Question about Philips ID9370B/37 Phone
Philips id937 no ring tone cannot recieve or mike calls. philips id937
4 Suggested Answers
SOURCE: no ring tone
If you can't mend the phone I am looking for a spare base and would be interested in buying it from you. geoffrey 07966 907232
Posted on Aug 10, 2008
SOURCE: Philips id937 Wont answer calls
I have a similar issue. I am on voip and when I receive another voip call all is good. when a regular call comes in, I get on the screen, "Voice Call" and "slient" in the lower corner. Anh ideas?
Posted on Sep 20, 2009
SOURCE: PHILIPS ID937 phone.
Fixed:) Ok so I bought 2 extension handsets from different people off of Ebay, both new. First one wouldnt register or would say incorrect pin (0000). So I tried the second one, same thing. Here is what I did: When attempting registering, make sure the handset is physically on top of the main base station, IE charging. Start the registration process on the handset and press-hold (dont let go) the locate handset button instead of press and hold for 3 seconds (like the manual says to). If that didnt work, I removed the batteries and tried pressing and holding the same button for 3 seconds, then release. Wait 10 seconds, then press and hold for 3 seconds. Repeat. If the handset timed out and went back to the main unregistered instruction screen. I took the batteries out and tried again. It was a bit of trial and error but each cycle I removed the batteries to reset the handset. First extension handset took 20 minutes of head scratching, the second 2 minutes. Hope this helps someone. The build and sound quality on these units are great, the tech support....not so much.
Posted on Feb 26, 2010
My philips cd135 cordless does not ring when recieving in coming calls what is the solution.
Your phone is prob on Ringer Off mode. Press menu and then scroll down to Personal Set, press menu and Handset Tone will appear on display, press menu and Ring Volume will appear on display, press menu and then scroll to select volume, low, med or high. Do not select ringer off.
Jan 02, 2010 | GE Cordless Phone & Answering Machine...
When recieving call, we have no ring tone osunds
i asume that your reffering to a cell phone you should check your sound settings making sure that its setup to ring when recaiving a call if you do this make sure that you are saving your settings if this fails it could be a faulty speaker and i would take it back to where i got it good luck!
Dec 18, 2009 | Lands Phones
I bought your digital cordless phones two weeks ago and now we recieve no incoming calls because they do not ring although we know that they are ringing also we cannot ring out we hear the number being...
They're not mine or FixYa's phones, they are yours.
Are you hearing dial tone before you ring out? When a phone doesn't dial or ring, it's the first sign that it's not connected to a working phone line. Try a regular phone in the same jack first.
Carl
Dec 13, 2009 | Philips Lands Phones
Aug 23, 2009 | Philips ID9370B/37 Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
Ring voloume
ave you set it from inside the profiles for incoming calls. have you turned up the volume from the side of them phone when making or recieveing calls. set your pofile with all the loud tones and then it should work again.
Jul 20, 2008 | Lands Phones
No ring tone
Did you find a solution. We are having the same problems
Mar 17, 2008 | Philips ID9370B/37 Phone
H350 HEADSET
you may have the earpiece volume too low, because you will only recieve a bleep when there is an incoming call, not a ringing tone, or just set it to auto answer in the phone settings.
Aug 10, 2007 | Motorola Mobility H350 Wireless Headset
Philips ID9370B/37 Phone Logo
456 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
