover a class fridge freezer, freezer keeps icing
You have an auto defrost problem. Need to check element for resistence. if good, check the thermal fuse for continuety. Most of the time i replace both the thermal fuse and the little clixon that is attached to the evaporator coil. Defrost timer is quite robust and very seldom do i need to replace that. You need to firstly defrost freezer overnight to allow cover removal. All components should be visible.
Posted on Nov 12, 2009
  • 9 Answers
SOURCE: Fridge not cooling, Freezer is working (upside
We experienced a smilar problem with your Fisher & Paykle fridge/freezer.
The fan that sends cold air to the Fridge section of the appliance didnt appear to be working leaving the Fridge poorly cooled.
I suggest the first step is to turn the fridge off and leave it to totally defrost.
Build up in ice in the freezer section seemed to have an impact on the proper operation of the fan which seems to relie on a thermostat for its operation.
Having defrosted and cleaned the fridge the problem was solved.
The fans have a delay before switching on after the door is closed. Place a magnet over the door sensor switch and wait to see if the fan works.
The problem could be that the unit has iced over itself over a period of time and defrosting it could solve the problem.
Posted on Mar 03, 2011
Why does thick ice form regularly on bottom of my samsung frost free upside down fridge .
The drain line in the bottom of the freezer is frozen over. Remove the back cover boil some water and slowly pour it down the drain to clear it.
Mar 02, 2014 | Refrigerators
Fridge not cooling, Freezer is working (upside down fridge/freezer)
Feb 28, 2011 | Fisher and Paykel Active Smart E522B...
Hi there, i have a westinghouse bj505sr. The problem i have is that the fridge and freezer are not cooling the way they wer until 1 week ago. I have checked the door seals and they are ok. The only thing i...
sounds like you have a blown defrost element on the back panal of the fridge if they blow then excess ice builds up and the unit stops chilling correctly have the defrost elements tested if you know how to use a mulitimeter try testing the elements as you would a fuse
best of luck
please remember to rank my reply
Dec 01, 2010 | Refrigerators
Mini Danby Fridge Won't cool but compresser is running very HOT!(Model DCR412BLS) the fridge has just recently been moved into a warmer environment without air conditioning. As well, it had accumulated...
never turn a fridge up side down and when moving a fridge or freezer keep it upright as much as poss and dont plug back in for 24hrs.now leave it unplugged a buy new one...
Sep 14, 2009 | Danby DCR412 Compact Refrigerator
I have a westinghouse upside down fridge what tempereture should it be for freezer/refrigerator? cos its pretty to cold like bit of ice goes in the meat packages.
The fridge should be between 2 and 5 degrees C or 36 and 41 degrees F and the freezer should be between -18 and -25C and 0 and -13 defgrees F. If you cant get the temp right then call a service engineer asazp.
Sep 10, 2009 | Westinghouse Refrigerators
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Candy frost free fridge freezer .freezer working ok
The thermostat might be turned up too high or is faulty. It should click when turned up and down from the setpoint.
May 12, 2009 | Freezers
Freezer works great, as it should, but fridge is only keeping items room temp. I have the setting at the coldest setting: #7. What is wrong?
Here's what I did, I defrosted! I found out that the fridge temp is monitored and maintained by the freezer. Because we had a power outage one night, my freezer thawed while we all slept and then when power came back on, freezer re-froze but this cause an ice build up on the vent on the back wall of the freezer. Well, ice must have been in one (or more) vents, causing blocked air flow in my top half of the refrigerator. I turned the dial in the freezer to "off" which also shuts down power to the fridge half. I then unplugged the refrigerator, hauled all my food items into coolers, opened the freezer door and refrigerator doors and left them open for a little over six hours. I took advantage of this empty fridge and freezer and wiped everything down. After this time frame passed, I plugged the fridge back in, turned the freezer dial to my preferred freezer temp, and wah-lah! Within two hours I had a cold fridge and solid ice cubes in the freezer. I then put all my food items back into their appropriate compartments, and went to work. Bear in mind, a total 24-hour period is needed for the fridge to re-set itself, but still, after two hours the fridge was noticeably cold. Who knew, besides our parents' generation: DEFROST!
Sep 10, 2008 | Maytag MBB1954G Bottom Freezer...
Ice tray stuck
Oct 09, 2006 | Samsung RB2155 Bottom Freezer Refrigerator
Refrigerators Logo
184 people viewed this question
Top Westinghouse Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Chris Hall
Chris Hall
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
