Question about Nokia 6010
Key issue :(
Is there anyway to fix a oddball key? The number 7 key on my phone is acting rather odd, I have to press it rather hard for it to regester that number, all the other keys work fine. Can someone please help? Thanks
Try pushing the button down at different angles.
Posted on Mar 16, 2008
  • Nokia Master
  • 3,042 Answers
Same problem, for 0, 1 is starting to go. As far as I can tell the flex pad nibs on the bottom are wearing from use. Best would be replace flexible key pad with new if you could find one. I havn't yet. I put a small piece of plastic between flex pad nib and the switch for 0. I like the phone but Tmobile's solution is to upgrade and 2yr contract.
Posted on Feb 17, 2008
    Problem Solver:
  • 9 Answers
The flex cable in your phone is the problem. You would need to have it restored or better yet, replaced.
Posted on Apr 18, 2007
Ti-36x Solar Scientific Calculator issue: number buttons resetting to zero...
Look in the back of the calculator, some TI models have a pin hole to hard reset the calculator.
Mar 22, 2015 | Texas Instruments - Ti-36x Solar...
I can turn it on, and if i dial a numbre i can make a call, and if someone calls or texts me my phone will ring, but the screen is black, and i really need to fix it. Its started out with half of the...
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 10, 2012 | Nokia 7610 Supernova Cell Phone
< problem identifing Sea-gate external hard drive (500 gb- no external power) > my extrenal hard drive has a odd problem : sometimes when it got connected to the vista laptop its light turn on &...
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Aug 10, 2010 | Seagate FreeAgent Go 500 GB USB 20 Hard...
Is there a reset option on the samsung red rant i am umable to power on and i have a new battery
Try a Hard Reset:
Hard Reset will reset the phone to its factory settings and erase all data.
1. Press the MENU/OK key to select the MAIN MENU tile.
2. Scroll Up to Settings and press the MENU/OK key. 3. Scroll Up to More and press the MENU/OK key. 4. Scroll Up to Security and press the MENU/OK key. 5. Enter the lock code. For this example, press 7 to prompt one to fill in. If you can’t recall your lock code, try using the last four digits of your wireless phone number. If this doesn’t work, call Sprint Customer Service at 1-888-211-4727. 6. Scroll Up to Erase/Reset and press the MENU/OK key 7. Scroll to Reset Phone and press the MENU/OK key. 8. Read the Warning and press OK (Left Soft key). 9. Scroll Up to Yes and press the MENU/OK key. 10. Scroll Up to Yes and press the MENU/OK key to complete the reset. 11. For this example, once the reset is complete, scroll Down to No to decline to verify Wireless Backup
Oct 23, 2009 | Samsung Rant Cell Phone
After many years have misplaced the instruction manual for our Vista 200. Need to know how to set up names and numbers for the automatic dialling feature. tdijimmy@hotmail.com
First, ensure the display is bright enough. If it is not, press successively on the "Brightness key" that is located on the top of the phone above the "Memory key". You have 8 brightness settings. Note that the "Brightness key" has no label.
You are now ready to start programming.
1. Press the "Memory key". It is labelled "Memory" and is located above the "Memory keys" numbered 1 to 10 on the right-hand side of the phone.
2. Press the "Memory key" you want to program. (1 to 10)
3. Enter the number you want to program using the "Dialling keys"
1, 2, 3,
4, 5, 6,
7, 8, 9,
*, 0, #
4. Once the phone number is entered, press the "Memory key" again.
5. Now enter the "Name" for the phone number you just entered. To do this, you press the "Dialling keys" as follows:
For A press the "2" key once,
For B press the "2" key 2 times,
For C press the "2" key 2 times,
For Q press the "7" key 2 times,
For Z press the "9" key 4 times.
Use the same for all letters.
To go to the next letter, press the "Right arrow key".
For a space, press the "Right arrow key".
6. Once the name is entered, press the "Memory key" one last time. You are done.
7. To test it, press the "Memory key" you just programmed.
Oct 19, 2009 | Bell BE-412CID Corded Phone
Blackberry 7100g
About fixed dialing
If you enable fixed dialing number (FDN) mode, your device only makes calls to contacts on your FDN list. Your device can dial emergency numbers in FDN mode, even if the numbers are not in the FDN list. If your service provider plan includes SMS, you can also send SMS messages to contacts on your FDN list
so if you have this enabled chances are you have to turn it off.
this is how you turn it on so you should be able to use it as a guide to turn it off.
Turn on fixed dialing
1. In the phone options, click FDN Phone List.
2. Click the trackwheel.
3. Click Enable FDN mode.
4. Type the PIN2 code provided by your service provider.
5. Click the trackwheel.
or if you wanna keep it on and add friends to the fdn
Add contacts to the FDN list
3. Click New.
6. Type a name and a phone number.
7. Click the trackwheel.
8. Click Save.
and finally some shortcut keys:
To open the phone, press the Send key.
To end a call, press the End key.
To call a selected contact or phone number, press the Send key. To call a speed dial number, hold the assigned key.
To add an extension to a phone number, press the X key. Type the extension number.
To call your voice mail access number, hold 1.
To type a letter in a number field, hold the Alt key.
To type the first letter on a key, press the letter key once.
To type the second letter on a key, press the letter key twice.
To turn on or turn off mute using the Mute button, press the Mute button.
To turn on or turn off mute using the keypad, press the exclamation point (!) key.
To turn speakerphone on and off during a call, press the period (.) key.
To change the volume during a call, roll the trackwheel.
Aug 02, 2008 | RIM BlackBerry 7100G Smartphone
Some of my numbers wont work
you can take the phone to a repair mobile shop and ahve them replaced the flexcable in the phone or reflash the keypad flexfile into the phone for you.
Jun 15, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Number 7, 8 & 9 key is not working
change your keypad or clean keypad.
Feb 21, 2008 | Nokia 6600
Nokia 6010 Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
Damen Wong
Damen Wong
