Question about Sony KV-35S45 35" TV
RCA25F422.CTC203AC4 Hi guys, this set RCA F25422 CTC203AC4, has a farely good pic and sound, but has this fault that i never saw before,When i go to menu it usualy has a blue square with a yellow line,but this one instead of the blue has just green barely can see the menu controls,and also the channel # has a small green square like the menu,it all started with almost full red kinda like when you have a crt board fault and clear up, i suspect caps, since i had this chassis as a spare not used it for long time.any ideas where should start to look for this trouble. ihave this two caps that show short in my ESR,they just at the end of the micro, they come out of pin 26 of U12101the micro to ground,one is C12707 220uf35v,the other is C12707 a surfmout cap dont know value,i took out the electrolitic cap and out side is ok.the other one i did't take out but i assum that it willbe ok. could the micro be bad or the short could be some other place?any clues will be wellcome thanks.
    Genius:
  • 1,694 Answers
Menu read-outs / display originate in the jungle IC..........T.
Posted on Mar 28, 2008
Problem with RCA F25422 25
what is the problem with your tv might can help you.
Sep 17, 2012 | RCA F25422 25" TV
THE TV POP AND THE SOUND WENT OUT
check for burnt amplifier ic.
How do i get dish network to work on rca f25422 tv
Well, you have a couple options with this. You can use either coax cable, or RCA cables. If you use coax, you want to connect it on the receiver that says TV set out, and out the tv set on channel 3 or 4. If you use RCA cables, you want to connect these to the color coded connections on the back of the receiver labeled with a Green 1. The tv will need to be on channel 3 or 4, and a video in put, usually Video 1 or 2.
Becki Barned
DISH Network Customer Service
Feb 01, 2011 | RCA F25422 25" TV
I had kids messing with my rca gemstar f25422 tv the did something to the settings and i can see the menu to get it back
you should power off the television and power it on to see if the menu is still there or not , and it does not work.
check the remote carefully if menu is on it, then press menu to exist the menu . GOOD LUCK..........
May 21, 2010 | RCA F25422 25" TV
I have a rca model number F25422 perfect picture no sound what
I HAVE A 25' RCA WITH THE GUIDE PLUS ON IT. MY DVD PLAYER WILL NOT WORK ON THIS TV. HAVE ALL THE CABLES I NEED(RED,WHITE &YELL) AND THE CONVERTER BOX.
Apr 02, 2009 | RCA Televison & Video
Speaker for RCA F25422
i have a problem with mine If i get another one instead of fixing this one i will give it to you.
Jan 02, 2008 | RCA F25422 25" TV
Cable Input (Tuner)
why? and what is your main problem? can you wright your problem please!
Oct 08, 2007 | RCA F25422 25" TV
RCA ATC113AA.F20TF20 G2 Problem
adusting these stuffs needs a special equipment like the color pattern generator. u cannot just adjust this manually. try to inspect the crt circuit board see if there is an open resistor there. u have a luminance problem
Jan 04, 2007 | Sony KV-35S45 35" TV
RCA F25422
The solder could be loose in the CRT board witch is at the end of the picture tube neck,before you take the back cover out try a simple test put your forearm in the face of the picture tube and the hair should stand with the tv on that will mean you do have high voltage going to the picture tube but if the hair in your forearm does not stand with static it means the picture tube is missing high voltage and then reason for that is not necessarely a loose conection but a bad component in the main board.If you not familiar with tv service be safe and call for assistance.
Sep 28, 2006 | RCA F25422 25" TV
Sony KV-35S45 35" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
