It is possible that the file Lsass.exe has become damaged or is not properly linked to the other files in the security system. Reset this file by using the following steps:
1. Turn on the PC and press the F8 key repeatedly when the first screen appears.
The Windows advanced options menu appears.
2. Use the Up and Down Arrow and Enter keys to select Return to OS choices .
3. Select Microsoft Windows Recovery Console .
NOTE: If "Microsoft Windows XP Recovery Console" is not listed, restart the PC with a Windows XP CD, Recovery Console CD, or Recovery Tools CD in the top CD or DVD drive and open Microsoft Windows Recovery Console. If a Windows XP Setup screen appears when using Recovery Console CDs, press the R key to open the Recovery Console.
NOTE: If "Microsoft Windows XP Recovery Console" does not list and you do not have a CD with recovery console, try the following:
a. Turn on the PC, and press the F10 key repeatedly at the first screen.
b. At the Recovery screen, click Advanced Options .
c. Press the Alt + D keys at the same time to open a command prompt window and skip to step 5.
4. When the login prompt appears, press the number next to the windows version (minint or Windows) and type the logon password. Try pressing Enter if you do not know the password.
5. At the command prompt, type the following: diskpart
6. Press Enter , do one the following:
- If a table of volume names appears, remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO) and press the Esc key.
- If a diskpart prompt appears, type list volume , press Enter , remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO), type exit when done, and then press Enter .
NOTE: If the main drive volume name does not appear in the list, the PC needs to be recovered.
I am just using the windows CD writing wizard.
First I open my file containing the pictures. I select all pictures and go to file, send to, DVD-RW drive (E) which copies all the files. When I get prompted, I open the balloon that tells me I have files ready to be written to the CD. Then I go to file, write these files to CD, which brings up the CD Writing Wizard. I type in the name of the CD and click next. The wizrd then says there is no disc in the drive and tells me to insert a writable CD into drive E:\.
I bought a pack of new CD-R discs and when I insert the disc, the wizard still requests I insert a writable CD into the drive.
Hence my problem.
I have since sent the files to my work PC and done exactly the same thing, and when I put the disc in it automatically writes the files to the disc. Therefore I believe I am doing everything correct.
Any ideas why it is not working on my PC at home?
My PC is approx 3 years old and this is the first time I have attempted to copy pictures to CD on it.
Any help will be much appreciated
Thanks
