Question about Epson Stylus C20UX InkJet Printer
Thank you for your recent reply
When i start to go into the printer a message comes up the programme didnt download correctly it may not work properly
its a epson c20ux new ink cartridges ....making all the right printing noises......ink indicator shows full... no printing comes thru to the paper.
cleaned it loads of times have had to colours and partial black come on nozzle checks.now nothing
i downloaded thee driver from here.
help please
  • 1 more comment
  • Anonymous Feb 13, 2009
    yes its still there, thanks for replying
  • herwotdus Feb 18, 2009
    i';m in the process of the second 'soak' thanks for the help. if this doesn't work, i'm going to throw it up the garden, smiling as it sails through the air,,
    guess i'll take up the pencil again.
    thanks again.
    yve
  • Gerry Millward
    Gerry Millward May 11, 2010
    Hi - do you still have this problem? If so, can you post a comment to confirm, and I will help you solve it.
  • 353 Answers
The red light is not on or flashing, is it? You did, of course, remove the yellow plastic tape from the cartridges before installing them, didn't you?
OK - the first thing we must ensure is that you have good cartridges. The printer Status Manager (SM) does not actually measure how much ink is in them, it merely estimates it by counting the number of ink shots used and calculating what's left. There are many reasons for getting this wrong. So we must start from a known good position i.e. new cartridges. Put new ones in, but you MUST use the proper cartridge exchange procedure so that an ink charging cycle is carried out. Now try a nozzle check. Any sign of ink? Yes, but not perfect? If so, or if nothing still, do a couple of head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat the head clean etc. Patience is required here.
Still nothing? OK - let's try cleaning the nozzles. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water (available from you local car accessories store). DO NOT USE TAP WATER! Then carefully push the print head fully into its parking position by hand so that the cup full of fluid comes up over the print head. Do not turn the printer on! Leave this for at least 24 hours, then try a head clean & nozzle check again. You may get some strange colours to start with - don't worry about this. However, if still nothing, repeat the soak procedure. If still nothing after this, report back.
Posted on Feb 15, 2009
  • Gerry Millward
    Gerry Millward Feb 15, 2009
    Oh - don't worry about the drivers - if the Status Monitor is working i.e. it shows you the ink levels, and you can carry out head cleaning and nozzle checks, the drivers are OK.
  • Gerry Millward
    Gerry Millward Feb 18, 2009
    Er - you don't say if you have installed new cartridges. Honestly, there is absolutely no point in head soaking unless you KNOW you have good cartridges.
PRINTER GOES OFFLINE
cheak printer connection is proper & paper setting is proper then still printer is offline may be a problem of sensor or datacable give me a status reply
Apr 19, 2011 | Dell 1815dn All-In-One Laser Printer
When trying to install window server 2003, i get the following error message. Setup did not find any hard disk drives installed in your computer Make sure any hard disk drives are powered on and...
The setup program does not recognise your storage controller.
HP and Dell usually supply a startup CD, that will help you configure RAID levels and partitions and start the Windows installation. If you have the supplied CD boot from it and it should work OK, if not you can download it here
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=15351&prodSeriesId=316541&prodNameId=327476&swEnvOID=1005&swLang=8&mode=2&taskId=135&swItem=MTX-d7672226b6284520b9e292b9bd
Please let me know if it works, any issues send a reply :)
Dec 22, 2010 | HP ProLiant ML370 G4 Server
I have a U-Print cdp78 disc printer was working fine for the past year but recently I keep getting a message that the to be switch on or the driver is not installed correctly I tried everything I can...
yes this might be true, that the installing . i think you just had the same problem. as mine you have to reset the botton the computer does not regonice the usb printer because the printer instll programm with the hardware somehow has some failed. and to reset just follow press the start botton unplugg usb and current cable from the uprinter keep holding the start botten replugg both usb and current to the uprinter. and here we go the computer will ask you for new installings and so just reput your cd installing and it will work again
Sep 19, 2010 | Vinpower Digital U-Print CDP78 Printer
I have recently bought a new laptop a fujitsu siemens amilo and although all drivers and hardware or indicating they are working properly for my printers i cannot print when i try to print a test i get an...
You need first to deleting the old driver and that in device manager and system then shutdown the system and start again (you must be admin) then connect your device and the computer will read the driver for it again. I need to know the printer data name, model, etc. so we can try to get you the correct driver free, let you know. Please see that grant me your approvals by rating my service and I hope that I can serve you again the future.
Sep 26, 2009 | Computers & Internet
Enquiry
That means that you have to uninstall and reinstall Yahoo Messenger.
Go to start then control panel then ADD/REMOVE programs. After that look for Yahoo there highlight it then click on remove. After that restart your computer.
Go to www.yahoo.com then download and install Yahoo Messenger.
I hope this has answered your question. If you have more questions please post a reply and i would be happy to assist. Thanks.
Oct 22, 2008 | Compaq Presario Notebook
Lexmark 3400-- X3430 Has never worked properly with my pc. Will not communicate. Accepts print request but will not print. Will print check page but not request. Does not scan nor copy either. No fax in...
Try using the most recent updated driver for your printer.
Please follow the link below to download the correct driver for your printer directly from Lexmark.
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0
use the product finder to select your exact model and operating system. download the file and save to your desktop. after download is complete, close all browser windows and run the install program. This will properly install the correct driver for you.
Please take a moment to rate this solution.
Thank you
Oct 15, 2008 | Lexmark Office Equipment & Supplies
"Error 1068 Could not start the Printer Spooler on local Computer"
HI,
right click on my computer -> select manage -> one should be services and something (or something like that) open that and go to services -> find the printer spool service and right click on it -> click on properties -> in the printer spool service properites click the "Start" button and also under a drop down menu change it from "Disabled" to "Automatic".... This is what you did right ?
Log in to Administrator account and try it there. If that doesn't work then install a fresh copy of Windows Xp. It should work now. Thank you.
Sep 07, 2008 | Office Equipment & Supplies
Pixma iP1700 error message
see if reinstalling the printers drivers and print software, see if that helps it,
regards
Paul.
Feb 05, 2008 | Canon PIXMA iP1700 InkJet Photo Printer
http://www.usa.canon.com/consumer/controller?act=DownloadDetailAct&fcategoryid=357&modelid=10238 Above is the Canon site with the newest drivers available. Download them and install them. First "delete" the printer from print properties. Unplug the printer from the wall for a few minutes and shutdown the computer. Plug the printer in and reboot the machine. Install the new drivers. You are in a loop. definition of LOOP: see LOOP. Let me know what happens. Good Luck, Tim
Feb 14, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Epson Stylus C20UX InkJet Printer Logo
79 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
